Question about Pioneer Vintage Home Theater System Sa-1050 Sg-550 Tx-950 Ct-1050w Rare Manual
How do i install a fan in my pioneer SA-1050 amplifier?
I would like to install a cooling fan in my amp but i dont know the best way to do it or if its possible.
5 Suggested Answers
SOURCE: All I want is two
To whom it may concern, I am sorry but I was able to find the two plugs I was looking for in my junk draw . thanking you for your concern regards theeich.
Posted on Apr 28, 2008
Benimur
  • 6966 Answers
SOURCE: Connecting Pioneer DEH-2000MP to an amplifier
Hi and welcome to FixYa,
You would need a special adapter that connects to the speaker wires of the Pioneer DEH-2000MP and converts them to line level RCA ports. Something like the image below and available from here or most car stereo stores.
Good luck and thank you for using FixYa.
Posted on Feb 13, 2009
lesliemurphy
  • 69 Answers
SOURCE: I have a Pioneer SA 1050. All the lights come on
check your speaker selector switch to see if its on the correct setting ie; speakers one ( not speakers 2 ) also check your speaker cables by reversing them, ie; put right speaker cable into left channel and vice versa with the left etc? check also to see if your amp is set to headphone output by mistake in which case no sound will come out until you select the speakers instead? good luck.
Posted on Sep 14, 2009
  • 73 Answers
SOURCE: I have a pioneer amplifier sa-1270 very old. I
partsearch.futureshop.com, pacparts.com, digikey.com; local electronic parts store -- use google search or yellow pages
Posted on Oct 12, 2009
Pioneer SA-1050 will no longer power up
I would check the internal fuse(s) in the power supply. If they have blown replace them. If they blow again suspect a shorted power output device on the heatsink.
It's best to look at the soldering on the PC board, especially on second hand devices. This will show you if it has been repaired. If the soldering doesn't look like new, someone has been messing with it. They could have done anything to it, including fitting wrong parts, or fitting the right parts but not doing it right.
Jul 21, 2013 | Audio Players & Recorders
Pioneer SA 1050
IF it still uses a rotary track control, you can clean it with Servisol Switch Cleaner or Video 40.
However most modern systems use an IC to control the volume, which could be faulty.
Mar 06, 2013 | Audio Players & Recorders
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
Pioneer sa-1050 2 burnt resistors, cannot read
where exactly are these resistors located? any idea about the circuit board resistor numbers? sometimes burnt resistors do not go completely bad and is still possible to measure their values. why not take them out and try measuring their values. otherwise u have to b very specific about the rsistor numbers
Apr 05, 2010 | Audio Players & Recorders
I asked earlier about my pioneer amplifier sa-1270 circuite fuse but the circuit I need is PD 4088-A7507H48 and LB 1214. Do you know where I can find these cicuits?
This may work but i always take my amps to a tv repair place. They normally dont work on these but i convinced him to do it. He fixed both amps i took to him. Try ur luck
Oct 12, 2009 | Audio Players & Recorders
Jun 24, 2009 | Pioneer Audio Players & Recorders
Help with CVR 12 (kickers) and a Power 1050 s amp (Rockford Fosgate)
Send me your email account and i will draw you a diagram and send it to you there. I will need to know if the ohms of each sub as well as the amp. I'll also need to know if the subs come with one or two voice coils.
Ciza
Nov 04, 2008 | Rockford Fosgate Power 1050S Car Audio...
Su-g91
Have you checked the fuse in the unit?
Aug 31, 2008 | Technics SA-AX540 Receiver
Pioneer Vintage Home Theater System Sa-1050 Sg-550 Tx-950 Ct-1050w Rare Manual Logo
77 people viewed this question
Top Pioneer Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Computer Links
David
David
Are you a Pioneer Computer and Internet Expert? Answer questions, earn points and help others
