Question about Tivo Series2 TCD649080 Video Recorder
Hooking up laptop to hdtv with hdmi cable
I have some hd movies downloaded on my laptop. If i hook up to my hdtv as a secondary monitor using hdmi cable, will it come through in hi def
  • capricornsky Apr 09, 2009
    im trying to to hook up my HDTV Sharp32 in with my HD HP laptop using the HDMI cable and i can not seem to get picture
Only if your graphics card can handle HD viewing
Posted on Mar 07, 2009
How do I hook up a laptop to my 32 inch element to watch movies?
You have to activate the external video port. Usually F8. Check your owners manual.
Nov 18, 2014 | Element ELCHW321 32-Inch Class 720p 60Hz...
Can't get picture on HD TV using HDMI cable
The simplest method
1. turn off tv and laptop
2. hook up hdmi cable from laptop and then to hdtv
3. turn on laptop and once the laptop has booted fully,
4. turn on tv and select the source....
Feb 11, 2011 | HP Pavilion dv5tse Notebook
Laptop connection
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Apr 27, 2010 | Philips 37PF7320A 37 in. HD-Ready LCD...
BEST CONNECTION FOR TAPE PLAY ON HDTV. VCR HAS BOTH HDMI AND S-VIDEO PORTS PLUS THE STANDARD A/V PORTS
Use the HDMI cable to hook up the DVD/VCR combo.Use the HDMI ports and cables,best result for the new format HD Movies,Tv's shows.Less clotters too.
Mar 20, 2010 | Televison & Video
I just got my first HD TV, I want to know how to use HDMI cables to hook up my suround, ps3, Wii, and Cable.
Very easy to hook up.It just two USB hubs hook up with a wire basicly.Use 3 HDMI cables for one each device.
Feb 16, 2010 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Need to hook up laptop to TV
If you have an HDMI port you might also have an RGB port, use your tv video source button and go through your options. If RGB option is listed you have it. It's a standard moniter port, you can use a standard monitor cable to hook things up. This will not however carry sound so you'll need a basic 3.5mm size cable that ends in an RCA plug (can be picked up radio shack.
I use this method to watch hulu.com movies on my 50" plasma tv.
Another option if you have an "S" video on both the laptop and the tv, use that with just an "S" video cable.
Other wise look for a RGB cable that converts to standard RCA stereo plugs again Radio Shack should be able to help you. You can also buy cables on eBay a lot cheaper then a retail store.
Aug 19, 2009 | Acer Aspire 5720-6661 Notebook PC
Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Feb 14, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Hooking up hdmi cable from laptop to tv
yes it will. when u plug in the HDMI. right click on your desktop and adjust your graphic properties for your secondary screen
Jan 03, 2009 | Tivo Series2 TCD649080 Video Recorder
Audio Trouble hooking PS3 up to HD
Hi there, Have you checked that the HDMI Cable is inserted into both your PS3 and HDTV correctly ? if the cable moves about in the HDMI port that causes static sometimes ! Also check that your cable isn't damaged.
If the problem persists. i would just Use your Composite (Red,Green,Blue) connection from your TV to your PS3. you said it doesnt have static problems. and Using the composite cable you can still get the Full 1080p Resolution on your TV that the PS3 can Up-Scale to!
Hope this Helps ?!
Oct 27, 2008 | Sony Playstation 3 (PS3) Console
Rca hdtv m50wh754s
You need a audio cable for sound. HDMI cable is only for picture. I use the comp 1 plugs myself, better picture. I found with my TV that the HDMI cable is only good if you have a digital box for it. You can also use the plug to hook your computer to off your graphics card and watch downloaded movies on.
Oct 06, 2007 | RCA HD52W56 52" Rear Projection HDTV
Tivo Series2  TCD649080 Video Recorder Logo
814 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
