Question about 2000P Radar Detector
My k40 system mythodically chirps twice every ten seconds. Error code?
2 Suggested Answers
SOURCE: My K40 Undetectable seems faulty
the on board diagnostics is telling you the rear sensor is bad or disconnected
Posted on Oct 07, 2010
My security system will not respond to the key fob commands.
Possibly change the remote battery? Get thee to a mechanic
Jan 30, 2014 | Viper Vehicle Parts & Accessories
My K40 unit keeps beeping 2X every 10 seconds or so.. It still goes off when radar is present but it wont stop beeping. any insights would be helpful
You have a K402000 radar system. The double beep is a rear receiver disconnect notification. If you go to the K40 website and access their dealer locator from the dealer section, you can find an authorized dealer to help you with this problem or you can call K40 directly and speak to them...they really are a great company to deal with.
Aug 20, 2011 | Calibre Radar Detector
Can`t get the hand set to lock or unlock, and i ha...
Open the boot/trunk lid and drivers door. Switch on the ignition to position II but do not start the engine. Wait for the dash lights to extinguish. within 5 seconds of the lights going out, Rock the valet switch, in the centre console, 5 times. The system will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions, the first key-ring transmitter will be linked to memory 1, second to memory 2 etc
Press and hold the larger, lock, button on the key-ring transmitter whilst watching the Red LED and ether wait for it to stop flashing or for the system to chirp a confirmation it has got the signal. If the system doesn't receive any signals for 15 seconds, it will chirp twice and exit learn mode
To program further key-ring transmitters, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the key-ring transmitter as above
When finish, wait 15 seconds for the system to time out and chirp twice, turn off the ignition, close the doors and boot lid.
May 21, 2010 | 1995 Jaguar XJ6
Vehicle is stuck in valet mode. Steering column is locked. Vehicle is a 2006 Jaguar XJ8L. Cannot open the glove box to get the owner's manual.The battery is fine.
Open the boot lid and drivers door, and switch on the ignition. Rock the valet switch, in the centre console, 5 times. The system will chirp to indicate it has entered learning mode.
On models with seat/mirror/steering wheel memory functions, the first remote will be linked to memory 1, second to memory 2 etc.
Press the larger, lock, button of the remote. The system will chirp to confirm it has got the signal. If it doesn't receive any signals for 15 seconds, it will chirp twice and exit learn mode.
To programme further remotes, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the remote as above.
When finish, wait 15 seconds for the system to time out and chirp twice, turn off the ignition, close the doors and boot lid and the job is done!
Mar 07, 2010 | 2006 Jaguar XJ8
Jaguar xJ6 X300 The electric seat has stopped working . I can hear the two relays clicking on the left hand side of the driver chair so assume the fuse is ok . Any ideas on how to fix it .?
the motors stick ( freeze ) i have heard that disconect the battery for an hour helps with this,and you may need to reprogram everything after..
Mar 03, 2010 | 1994 Jaguar XJ6
I removed the battery from my car and when i put it back in the car would start all the control panels work in the car I just wonderd if i had to reset the alarm with the fob
To reset remote, rock the valet switch once. The system will chirp twice for remote number two, three times for number three etc, then press the lock button of the remote as above.
Feb 28, 2010 | 1993 Jaguar XJ6
Aug 20, 2009 | 2000P Radar Detector
How do you arm the factory security system? Pushing the button on the remote once?twice ? Need to know arming and disarming procedures .Thanks poorbob
push the button twice to dissarm the system, it will arm itself after about 30 seconds you should be able to see that its armed by the indicators flashing or if you have a siren fitted it will chirp twice . this function can removed but it will automatically self arm
hope this helps
kind regards
bert31000
Mar 19, 2009 | 2003 Harley Davidson FLHT Electra Glide...
Grill-mounted K-40 continues to "chirp" every 10 seconds...
I too had the same problem and called their customer service. They told me 1 chirp means a front receiver fault, 2 chirps means a rear receiver fault. They suggested I check the wiring and to switch the front receiver with the back receiver to see if the error code would "travel" with it to determine if the receiever was faulty. I did that and the problem went away. I assume I had a connection that loosened up.
Jan 13, 2008 | UN 3000SW Radar Detector
2000P Radar Detector Logo
37 people viewed this question
Top K40 Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a K40 Vehicle Part and Accessory Expert? Answer questions, earn points and help others
