Question about HP LaserJet 5000n Printer
HP LaserJet 5000n - Paper jam under the cartridge
HP laserJet 5000N: The paper jam occurs under the cartridge for the 1st page every time try to print.
Appreciate your response
Happy new year
    Problem Solver:
  • 8 Answers
Check the tray to make sure the paper stops are set right and that the printer is set for the correct size paper. Clean the feed rollers above the paper in the tray and if necessary, replace them.
Posted on Jan 03, 2009
I am printing documents to my HP LaserJet 5000n Printer and the printer's not responding. I've tried restarting it and it displays that it's processing a job before displays that it's ready.
Either a corrupted driver or possibly a bad network card or parallel port, depending on how you have it connected. Does the printer print test pages from the on printer control panel ok? If yes, try printing a different document from a different program or try the windows test print from the driver. If it prints the windows test print then likely you have either a corrupted program or file. If it will not print the windows test print then I would delete the driver, download the current HP UPD driver and install that.
Sep 24, 2015 | HP LaserJet 5000n Printer
Printing black paper
check grounds on the main board or clean formatter
Mar 19, 2014 | HP LaserJet 5000n Printer
Paper jams at toner cartridge, printer service maintenance kit installed
Paper Jam clearing: copy and paste the link in your web browser...I used to work with these printer's..when they work great, when they don't, not so great..
https://www.manualslib.com/manual/949165/Hp-Laserjet-5000.html?page=84
Clearing Paper Jams If the printer's control panel displays a paper jam message, look for paper in the locations indicated in Figure 22, then see the procedure for clearing the paper jam. You might need to look for paper in other locations than indicated in the paper jam message. If the location of the paper jam is not obvious, look first in the top cover area.When clearing paper jams, be very careful not to tear the paper. If a small piece of paper is left in the printer, it could cause additional jams. If paper jams are a recurring problem, see page 78.(A paper jam message might also display if the rear door is open.)
The top cover of the printer must be opened and then closed to clear a paper jam message.Paper jams can occur at the following locations:Output areas(top and rear)Go to page 75.
Loose toner might remain in the printer after a paper jam, but thetoner should clear after a few sheets are printed.
Jan 31, 2018 | HP LaserJet 5000n Printer
My HP LaserJet 5000N will only print one copy at a time. No matter how many copies I order, I still get only one copy. I'm on a networked PC using Windows XP. Any ideas?
normally you will need to let the printer know that you have preformed any maintenance on it by clearing the error count after such an error occurs and is fixed it is normally listed under general or service options on the printer menu but you may need to look through the users manual
hope this helps
Robb
Oct 27, 2010 | HP LaserJet 5000n Printer
Label stuck on a roller?
Looks like label stuck on the toner cartridge. Easiest solution would be to replace toner cartridge or if you can slowly spin the OPC drum on toner cartridge till you find label NOTE: damage to the OPC drum with affect print quality as well as oil from fingers will affect PQ( print quality)
Jan 13, 2009 | HP LaserJet 5000n Printer
HP laserjet 5000N - Paper jam under the cartridge every time try to print
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 03, 2009 | HP LaserJet 5000n Printer
URGENT-- engine test problem in HP LaserJet 5000n
iam using hp5000n laser printer. It is giving 13.1 &13.3 error messages freequently. (This is paper jaming problem)
May 23, 2008 | HP LaserJet 5000n Printer
Paper Tray
The paper tray is a non-repairable item. HP replaces them outright.
Jun 12, 2007 | HP LaserJet 5000n Printer
HP LaserJet 5000n Printer Logo
253 people viewed this question
Ben Johnson
