Related Tags:
This problem should be removed because:
Problem with Tivo Series2 TCD649080 Video Recorder
hooking up hdmi cable from laptop to tv
i have sum hd movies downloaded on my laptop. if i hook up tv as secondary monitor using hdmi hookup will it come through in hi def or will s video be just the same
Solutions (1)
Best Solution
yes it will. when u plug in the HDMI. right click on your desktop and adjust your graphic properties for your secondary screen
blank screen on HDMI connection
Using a Sony A-10 rear projection LCD monitor with a HDMI cable for the past 3 years. Last night it just quit working. I then hooked up via...
hooking up laptop to hdtv with hdmi cable
i have some hd movies downloaded on my laptop. If i hook up to my hdtv as a secondary monitor using hdmi cable, will it come through in hi...
Motorola DCT 6200/1000 seems to only have one...
I have a Series 2 DT TiVo hooked up to my DCT 6200/1000 with RCA cables. I also have the cable box hooked directly to my T.V. through...
I have a 32inch Phillips HD ready TV but there
I have a 32inch Phillips HD ready TV but there does not seem to be and HD input for my DVD player
Add Your Solution
my tv guide on my
my tv guide on my tivo says "To be advised" for all channels.
Why dont I get the
Why dont I get the TV guide on Tivo it keeps saying TO BE ADVISED ON ALL CHANNELS
constant 'to be advised' on
constant 'to be advised' on my guide
tv guide says TBA.
tv guide says TBA. However, all connections appear solid and i have downloaded and restarted. Help Michael
Fix-O-Meter
6,031
6,031 people viewed this problem
- 2 people found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Tivo TV Receiver and DVR Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
You can pick up an HDMI to DVI cable from your electrioncs store. Bad thing is, you'll need a seperate cable for sound. A red and white on one end and headphone (3.5) on the other end.
