Question about Toshiba Satellite A135 Notebook
Dvd drive doesnt recognize that a disc is in
I cannot burn or play any disc in my dvd/cd drive. When I put a disc in it just spins and the computer doesnt acknowledge that it is even there. I have a toshiba satelitte A135-S2306 with a pioneer dvd rw drive. I tried to download a new driver and it tells me its working so I dont need one. I am at a loss and our local shop where I purchased it sucks!! I cant seem to find any drives that fit it online either.
  • jsta Jan 12, 2009
    I go to the device manager and under properties it says "this device cannot start ( code 10)" What does this mean?
    Sergeant:
  • 320 Answers
Hi... This is lens problem.. Clean the lens using cleaner disc. and make sure that the dvd/cd rom icon is present inside the My Computer. if not then go to Control Panel->System->Hardware-Device Manager->enable the dvd/cd drive....
Thank you...
Posted on Jan 03, 2009
Sony DRX840U DVD/CD RW Burner won't play a DVD!
you hvave to check the compatibility first. next is the location rights to play the movie dvd ., other wise., the dvd locks the play.
Nov 18, 2014 | Computers & Internet
Hey guys, I've fluffed up something on my win7 computer, PIONEER DVD RW DVR-107D ATA Device haven't got a clue what I did to make it go wrong but it no longer plays movie data that I have burned...
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
Jun 22, 2011 | Pioneer DVR-107D DVD±RW Burner
Computer not recognizing Dvd drive
Hi, Check the MS word / software file it works DVD drive, if it recognize there is no problem the drive and play CD - format files.
If not recognize, i found that DVD Lens not working what you can do DVD lens cleaner disc you found stores. Rgds, Manju
Jan 26, 2010 | Computers & Internet
My drive will not burn dvd-r anymore but it used to, it burns cd-r and reads discs no problem, but now when i try to burn the disc spins but makes a strange knocking noise.
sometime it has more to do with the driver software than it does with the unit itself.
Try uninstalling the writer software, restart the computer, reinstall the software, restart the computer, and attempt burn again. Software occaisionally gets confused and needs to be "rebooted" from time to time. Hope this helps.
Oct 12, 2009 | BenQ DW1670 Double Layer 16 DVD RW IDE...
CD drive doesnt recognize a dvd
Sorry to say, but a CD drive cannot read DVD's. You need a DVD reader. Thus, the CD drive will not recognize DVD media and tell you no valid disc is in the drive. I recommend buying a DVD RW (reader/writer), as they are inexpensive and enable you to burn DVDs as well as read them.
Jan 01, 2009 | Dell Dimension 3100 PC Desktop
Gateway laptop pc wont recognize blank discs in drive E:
Are you sure E: is the cd/dvd burner?
Can you put a cd with music or a dvd movie in there and get it to play it?
Mar 19, 2008 | Gateway 7330GZ Notebook
The cd drive does not recognize any discs
That is not a DVD drive, it is a CD-ROM drive. It can not play DVDs.
Jan 20, 2008 | Panasonic CD FOR TOUGHBOOK (cf-vcd721w)...
My Lite On DVDRW will not recognize any audio cd's...
Hi PhxROcker,
In these drives there are two lasers and two pick-up sensors. Normally in a combined head. One set is used for the DVD and the other is used for the CD. From you description it sounds like the optical sensor for the CD laser has expired! When you place a CD into the drive a small amount of information is read by the drive that identifies the disc type, manufacturer, it's status, capacity etc. If the drive cannot read this then it thinks nothing is present.
If you insert a disc does the LED on the front the the unit flash a few times while it spins the disc. Does it do this repeatedly? If it fails to read the disc does the LED stop blinking and the drive no longer spins the disc? If this is the case then your drive may indeed be faulty.
Sorry I could not be of any further assistance.
Regards,
Spare head 2.
Jan 05, 2008 | Lite On (SHW-1635S) DVD RW Dual Layer...
Cd not recognized
Often the Laser for the CD section gets burnt out... I have seen this often there is no fix... Ya gonna haveta get a replacement sorry.
Apr 19, 2007 | Lite On (SOHW1633S) DVD±RW Dual Layer...
Toshiba Satellite A135 Notebook Logo
175 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
