Question about Sharp AL-1000 Laser Printer
H 4 error
It keep flashing h4 and will not let me press anything
    President:
  • 8,637 Answers
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 26, 2009
What does Olivetti d-copia 120 error message H4 mean?
  1. H4 00 means Heat roller abnormally low temperature
Jan 26, 2013 | Office Equipment & Supplies
The copier flashes an error code H4 and is in-operable. How do i solve this problem.
this is the heater unit error
very quickly in sequence do the following
[clear]-[exposure]-[clear]-[exposure] machinewill go dead input 14 and press start mc will clear error
if the unit is faulty you will have h4 again
Mar 17, 2011 | Toshiba e-Studio120 Copier
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
H 4 code flashing
The H4 code indicates the fuser may have blown the thermistor. It also could be a false error code. Try this series to clear the error and if it returns, then you'll know for sure the fuser is the culprit. To reset press the following buttons:
  1. Press this sequence: CLR-Exposure-CLR-Exposure
  2. The display will go blank
  3. enter "14", press "PRNT"
  4. Press "CLR" several times to exit.
Give that a try and good luck.
Feb 18, 2010 | Sharp AL 1631 Copier
What does it mean when h is flashing
There is a problem with the fuser unit , H2 means thermistor open or not connected, H4 means low temperature or fuser lamp not working. Reset with by pressing ; # , Interrupt , C , Interrupt. Display will go off then enter 14 and press Print key.
Jul 29, 2009 | Sharp AR-5316 Advanced Digital Imager...
H4 problems
Try to reset the error code by pressing : C exp1 C exp1 14 start. if the problem still occur then you should change the heater lamp
Apr 01, 2009 | Sharp AL 1631 Copier
My Sharp AL-1217 keeps flashing H4 and does not respond
This is a typical fuser lamp issue. This is usually caused by a fluctuation in current supplied to the fuser assembly when the copier is warming up.
This cannot be solved by powering off the unit nor by unplugging it!
Follow the simple steps below to correct the issue:
  1. Power on the unit.
  2. When the LED display starts flashing "H" and "4", Press C and Auto button(this is the leftmost button with the copier console facing you)
  3. Repress the C and Auto Buttons again
  4. Press the copies button until 14 appears on the LED.
  5. Then Press the BIG Blue COPY button(the rightmost button with the copier console facing you)
Hurray, that's all folks
Mar 25, 2009 | Sharp AL-1217 Copier
My copier ( xerox xc1040 ) hit a power surge . It
i speak a littlebeat english.
H4
00
Low Temp
you cant erease this code
in panel control
press (clear ) (exposure select key) (clear) (exposure select key) (14) & (start key)
14: Resets H3, H4,
Feb 28, 2009 | Xerox Office Equipment & Supplies
Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
Feb 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AL-1000 Laser Printer Logo
70 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
