98 mustang cd player doesnt work
98 mustang. so my cd player stopped playing my cds a couple months ago been to busy at work to look at it just checked all my fuses pulled the negative line from the battery to reset everything cleaned the fuses nothing has worked wondering if its a lost cost and should just replace the unit with a new cd player really dont want to but i am running out of options.
    Master:
  • 444 Answers
I installed car audio equipment for over 38 year befor i (Retired) End all so am a (Certified) Electronic (Technician) It will cost you more to have it (Repaired) Then to just go out end buy a decent new one.
Posted on Oct 26, 2012
SOURCE: CD player stops to read disk two and nothing happens and won't play cd's
there could be a wine gum jamming it up honest i had the same trouble hope my knowledge helps u
Posted on Jul 04, 2007
robotek
  • 1512 Answers
SOURCE: Cannot get music CD's to read.
The lens have a bad habit of falling out of the optic assemblies. They are held in with only a 2 dabs of glue. You can VERY CAREFULLY glue it back in. It is a plastic lens and affected badly by the wrong type of glue. Use a craft/modelling glue. DO NOT USE SUPER GLUE It will cloud the lens and render it useless.
  1. Remove the lid and remove the 4 screws that retain the laser traverse assemly(it has a brown flexifilm attached to it). dont UNPLUG ANYTHING
  2. Gently turn the entire optics assembly over by carefully maneuvering it(there is an earth strap to unscrew that may make it easier).
  3. Wit the assembly facing upwards, refit the lens back into the laser assembly, ensuring that it is sitting entirely flat
  4. Then use a tiny dab of glue( I use a Tarzan's Grip, a craft glue ) to EITHER SIDE of the lens making sure that it is dabbed on both the lens and the mount that it fits into
  5. Let the glue go off(couple of hours)
  6. Clean the lens with a cotton tip moist with windex(glass cleaner), and then again another dry one to be sure there is no smear left.
  7. Remount the traverse assembly and test
Check that the rubber suspension mounts have not perished also If they have collapsed(they should sit within about 1mm of the retainer screws when refitted), they will need to be replaced also. You will need to get them from a Pioneer service center. They are about $1.00 each.
APPLY SPARINGLY. Glue everywhere or on the face of the lens can easily destroy the coating.
This method works 4 out of 5 times without having to do the grating adjustments on the optics. And save you $100 for new optics and time to set them up. Good luck, and dont forget to rate me "FixYa" If you need more advice on these players... i have fixed hundreds of them. They are well worth repair and hard to replace with anything similar. .
Posted on Feb 06, 2008
VOTIT
  • 2071 Answers
SOURCE: CD player won't play disk and says "no disk"
The problem of "'no discs'"displayed is in the mechanism in the roller thats moving back and port bringing the lense set .The old grease thier is already hardened that cause the problem.Clean that by using a lighter fluid or like that fluid to take the old grease,and put it with a new one first class grease type-A grease put only a little grease and wipe the lense with a cotton buds without any chemicals on it .Try this solution so performance will be better.
Posted on Jun 18, 2008
SOURCE: nsm jukebox wont play cd
Sorry for my bad englisch...i am from the netherlands...i have a nsm songbird cd-jukebox...i put one euro piece on the laser so he has a little more pressure on the cd...thats all...he is working perfect now
Posted on Feb 22, 2009
localwonder
  • 6784 Answers
SOURCE: Denon DCM 390 not longer reads discs--HELP!
Hi there, this lens may be dirty or it may have a thin layer of heat film that is causing it to not read in a consistent manner. i would try to clean the lens with a good CD lens cleaner. if the cleansing doesn't restore the lens to its original reading state, this will confirm lens assembly failure and you will need to replace this assembly.
Posted on May 18, 2009
Cds play on all cd players but the ones i made on new computer do not why?
it all depends on the CD's your using. some CD's will not play on some players. try DVD-R blank disc, this may make a difference. try one to see ! I ran into the same problem a while ago! it depends on the player itself, DVD-R 4.7GB data 16xspeed. this should work if player is compatable with it.
Jan 23, 2012 | JVC Computers & Internet
CD Player in caravan doesn't play burned cds.
the CD player is a clever one thats looking for the copyright on the CD .Try using nero to burn the cd that oftens fools the player ,or an old computer with windows 98 on it with a copy of the old nero or windows media player that come with windows 98 as the later versions will not work with a lot of expensive players .if it has a line in plug then use a i pod or your mobile phone ,if it has a tape player then use a cassete with the wire coming out that plugs into a audio device ,i use my mobile phone which has a 1gb memory card in my jag as i have the same problem with the cd player ,also in the every day car my escort i use this as iam fed up with having the window broke and cd player nicked .But i have found that burning cds with an old computer with windows 98 i can burn cds that will play in the jag ,not that i use it a lot cant affords the petrol here in spain at 5 dollars a gallon
Aug 01, 2010 | 1999 Dodge Caravan
Philips mc235B/37 CD player no longers plays CDs. I get a "No Disc" error or an "Error" message. CD's often don'teven spin. If they do, they spin slowly, then stop, and start spinning in reverse before...
if you can see the laser then gentaly with a soft cloth wipe the lens
and then try
if that doesnt work then i recoment that you call philips and see what they say because it is slightly older than one year they might replace it for free
if not call the shop that you bought it from
May 09, 2010 | Philips MC235 Shelf System
My portable dvd player doesnt play dvd only cd
use a lens cleaner to clean the lens of ur dvd player
Jul 11, 2009 | Televison & Video
Jukebox won't play selection, selects cd's 1-100 in order
Dear Amanda, Here is the manual,
Try re-programming your juke box per the instructions in the manual.
If you will e-mail me at deeddawg@bellsouth.net , I will E-mail you the 100 page manual in PDF format.
Gary.
Jun 28, 2009 | Wurlitzer Jukebox 1015 One More Time...
CD player won't play CDs burned on new computer
hi penguinxy.
try get a original cds if it works fine.the next time you burn cd try burn at 8x or low may be your cd lens is not detecting cds burnt at high speed.hope this helps..
May 10, 2008 | Jensen CD-2010X CD Player
USB and CD Player Stopped Working
Checa en el manual si no activaste un candado con el usb.
Apr 09, 2008 | Kenwood KDC-X591 CD Player
My cd player wont play my burned cds
this happens all the time, instead of getting CD-Rs, try getting the CD-R Music, they are specially made to be played on CD players, I buy these all the time and they work in every CD player.
Feb 09, 2008 | Jensen CD4610 CD Player
Skipping
If you go out and buy a cleaning disc it may help. You should really clean a car cd player at least ounce or twice every 6 months to get the best sound and play out of the unit. You can pick these disc up at any walmart , kmart , or computer store. Hopefully this can help you out
Dec 18, 2007 | Kenwood KDC-MP228 CD Player
Wont play cds burnt by new computer?
is the files your burninthe same format m8 ie mp3,wma
Dec 09, 2007 | Stanton C.313 CD Player
52 people viewed this question
 Grubhead
Grubhead
