Question about Toshiba 50 Inch Big Screen Flat Tv Theater View Rear Tube Projection Low Hours
Television the picture gets distorted and a wavy line goes up the screen. doesn't always happen
    Genius:
  • Toshiba Master
  • 2,432 Answers
If you are using a cable box, tried to reset. then tried to unplug any connectors that has been hooked to the component input of your tv.
Posted on Oct 27, 2012
Ws55613.picture is wavy, sometimes it happens as soon as you turn the tv on and sometimes it takes hours. the wavy lines eventually become purple and pink. still able to see picture, but very annoying and...
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Feb 24, 2011 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi VS-55609 distorted Picture Flickers
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs. To get fixed either call in a local TV repair company or goto sites such as Tv Repair Kits to get a repair kit with instructions. Here is there link.
http://www.tvrepairkits.com/xcart/home.php?partner=papa1dude
They have put together complete kits for most models that include the parts, step by step photo instructions, repair assistance, etc.
May 14, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Wavy line goes through picture during color changes,picture cut off on bottom
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 25, 2010 | Hitachi 60SBX78B 60" Rear Projection...
JVC AV-48WP30 convergence drifting after IC replacement
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 16, 2010 | JVC AV-48WP30 48" Rear Projection...
Red, Green convergence lines are wavy
*Screen Looks 3-D
*Colors wont align
Sep 16, 2009 | Akai PT4298HD Rear Projection Television
Wavy lines appear across the screen
*Screen Looks 3-D
*Colors wont align
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Pictures goes to distorded wavy lines.
This could be attributed to tuning reception of your tv. If your using antenna only, it is most probable. If cable, check your line.
If this is a crt type, moving that tv with that size could somehow bend its circuit board. Loose connection is a probability. Could be some minor component is detached from solder. This can be attributed to tuner and vertical IC.
Just for an input.
Apr 20, 2009 | Sanyo DS27910 27" TV
Screen Out of Focus with Wavy Lines - Perfect Focus Will Not Corr
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Red/Orange looking video
You can see some examples and find a fix here...
Mar 06, 2009 | Samsung HCM4215W 42" Rear Projection...
Hitachi Projection Color Lines
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 29, 2008 | RCA P52937 52" Rear Projection Television
Tv has wavy lines 6" from top and sometimes from the right side a wavy line
heart ach... of having bad convergance amp ic's
Dec 20, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba 50 Inch Big Screen Flat Tv Theater View Rear Tube Projection Low Hours Logo
79 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
