Question about Video Cameras
Sony minidvcam DCR-HC37 tape door mechanism won't close, no indications
The tape door won't close either with tape in nor without a tape. No indications, no flash lights. it's just not closing...
  • dengotsis
    dengotsis Oct 27, 2012
    Nothing happens after I took off the battery, it's still the same, NO indications, No errors..
3 Suggested Answers
  • 13 Answers
SOURCE: sony handycam dcr-hc38 tape door wont close. fault
Try this if you are tech savy, if not you may want to take it to a person to have it fixed or send it off to sony.
1. unplug camcorder AC cord
2. remove fat battery from back of camcorder
3. remove slim battery from under the LCD (it's the size of a nickle coin)
4. wait 2 minutes
5. plug AC into the camcorder
6. flip the camcorder into VTR mode
7. tape should automatically eject
Found at : http://www.camerahacker.com/Forums/DisplayComments.php?file=Video%20Camera/Sony/DCR-TRV350_tape_wont_eject_C.32.11.html
Posted on May 31, 2011
ZJLimited
  • 17970 Answers
SOURCE: I have a Sony Handycam
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Posted on Jun 06, 2011
The cassette door to this camera will not retract when I try to close it. as you probably know you close the door partially, the casstte holder retracts and then you can finish closing the door. When i...
Hi.
My name is Rick and I am the owner and technician of Discount Camera Repair. The problem you are experiencing can be repaired fairly inexpensively but will require disassembly by a qualified technician. The camera will need to be disassembled to remove the tape mechanism and then the tape mechanism will need to be disassembled to repair. If I can be of any help please call or email me and I'll get the camera working for you.
Dec 27, 2011 | Sony Handycam DCR-IP5 Micro MV Digital...
Tape door won't close i get error message reattach power. i've reset , used different power supply, still tape door won't close any goo ideas? chuck
big problem with sony as you can see im a pro tech but had the same fault with mine. and it broke my heart 4 weeks old and sony dont give a dam ironicly a mate told me slam my fist under the bottom and it will close after hrs of trying to fix it i took his stupid advice and after many hits it closed and worked great for a few weeks
Sep 12, 2011 | Sony Handycam DCR-HC96 Mini DV Digital...
Sony dcr-dvd408 can't open the access door to get the tape. I hear cliking but it won't open
This can be due to failure of the loading motor mechanism . Since you are hearing the clicking sound , it is possible that the motor is working to the command from the processor but there is failure in the mechanical drive., This can be due to pulley slipping , gear failure or belt failure.
Unless the camera is opened to remove the covers and get access to the mechanism , the exact fault cannot be confirmed.
Aug 16, 2011 | Sony Handycam DCR-DVD108 DVD Camcorder
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
My sony handycam dcr-hc26 door won't close. error C:32:11
Remove battery/ power source from camcorder for minute, reattach battery/ power source and close the tape door.
If that does not solve problem then I'm afraid, tape mechanism got defective and will be replaced.
Let me know if you need tape mechanism part number info.
Thanks.
Dec 09, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Looking for a driver for XP
http://www.bioticaindia.com/dcr-hc37.html
http://esupport.sony.com/US/perl/model-find.pl?mdl=dcr%20hc37&PRODTYPE=33,32,63,71,7,102,26,80,72,44,55,84,74,27,57,61,103,89,10,35,78,48,77,29,50,39,64,58,12,41,81,52,60,66,73,45,101,86,76,62,54,67,70,68,17,2,1,88,100,82,25,28,83,59,69,49,24,53,79,42,22,46,13,6,85,3,36,9,51,47,38,4,34,37,43,5
May 05, 2009 | Video Cameras
Sony DCR-TRV510 error code C 31:10 tape bay closes then opens
The error code was indicated the LS chassis assy is defective, bad luck it require a qualified Tech trained from Sony. I suggest you to bring it in Sony to repair it would cost you about from $180 to $250 if you are in AUS
I hope that give you some ideas
Dec 04, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Tape door wont close
I'm having a similar problem. The camera is a Sony DCR-TRV280. When you put a tape in the tray will not go down. However when the tray is empty and you push it shut it will go down. In other words the mechanism works fine without the tape but with the tape it doesn't. I hope the explanation is clear enough. Thanks
Mar 21, 2007 | Sony Handycam DCR-TRV525 Digital Camcorder
Video Cameras Logo
362 people viewed this question
Top Video Cameras Experts
Are you a Video Camera Expert? Answer questions, earn points and help others
