Question about Home Security
A s-20ae safe can I get an override key to buy
It will not open battery flat I have no override key wisy to buy or get one
3 Suggested Answers
kalamazoo222
  • 285 Answers
SOURCE: I have a Richmond electronic
The manufacturer or a locksmith can help you. Look for a local locksmith, or contact Richmind for more info at: http://www.richmondsecurity.com/contact_us.php
Posted on Dec 01, 2010
jyackle5
  • 8197 Answers
SOURCE: I have an ES20 safe,
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
Posted on Apr 09, 2011
Opening my safe when the batteries are low
Without the details of the safe this is very difficult to answer, however most safes have a hidden key slot beneath a clip off panel, If you haven't got a key you would have to resort to a locksmith to pick the override key slot.
Mar 09, 2017 | The Home Security
My Safemark Systems electronic safe won't open. I have the code but my batteries are completely drained. How do I get in safe?
4 0 Electronic Safe
use your cobra key or buy this Emergency Handheld Override,that goes to it,or replace the batteries.
Emergency Handheld Override EHO
Safemark Systems
2101 Park Center Drive
Suite 125
Orlando, Florida 32835
USA
1-800-255-8818 USA
1-407-299-0044 International
1-407-299-7650 Fax
1-800-299-4288 Tech Support
May 01, 2015 | Locks & Locksmithing
Safewell EX2005327788
A set of emergency keys is supplied with every Safewell safe. In case the batteries drain out, you may use the emergency key to open the safe. These keys override the digital password. Remember, never keep the emergency keys inside the safe.
Jan 14, 2015 | Home Security
How to open digital sure loc safe box when the battery no more?
There should be a manual key override just for situations
like this.
Jan 04, 2015 | Safe International Locks & Locksmithing
How do I open my Yale Home Safe YSS0000NFP. The batteries have gone totally flat.
Yale battery operated safes have a manual override function for which keys are supplied.
Nov 14, 2014 | Locks & Locksmithing
I Have a Suresafe 20ES and the battries have gone flat. How do I get the door open
There are two ways you can open this safe. First one is to give alternate power supply for which generally a devise is provided which I do not think you have the access to. Second Option is that you must have manual override keys. With this manual key you can open the safe and then change the batteries.
Jul 10, 2014 | Safe International Digital Electronic Safe...
No override key to open the safe and need to change battery
is there a reset button in the sentry safe X055 that i could use to reset the password
Nov 15, 2012 | Safe International Sentrysafe X055...
Have a Sentry V260 safe. The #1 button will not register when pressed. All other buttons register except for the #1. And the #1 button is in the combo. How else can I open it or how can I fix this button?
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Dec 25, 2008 | Sentry Fireproof Safe
The number 1 button will not press
Key override
battery holder.
5. Open the door.
Dec 24, 2008 | Sentry Fireproof Safe
Home Security Logo
123 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
