Question about Razor E300 Scooter
Throttle not working
Battery charged. No power wen I turn the throttle. But wen I lift up the back tyre off the ground the back wheel spins.
2 Suggested Answers
erickedubbs
  • 15 Answers
SOURCE: Indicator light fully charged...but barely enough power to move
i have the same exact problem on 1 of my sons MX5s..i checked all 3 batteries and all that! you left out the controller clicks when the back wheels sapose to be moving ,it's not....so worse case scenerio batt,controller,motor,(650 This time)& throttle....So theres our blue print...lets hope it's just the batteries....!
Posted on Apr 13, 2013
Razor Scooter ground fOrce go cart wont go
The E100 is a Kick Start scooter, the Rear Wheel has to be Spun for it to start. This scooter will not start from a motionless position.
Could be the battery.
Put the Scooter on a block so the rear tire is raised. Remove the standing plate to reveal the battery compartment.
Charge the Unit completely
1. Using a multimeter measure the voltage across the batteries. If the voltage is below 20 volts batteries are dead - Replace batteries.
2. Now for a running test. Turn the throttle and spin the rear tire to preform a kick start. Still measuring the voltage. If the voltage is Below 20 volts or if the voltage drops quickly batteries are dead - Replace batteries.
3. If the voltage is remaining around 24 volts for a long period - then you could have connector problems, clean and tighten all connectors.
I use a fiberglass electronic cleaning brush, as contact cleaners leave residue that interfere with electrical connections.
See my other posts for E100
Feb 07, 2015 | Razor E100 Electric Scooter
My Zip'r 4 is flashing the green light 7 times which means, "A throttle fault has occurred." The Throttle seems to be working fine, How do i fix this issue?
One of the cells of the battery seems to be bad. Though you charge it, and it shows full charge, but at the time of using the throttle the kinetic power is not there. I recommend that you take the battery to battery ware house so they can confirm the problem. If the problem is not with the battery then the issue is with the circuitry, but most likely it is the cranking power of the battery, though it is fully charged, but it get exhausted right away..
Jul 07, 2014 | Zipr Mobility Zipr Xtra 4-Wheel Hybrid...
Razor mx350
Have you tried removing plastic chain guard and making sure chain is not off track i had this problem and that is all it was.
Apr 24, 2014 | Razor MX350 DIRT ROCKET - BLUE
Spinning
It's not fully charged. Try putting in brand new batteries and fully charge before trying again
Jan 05, 2014 | Brookstone Remote Control Helicopter -...
My Dirtbike, wont go after i charge it
Check that the lights on the throttle battery gauge show green. Lift the rear wheel off the ground and apply throttle and watch the lights. If the battery voltage drops under this load, indicated by the light changing to yellow or red, then it is likely the batteries are low in capacity and need replacing. Most battery shops will load test the batteries free of charge to confirm.
If the batteries test OK then it may be a bad connection between the batteries, fuse, switch and controller may also cause the voltage to drop under load,
Oct 15, 2012 | Razor MX350 DIRT ROCKET - BLUE
How will i know if its my batt or motor on off switch lites up red but nothing happens
Lift the rear wheel up off the ground and apply the throttle, while watching the throttle lights. If the throttle light goes from green to yellow or red it shows that the battery voltage is dropping under a light load because the batteries are low in capcity - not holding much charge. Most battery places will load test the batteries free of charge to confirm this.
Have a look at the trouble shooting guide here
http://www.razorama.com/razor-installation-guides.html
and the wiring diagram here
http://manuals.monsterscooterparts.com/recreational/Razor/Wiring/
Jul 30, 2012 | Razor MX350 DIRT ROCKET - BLUE
The lights are on showing that it is charged but will not go. It is only 10 months old.
If the charger is left plugged in longer then 24 hours you may over charge the batteries and they will not work properly. Also You must charge the batteries once a month even if it hasn't been used.
Lift up the back end of the gocart and see if the wheels spin when you pull the throttle. If you only get a clicking sound start by replacing the control modulator. 10 months old your batteries should be still good unless you over charged them. (Leaving plugged in longer then a day) Good luck...
Nov 16, 2010 | Razor 300001-SL Ground Force Go Kart
Mar 30, 2009 | Razor MX350 DIRT ROCKET - BLUE
Car rides rough when accelerating
The throttle position sensor could be kaput.
On the other hand you might begin by cleaning the throttle.It may be sticking. Locate where the throttle cable goes to the intake and use an appropriate spray cleaner to clean the throttle.
Aug 23, 2008 | 2001 Ford Focus
Razor E300 Scooter Logo
44 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
