Question about Miller matic 140 Mig Welding Package W/As 907335
How to wire the run cap and thitewire that go it
How to wire the run cap and the two white wire that go to it
  • 57 Answers
You are talking about the 2 white wires that come out of the gun and conect to the welder right? You are also talking about the wire that runs off the spool though the gun? Well if not this will not help you but if you are then it is the solution. The gun slides through the hole in front of the welder. inside there is a butterfly screw that needs to be loosend to allow the gun end to go in all the way. you tighten the screw back down after (welding whip) gun is installed. after that if you look inside the welder at where you just did the work to slide the gun in. You will look above the whip and see two prongs that are sticking out to allow the 2 wires to slip onto the conection. It should not matter which wire goes on which tab but both have to be connected. After that then turn on the welder and squeeze the triger for a second and the wheels on the inside of the welder should start turning. Now shut off the welder and unplug it. After you install the spool you will notice two rollers. Well on the left hand side of the rollers you will see a kind of handle / nut at the top. you should loosen the nut a few turns and be able to slide it to the left until it pivots down and out of the way. now you should be able to pivot toe top roller up enough to get the wire in there. Take your wire and carefully run the wire through the rollers and into the gun. Only put in about 6 inches or so of the wire. Now you lay the top roller back down and make sure that the wire is in the groove of the roller. After that is dont then pivot that retaining bolt back up to hold down the top roller. If it feels like a hard thing to do then loosen the bolt cap a little bit more to allow for the wire size. Now tighten the retainins screw just a little bit once you put it back into original position. After this make sure that you do not have a welding tip or nozzel on the trigger side of the gun. Now plug back in and then turn welder back on. keep the welder whip as strait as possible.Extended from the machine with zero loops in it. it is alright to bring it back to the side of the machine so as you can see what you are doing. Now squeez the trigger and the rollers should start moving. If the wire roll is not feeding wire into the gun then that nut that holds the roller down needs to be tightened up just a touch. Sqeez the trigger again and see if it despences the wire. if it does not then tighten and repeat until it does. DO NOT OVERTIGHTEN! That will flatten or crush the wire wich will wear out your internal gun and you rollers. Use the least amount of presure that you can to get the wire to spool into the gun. Well that should do it. If that is not the solution you are looking for then let me know and I will see what else I can come up with...Good luck....keefers
Posted on Jan 04, 2009
How to wire light switch?
ok! only hook up the switch to the black wires and cap the 2 whites together. just run 12/2 wiring with ground to switch, hook the black to switch in and black to switch out to light.. cap the white wires to and from switch! you can either hook ground wire to switch or the steel switch box. hope this helps, im not very good with words.
May 04, 2012 | Cars & Trucks
Need capacitor wiring diagram
No model number gotta shoot from the hip on this one:
The cap has 3 sections: Herm for compressor, F for fan, and C for common.
The common section of the cap gets a hot wire off the power cord, a wire from compressor marked C on compressor and a white common wire from the fan gets connected to C on that cap. These wires are almost always white in color on American OEM. The fan has a small brown wire that connects to F on tha cap. The compressor has a wire marked S on it make a note of that color wire and connect it to the section on the cap called HERM. Herm stands for hermedtically sealed compressor. So both your commons and a hot wire go to C. You need one small brown wire which goes to F from the fan. One wire marked S on the compressor goes to Herm for compressor starting. S stands for start winding.
Lets look at typical American fan motor wires: The fan has a black wire for high speed a blue wire for medium and a red wire for low. It has white wire for common, and a brown wire for capacitor. Connect your common fan wire to common and the brown wire to F.
With that cap properly connected basically all you would need to do to make it run is connect a fan speed, the compressor wire marked R for RUN, and and the other power wire.
Jul 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
Utilitech Wall Timer #0192773 does not switch landscape lights on? Replaced Intermatic that had 3 wires. Black to Black, blue to black and red was capped. Utilitech came with 4 wires - black, white,...
Old timer: Intermatic EJ500 & ST01C timers have a battery. Battery operates the clock motor. Red wire is for 3-way circuit [a hallway with 2 switches is a 3-way circuit].
Utilitec timer, clock runs on 120Volt circuit instead of battery. So clock has to have power.
How to connect wires:
Black timer wire connects to hot wire from breaker box.
Red (or blue) timer wire goes to landscape lights.
White timer wire connects to white neutral wire [or if no neutral is available, connect to bare ground wire].
Green timer wire goes to bare ground wire.
How to find black hot wire and white neutral wire inside box
: Disconnect and separate wires so you can test. Use ordinary tester. Power is on. There is only 1 black hot wire inside each electrical box. Test each black wire to bare ground until tester light comes on > that identifies the black hot wire. Next, test black hot wire to white wires until tester light comes on > that is the neutral wire. Exception: This test does not necessarily work with 3-way switches since they reverse each time switch is thrown.
Sep 14, 2010 | Intermatic Inc. ST01C Digital In-Wall...
I just purchased an fse1028sf to replace my faulty fan motor. I purchased it from a a/c supply store. My existing fan only had three wires. They were brown, black and purple. Black to: capacitor "c"....
Hi, this is a different wiring diagram then what you have . The 2 brown/wht wires are for the run cap only. Black and white are t-1 and t-2. They sold you a motor that takes its own run capacitor to run it with just both brown wires. Take the diagram from the new motor back along with your original. They will give you the right run cap to go with this motor. Yes, the red wire is power to fire your existing cap and old motor. You will need another cap to run this motor. Don't put the 2 brn/white striped wires on the old cap! They have to be alone on there own run cap. Go back to the parts house and they will show you very fast the wiring diagram and give you the cap. This is a very easy fix when they give you what you need. Keep me posted and ask them to give you what you need to run the motor. A 5 uf run cap perhaps?
Keep me posted.
May 03, 2010 | Heating & Cooling
I removed the cover on my mk 101 tile saw to replace the switch and the wires came off the run capacitor. Does anyone know which wires go where. Theres a neutral coming in from the cord on one side and 3...
OK MOST Caps aren't polarized, so can go on anyway... Check to see if there is any + or - on the Cap... NO then connect it up anyway .. if yes Phase needs to go to + Neutral needs to go to -.
Black is normally Phase, which probably goes to the motor so the other two, white & blue must be for the Cap.
But unless ya can get a schematic from manufacturer this is only an educated guess.
Jan 29, 2010 | Diamond Products Mk - 101 10" Tile Saw
Dell Latitude XT2 fails to start up.
I know this is an old post, but the LED code for CAPS lock on, F4 flashing, F5 on means memory issue. I had this issue, reseated the memory, and the issue was resolved.
Sep 23, 2009 | Dell Latitude XT2 Tablet PC
Sidewinder Fan Works but not the Light
As you were assembling the wire from the fan motor to the house wiring, there should have been two wires labled. One would have been labeled "FAN" and the other "LIGHT". To properly attach the wires, (be sure the power is off) twist the thin labeled black (FAN) and blue (LIGHT) wires together. Now attach those two twisted wires to the black house wiring with one of the supplied wiring cap. Finally attach the thin white wire to the white house wire with supplied wiring cap. Your fan is now ready for operation. If you had performed all these steps when you first assembled the fan, then the thin black wire going to the fan has come loose. Should your ceiling fan still not run after all that, then it's time to return it where you bought it because either the pull chain switch is defective or the manufacturer produced a defective piece of merchandise. If you found any of my suggestions to be helpfull, please rate my solution. Thanks D. Lange
Apr 19, 2009 | Hampton Bay Sidewinder 04890 Ceiling Fan
Replacing blower motor in furnace w/Fasco brand #D727
Some one missed the wiring diagram. I believe its like this:
L1 = Line 1 = (Hot all are same thing)
Black Hi
Blue Med
Red LO
Now usually the black is for AC and connects to a normally Open (NO) contact on the blower relay.
The heater speed (either red or blue) go the the normally Closed (NC) on the blower relay and on one side of this wire or contact on the relay it goes to the heating blower thermostat on the furnace.
The remaining wire (blue or red) you tape off.
L1 also feeds the Run Capacitor on 1 side and the Brown wire feeds the opposite side
The white wire is Neutral and goes to the neutral on the main line.
If this helps you please rate me accordingly and good luck.
Mar 13, 2009 | Kitchen Appliances - Others
Wiring compressor
The two terminal cap is only for the new fan motor. Connect the compressor wire back where you found it, on the 3 terminal cap. It's the terminal marked, "herm". The "common" terminal on the 3 terminal cap must still be connected to one side of the 220 power at the contactor. One side of the 220 goes to the common on the compressor. The other side of the 220 goes to the run winding on the compressor AND the common terminal on the 3 terminal capacitor.
Jul 18, 2008 | Carrier 38CKC036 Air Conditioner
Miller matic 140 Mig Welding Package W/As 907335 Logo
79 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
Jay Finke
Jay Finke
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
