Question about HTC Mobile Phone One S Black
My htc one s wont turn on even though it is charged
I can not get my phone to turn on, i have held down the power on button but nothing happens, i have also held down the power on and volume up and down buttons together but again nothing happens. can you help?
  • dollinc
    dollinc Mar 04, 2013
    i fixed mine by pushing the power button and the down volume button at the same time and then when the white screen came on choice recovery and let it go to the black screen with a little icon on it then pushed the same two buttons to power down the phone after like five minutes and the pushed my power button twice and it came on!
SOURCE: HTC P3400i LCD Problem
My Htc p3400i phone can't share fast informnation via Bluetooth
Posted on Jan 21, 2009
  • 61 Answers
SOURCE: HTC touch HD is completley frozen
If you have all your items saved to your computer with Active Sync, then do a master reset:
HTC Touch hard reset 14 January 2008
  • Power on.
  • Press and hold buttons marked 1.
  • Press and release 2 with stylus.
  • Release buttons marked 1 when menu comes up.
  • Press directly down on center dpad, marked 3.
You can also get tips & tricks from www.htcwiki.com
It has the latest and great updates, software, even known issues if you ever come across this. HTC does recommend that you do a master/hard reset once a quarter to keep it moving smoothly. Also, ensure you don't have a lot of open running programs. Perhaps once a day, clean the cashe and history. Do a soft reset (aka battery pull) once or twice a week. All depends on how hard you play with this lovely PDA device!
Posted on Feb 10, 2009
270rexton
  • 782 Answers
SOURCE: HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
Posted on May 12, 2009
adri65
  • 30 Answers
SOURCE: HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
Posted on Jul 12, 2009
SOURCE: My HTC Touch Pro turns completely off in the middle of the night
I think I have found out the way to solve this problem! I think! Ok on my phone I changed the power settings. Go to settings>all settings(if on touch flo)>system tab>power>advanced tab> then uncheck the two boxes that says "turn off device if not used for". Hopefully this works because I don't want to trade in my htc for another phone. Try it out and let me know if this works for you or not.
Posted on Jul 21, 2009
Htc first won't boot
Try holding volume Up and volume down together then the power button----hold all three until vibration starts.......that should get you to a factory reset.
Dec 04, 2013 | HTC First Android Smartphone AT&T Locked
I used a standard micro usb charger before reading the manual and the phone is now completely dead. Even with the correct charger now the light won't even come on. I am in shock that the phone is that...
Have you tried a hard reset? Hold the power button and the down button simultaneously and see if the phone turns on. It could be the cable but I think it was more the power supply unit that could have something to do with the glitch.
Oct 22, 2013 | HTC Cell Phones
I have an HTC 8X phone and it has randomly decided to turn off and is now unresponsive to the power button and chargers. It was perfectly fine a second ago with no problems at all. And unfortunately this...
  • First try a 'soft' reset (no data loss)
  1. Just hold the power button down for 30 seconds.
  • If there's no joy there then try a 'hard' reset (may cause data loss though most of your data should be backed up through SkyDrive)
  1. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
  2. Release the VOLUME DOWN button when you see an icon on the screen.
  3. Press the following hardware buttons in sequence: VOLUME UP > VOLUME DOWN > POWER > VOLUME DOWN.
  • If nothing happens that time, try holding down VOLUME UP, VOLUME DOWN and POWER buttons all at once for thirty seconds or until the phone vibrates.
  • If non of these work try them in the same order but after the phone has been charging for one hour.
  • If there's still nothing after this, comment here and I'll post steps for recovery attempts through your PC or Mac.
Good Luck,
Matt
Sep 11, 2013 | HTC 8x 4g With 16gb Mobile Phone - Blue
My htc 8s wont charge
Do not do a hard reset,you don't need to. Hold the power button down for twenty seconds and the phone will reboot itself.
Jun 13, 2013 | HTC Windows Phone 8S
My htc freestyle wont turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Nov 05, 2012 | HTC Freestyle Smartphone
HTC Touch 3g clone (T3238) won't turn on, no lights, nothing!
Simply!
Power off the device, then hold the Volume Down and Enter buttons at the same time, then press the Power button.
A message should come up asking if you’re sure you want to do this, let go of the buttons you held down and press the Volume Up button to accept, or any other button to cancel the reset.
please note >> it is will delete all your data ...........!
Oct 05, 2009 | HTC P3300 Smartphone
My Iphone wont turn on
listen to solution number 4..I tried it and it worked. Hold the power and home button until the apple logo pops up and your golden
Jul 20, 2007 | Apple iPhone Smartphone
HTC Mobile Phone One S Black Logo
889 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
