Question about NorStar Meridian M7310 Phone
All of a sudden the line lights on our nortel switch Meridian M7310 phones started blinking and the lines are dead. Any ideas?
We have a Nortel switch in our home that was installed for the original builder, an ATT executive. We have a single line on the system, and, today, the lights on the control or line buttons began blinking and we lost service. We also have a regular phone connected that does not go through the Nortel switch, and it is working fine.
  • 458 Answers
If you only have one line,why not just lose the Nortel system? You can reuse the wiring from the phone sets to the contoller as regular inside wire,and just plug in regular phones(and maybe put the Nortel phones and controller on EBay and make a few bucks off it!)
Posted on Oct 27, 2012
  • Jim McLendon Oct 30, 2012
    That might work for us, and I've considered that. Right now my doorbell is also tied into the system and I would need to redo that. This may be my ultimate solution. Do you know of a reset switch/button on the Nortel Meridian?
  • 3278 Answers
SOURCE: Meridian M7310; just installed replacement phone
Normal 0 Hello, Gary.
Disconnect power and cables from all phones and faxes on the line 3. Wait 15 minutes and reconnect the line again, one at a time. See if the Meridian works. If not, it could be faulty.
Hope this helps.
Posted on Feb 01, 2010
consultel1
  • 860 Answers
SOURCE: Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Posted on Sep 28, 2009
  • 18 Answers
SOURCE: Nortel M7310 Phone moved to another jack, now no incoming calls
The reason your phones config is not the same as before is because configuration goes by what extension it is. So if you plug your phone in somewhere else, unless you have DN's configured, your extension changes, so say it was extension 21, but now that you moved it, its now 23, those settings remain on extention 21, so if you bought another phone and plugged it into were extention 21 is, it would have the settings that your old phone had before
To access the intercom by just picking up the handset, Press Feature **CONFIG (266344), Select <A. Configuration>, then go to <2. Line Access>, Select that and enter the extension of the phone you want to have access intercom by just picking up the handset. Scroll until you see <Intercom Keys: #,> make sure you have at least one intercom key. Then scroll until you see <Prime Line: #>, Press change until the display reads <Prime Line:I/C>  And there you go. Hope i didn't confuse you
Posted on Oct 02, 2009
  • 18 Answers
SOURCE: I have a nortel norstar M7310 phone. we have used
Feature #85 (Note #FEATURE CODE deactivates that feature code)
Posted on Nov 17, 2009
  • 52 Answers
SOURCE: We have a Norstat Meridian M7310 phone system - is
THE PHONE IN THE BACK IS THIS A NORSTAR PHONE. WHAT IS THE QWEST VMAIL AND WHAT DOES THE NORSTAR SYSTEM LOOK LIKE . SOUNDS TO ME THAT QWEST IS SUPPLING VMAIL AND NOT YOU OWEN NORSTAR COULD YOU CLARIFY THIS FOR ME.
Posted on Dec 22, 2009
Nortel m7310 cant use touch tone
Try Feature 808 before pressing the touchtone digit - it tells the Norstar to send Long Tones to the remote system.
Jul 22, 2013 | Nortel Meridian M7310 Business Phone...
My M7310 won't forward a call to the next open line but gives a busy signal
Hard to answer because your problem description does not match the part.
Nortel Meridian M7208 Corded Phone is a digital phone which works off a phone system.Also note that the carrier controls the rollover, not the phone or its system.
Once you have more/proper details maybe you can be helped.
Dec 14, 2012 | Nortel Meridian M7208 Corded Phone
Power source
A Nortel Key Service Unit, an ICS (MICS,CICS), BCM (50,100 etc), Norstar (308,616,824), an Avaya IP Office running Nortel cards, or there is another company that makes a Nortel emulation key system but I can't recall what it is right now.
Carl
Nov 23, 2012 | NorStar Meridian M7310 Phone
Have Norstar M7310 5 line phone 2 lines say they
You need to unplug something, just not the phone.
The two lines are probably conferenced together. Go find the gray Nortel cabinet and pull the plug on it.
Carl
Oct 30, 2009 | NorStar Meridian M7310 Phone
Phone is dead! M7310
There is no power cord required for an M7310 set. The set gets all the power from the Nortel telephone system. Try plugging in your phone where another phone is active to ensure that your phone that you want to install is working. The phone flashes, then stops, then flashes, then stops... you just have to be patient when testing. Possible Troubles: -> It maybe the line cord, the cord that plugs in from the wall to the phone that can be damaged. -> the jack might be dead (wiring in the jack is pulled off) or inactive (there is no jumper from the office to the telephone system). -> the phone port from the telephone system might be dead.
Jun 06, 2009 | NorStar Meridian M7310 Phone
Nortel T7316E acts like M7310
Feature *81 will move line buttons.
May 04, 2009 | Nortel T7316E 2-Line Corded Phone
''nortel meridian switch goes dead then resets'' power supply?
Sorry to tell you but your system is going dead the power supply is going bad . The system needs to be replaced. if you are local in so cal I can install a replacement system for you 626-712-5753 efren
Feb 04, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Can't turn feature light off on my Merdian 9417CW
I have an A8674966 Nortel 23 line phone
Light on 2nd line won't shut off, no mesage
Dec 05, 2008 | Nortel Meridian 9417CW 2 Line phone
Caller id only displays after i pick up the line
it is a progrsamming issue that can be fixed where are yuou located?
you can call me at 3107016774
Sep 18, 2008 | NorStar Meridian M7310 Phone
Meridan 7208 help please
Dear sheryl498,
Your phone is designed for a PBX (Private Branch Exchange) unit like the Compact ICS or the 6x16 TCU that was at the office. It is not compatible with regular POTS lines or standard home lines.
Jul 29, 2008 | Nortel Meridian M7208 Corded Phone
NorStar Meridian M7310 Phone Logo
466 people viewed this question
Top NorStar Lands Phones Experts
george  peters
george peters
dan4261
Level 1 Expert
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
