Question about Goodman GMS90703BXA Heater
Blower motor a technician came over and said the motor is brokedn a need to be replaced. wondering how much should cost the piece and labor. thank you
  • 499 Answers
400-500
Posted on Oct 31, 2012
Estimate to replace ac/heater blower motor
Cost of the new motor plus half hour to 45 minutes labor time- just depends on what is in the way of getting to the blower motor. It is usually a pretty easy job, the fan blower assembly is retained by 3-5 screws. Take it out and put fan assembly on new motor, then reinstall.
Jul 30, 2015 | Cars & Trucks
What is the approximate cost of labor to replace blower motor
Over here in Austria it would cost you about 100 Euros + the blower which is about 150 Euros. You may check the cables, connections and fuses first.
Jul 28, 2014 | 2003 Kia Sorento
Looking at buying a 2001. What do I look out for? It has 90,000 miles. Timing Chain? Transmission? Headlamp covers? Electrical?
Engine r.gif An occasional problem on this vehicle is the failure of the Timing Chain and Guides (2.7L engine only). Failure of the Timing Chain and Guides may prevent the vehicle from starting. The cost to repair the Timing Chain and Guides is estimated at $537.80 for parts and $292.50 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax. Transmission & Driveline y.gif Occasional problems on this vehicle are failures of the Transmission Turbine Speed Sensor and the Output Shaft Speed Sensor. The cost to replace either of the Speed Sensors is estimated at $25.60 for parts and $32.50 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax. Steering & Suspension g.gif Infrequent problems reported, all with low repair costs. Brakes g.gif Infrequent problems reported, all with low repair costs. Heating & Air Conditioning y.gif An occasional problem on this vehicle is the failure of the Blower Motor Resistor, 4 door sedan only. Failure of the Blower Motor Resistor may cause the fan to run only on high speed. The cost to repair the Blower Motor Resistor is estimated at $14.75 for parts and $32.50 for labor. All prices are estimates based on $65.00 per flat rate hour and do not include diagnostic time or any applicable sales tax.
Thank you and good luck,
Lee
Aug 25, 2010 | 2001 Dodge Stratus
Cost to replace blower motor on Honda Accord?
The part from the dealer is $180.65 ,labor is .5 hours about $50. If you go to a independent shop the cost should be less:)
Nov 24, 2009 | 2002 Honda Accord
My blower fan only works on high?
Have the blower motor resistor replaced, part cost-$25.00, labor .50 hour. It is behind the glove box and very easily accessible. Don't let anyone say your blower is bad. The resistor controls voltage to the motor.
Sep 28, 2009 | 1998 Jeep Cherokee
My blower motor will only blow on level 4 and 5. 1,2 and three
Inside the blower housing under the dash by the floor is a resistor that fits inside the housing. It gets damp and burns open. Cheap to buy part, takes a contortionist to replace. I managed, and I'm old. It has two wires going to it.
Jun 15, 2009 | 2003 Pontiac Grand Am
Heater blower quit working
U will need a new switch, a new connector to the switch, a new blower motor and a new blower motor speed control resistor to fix this right, about $200 for parts and 2 hours labor time, so in my area about $400. my local labor rate is $100-125 per hour.
Mar 23, 2009 | 1996 GMC Jimmy
Heat levels..
need new technician.if the blower motor works even with only one speed than the blower motor works and did not need replacement.sounds like blower motor resistor or resistor wiring,when there is a problem with the resistor or wiring you will only have one speed,this way you atleast have heat.so if your tech replaced the blower motor when it worked and did not need replacement then it sounds like he is just throwing parts at it,you have to wonder if he really checked anything.have the resistor and wiring checked and if ok then check the heater control head and wiring.
Nov 06, 2008 | 2001 Ford Expedition
Help with a noisy Fisher & Paykel dryer
I have the same problem. Replacing the front glides (two glides cost under $20 plus labor and service call). The second time it seems to be more than the front glides. Service tech says that it is the blower moving back and forth on the motor shaft. (Because of a worn indentation on the shaft..). Therefore, he says that I must replace the motor and the blower--parts cost approx. $290, plus labor and service call. Ouch! Also says that the plastic front support piece is worn. More money! So, I am looking at a new dryer instead of trying to patch up the one I have (it's out of warranty.)
Oct 21, 2007 | Fisher and Paykel DE06 Electric Dryer
Goodman GMS90703BXA Heater Logo
22 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
