Question about Whirlpool GHW9150 Front Load Washer
Slow spin I have a whirlpool GHW9150 waser. the spin speed does not chage in any cycl. Th drum only spins slowlyni omatter what speed is selected) or no spin (if no spin is selected)
  • 883 Answers
Open the unit. check all motor windings for continuity. motor may have more than one winding for multiple speed
Posted on May 21, 2007
WFS1073DD front load WASHING MACHINE Everything works but will not spin fast enough to spin the water out. It spins very slow
Early automatic washers used a motor with multiple windings to provide the various speeds required by different parts of each wash programme. Modern washers use an entirely different sort of motor and the speeds are selected and controlled electronically with feedback to ensure the speed is correct.
I suspect the problem is the electronics - the part of the programmer and controller that regulates the motor speed but you should check the motor and motor brushes, the drive belt and all electrical connections as a matter of best practice before you spend money...
Aug 13, 2017 | Washing Machines
WSM2480 Clothes Still Wet After Slow Spin Cycle
It's possible that the tub didn't drain properly in the allotted time and the remaining water is slowing your drum from coming to maximum extraction speed.
Jan 10, 2014 | GE WSM2420D Unitized Spacemaker Washer /...
The cleaning cycle wont work.
Did you tried with different load?
It could be the control panel which is not to cheap.
Mar 09, 2013 | Whirlpool GHW9150 Front Load Washer
Washing machine drum does not rotate.
was the waser noisy before it stoped woeking if so it could be your drum bearing or somthing caught in the drum
Nov 10, 2011 | Washing Machines
Kenmore 417.44102 is 5 yrs old. The other day, it started making a banging noise on final spin. I can manually turn the stainless tub, but do hear a grinding noise, as if the tub is rubbing against...
sounds like th bracket on the back of the basket has broken. just replaced mine and itwas abit ofa bear. teardown is all from the back and itis almost a complete teardown, remove back panel and top, remove struts on the lower drum assembly, remoive drive belt. the large drum assembly has a bunch of screws tht holdit together(heads aretoward the front of the waser) remove all of the lower screws, removeth springs from the top of the drum ssemblyand remove he srings. take out thescrews fron th top halfof the drum assembly. the back half should now comeout. remove the bolt holding te drive pully onto the drum assembly then th plastic drum assemblycan b removed from thebassket. the back of the basket has a bracket on it I bet itis broken. this is a 200 dolar part, (basket) and replacementis the reversal ofremoval. it is a difficult and somewhat time consuming repair butit was well worth it for me
Nov 24, 2009 | Kenmore 44102 Front Load Washer
Water leaking and loud noise and rattling on final spin cycle
Turn the drum by hand and if you hear any noises it is the rear bearing. If there is no noise then remove the front bottom panel and take out the coin trap on the pump and check those hoses.
Eric
Aug 27, 2009 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet Front Loader won't get up to spin speed
Careful of overloading the front-loading washers. Too much of this will result in the bearings in the drum to go bad. When this happens, the rpms on the drum slow down due to belt slack. You can only see this with the back off of the unit and in the middle of the cycle. They do not sell replacement bearings...you'll have to buy the whole drum (bearings pressed inside) and for 1/2 the cost of a new washer. I hate front-loaders. I'll never buy one again.
May 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drum off balance
how do I tell if the drum is off balance or the bearings are out in the inner tub of this front load washer?
Jun 30, 2006 | Whirlpool GHW9150 Front Load Washer
Whirlpool GHW9150 Front Load Washer Logo
118 people viewed this question
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
