Question about Onkyo DX-C340 CD Player
Magnavox CDB 586 CD Caroussel Stuck
Won't raise caroussel and eject. No bad noises, just no action.
Took off top and front and can't access back area where CD's are removed by machine. Top plastic piece of the area that holds caroussel is a one piece plastic that can't be removed. All little belts that are visible are good.
Sledge hammer.
Posted on Jan 03, 2009
Show a diagram on how to get cd stuck in 2006 f150 out. Cd stuck and tried but it won' come out
Look to see if there is a tiny hole on the front of CD player just under the tray.that is the access point for a paper clip.if there isn't one...try turning ignition off then whilst holding the eject button turn on the ignition and do not release eject button.
you may need to try this several times.what you are trying to do is beat the cd from trying to read the cd as this seems to over ride any eject commands on some machines.if all of the above fail you may need to remove entire unit from dash to gain access .
Feb 12, 2015 | Ford F-150 F150 Extended Cab
Dvd stuck in computer
push eject button, slap the top of computer sould eject. the rubber type band that turns the wheel to open tray is worn out needs replaced
Apr 10, 2013 | Apple Televison & Video
Deck a will not eject
It is a belt that is loose and the motor that is slipping is the noise you hear. Usually if you can get the belt out and measure it subtract 5%
Dec 20, 2012 | KLH CDR2000 2-Disc CD Recorder
Disassemble the MHC GX20 sony stereo
There might be a small hole for a safety pin. Press that and it will pop open.
Dec 11, 2012 | Sony MHC-GX20 CD Shelf System
Cd got stuck in the caroussel
Somewhat confused. If it won't open, there should be something you can press a safety pin into and it will open it.
Dec 10, 2012 | Sony MHC-GX20 CD Shelf System
2010 Jetta My daughter had a cd in and loaded another one. It is a single cd player. I don't know how it took it? It won't eject. How do I get them out??
If possible remove the unit from the dash, remove the top plate and push the cd out. If not I have removed stuck cd's with small flat nosed needle nose pliers.
Nov 01, 2012 | Volkswagen Cars & Trucks
5disc multiple choice cds stuck in slots how do i
Have a look for a small hole in the front of the CD player - this is the emergency eject button. Find a paper clip, unwind it and then press the paper clip through the hole - the CD should then eject the first CD and you will then be able to eject the others.
Apr 28, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
System wont load or eject any discs...
Remove the disc drive from the console. Remove the cover very carefull. Take the top part off (remove the 5 screws) and open the disc drive like a book.
Carefull remove the guide mechanism (the front part -1 screw).
The clicking noise is caused by the fact that the left side mechanism that raises and loweres the deck when the disk is inserted or ejected is stuck. Carefull push back the piece of plastic with teeth located on the left side of the deck (as you are looking at the disk drive the oposite side with the lens driving motor) until it clears complete the plastic round gear that drives that part.
mount back the guide mechanism, and the top part.
Attached the ribbon cables to the unit , power the console and keep the eject button pushed for about 10-15 seconds.
That will reset all the gears and stuff.
Worked for me when I experienced that issue.
Sep 05, 2008 | Sony Playstation 3 (PS3) Console
Cd is stuck
Disc Eject Prohibit: This feature keeps the disc from ejecting even if the eject button is pushed. The disc eject prohibit feature is engaged/disengaged by pressing the CD and Eject buttons simultaneously for more than 2 seconds.
Nov 30, 2007 | JVC Arsenal KD-AR260
Cds Stuck in cd changer. stuck at no. 6.
i have a infiniti i-35 2002 and my cd player won't play or eject i was switching cd's on no. 4 and when it went in it got stuck inside it won't play no. 1thru6 are there any suggestions
Jun 16, 2006 | Bose Wave music system Multi-CD Changer...
Onkyo DX-C340 CD Player Logo
456 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
