Have an ag2540,put in a tape,and now there is 5 feet of it all over the inside of the unit.how do I release the tape and then what is the problem
    Genius:
  • 1,199 Answers
It sounds like the rollers are dirty and need to be cleaned to be cleaned ( A Q-TIP and achol will do fine) getting the tape out can be tricky because its unwound inside of unit you may have to take unit apart and cut the loose tape then eject
Posted on Jan 03, 2009
  • 50 Answers
Press eject, if this does not work and it wont come out...take it apart and try to take it out
    Genius:
  • 1,011 Answers
I can't understand the problem. is this projection television? plz tell me the brand name and model no. of product and description of product
My affinity dryer wont spin
Try to clean out the coin trap and drain lines first.
1. Unplug the unit.
2. Tilt the unit up to where the front feet are in the air and the back feet are still on the ground. Please make sure the unit is propped up safely.
3. Now that the unit is propped up look inside on the bottom right hand side there is a black looking accordion thing. This is the coin trap.
4. Clean the drum out with as much water as possible and have towels ready. The next step you will have the remaining water come out.
5. At the top of the coin trap where it is attached to the drum is a silver spring with a silver screw. Loosen the screw and wiggle the coin trap down from the drum.
5. Reach inside the coin trap and clean what is inside of it out.
6. Put the unit back together following the same steps backwards
Sep 10, 2012 | Frigidaire Affinity ATF7000EG
Tape Stuck
I've checked the entire user manual which notes problems like this need to be referred to authorized service personnel. Myself, I would unplug the entire unit, put it on a kitchen table using a phillips (cross-tip) screwdriver to remove the top metal shell. Remove at least 2 screws each side and 2-5 rear screws securing the top. Nothing like peering inside to see what is causing the VCR to get stuck and help remove it. No release pinhole or tape freeing ejector will work if the unit's tape is tightly wound around some internal object or the tape is stuck because something foreign is inside the unit. Best of success. ZT3000 "Beta tester of "0"s and "1's"
Aug 17, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Why washer leak from the bottom
You would need to try to clean out the coin trap in the bottom of the unit.
1. Unplug the unit.
Sep 09, 2012 | Frigidaire ATF6000ES Front Load Washer
Electrolux front loader drain problem
1. Unplug the unit.
Sep 06, 2012 | Electrolux Washing Machines
Need tub capacity
Instructions
Things You'll Need:
* Measuring tape
1.
Measure the depth from inside the washer with a measuring tape. Start from the back of the inside of the washer towards you to the front of the washer. Measure the depth from a top loading washer from the bottom of the inside of the washer to the top. For example, a washing machine may have a depth of two feet.
2.
Measure the height inside the washer unit. The height inside the washer is from the bottom of the inside of the washer to the top of the inside of the washer for a front loading washing. The height is from one side of the inside of the washer to the other side in a top loading washer. For example, the inside of a washer may be one and a half feet, or 1.5 feet.
3.
Divide the height calculated in step 2 by two, and square it. In the example, 1.5 divided by two equals 0.75, and 0.75 to the power of 2 equals 0.5625.
4.
Multiply the number calculated in step 3 by the depth of the washing machine. In the example, 0.5625 times two equals 1.125.
5.
Multiply the number calculated in step 4 by Pi to determine the capacity. Pi is generally estimated as 3.14. In the example, 1.125 times 3.14 equals a washer capacity of 3.5325 cubic feet
Dec 21, 2010 | Washing Machines
I just need to know how to erase tapes (audio) with a realistic tape eraser cat. no. 44-233A???
1. Plug into a standard 110-120V AC power outlet.
2. Select a tape [or similar small object]...
3. Hold the eraser in your hand and squeeze the trigger. The red light indicates that the unit is operating.
4. While squeezing the trigger, place the bottom of the eraser in contact with the item to be erased. Move the eraser slowly in a circular motion over the entire product area but do not release the trigger yet.
Make circular passes arount the tape for approximately 10-20 seconds, then slowly withdraw the eraser until it is about three feet away from the tape. Now release the trigger.
5. Turn the cassette or diskette over and repeat steps 3 and 4.
Aug 31, 2010 | Audio Players & Recorders
When i put a tape in it beeps then would not eject
Ether the tape is cought inside the camera or the eject motor is not releasing the tape inside try the following
1. Take battery out
2, put it back in and press the eject but with the camera up to your ear.
If you hear it trying to eject the tape got ate inside the unit best thing here to do is take it to a camera shop have them extract the tape.
Hope this does help please do make sure you rate before you leave.
Aug 17, 2010 | Sony Handycam CCD-TRV68 Camcorder
I have a Sony DCR-TRV250 Digital Handycam Camcorder. Currently a tape is stuck in it and the camcorder won't eject it. The tape unit comes out but won't open.
I got the tape to eject by removing the battery from the camcorder, putting it back on so that the tape would go back inside the camera. Then I had the tape eject again. Several times the tape would not be ejected but I repeated my steps until the camera released the tape.
Nov 16, 2009 | Sony Handycam DCR-TRV280 Digital Camcorder
I do believe my vcr has died. I had a tape in and it stopped and took awhile until it would release the tape to let it come out. I pushed it back in and after 5 mins it did the same thing and didn't...
You may have already done this but I have run across VHS cassettes that a unit just wouldn't load and play. Try another cassette to see if it responds the same way.
Apr 15, 2008 | Symphonic WV806 DVD Player/VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
