Question about Craftsman 26 Hp 54" Deck Yard Tractor
Will not start no spark - Craftsman 26 Hp 54" Deck Yard Tractor
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 100 Answers
Check all fuses and does headlights come on when you turn the key on
Posted on Oct 27, 2012
Car does not get a spark changed distributor twice,coil still does not start
No-start, No-Spark diagnosing simulated - YouTube
? 5:13
https://www.youtube.com/watch?v=XSWN1M8Hoqo
May 19, 2010 - Uploaded by FrankHurtAuto
Simulation of no start with no spark diagnosing, ... I do get power but no flash on the light when cranking engine. Read more Show less. Reply
Engine Won't Start No Spark - Auto Diagnosis Repair Helpaa1car.com/library/no_spark.htmEngine won't start problem caused by no spark. ... If you have a scan tool, plug it into the vehicle diagnostic connector and look for an rpm signal when cranking ...Spark Related No Start Problems on Car - Auto Repair
Dec 01, 2015 | Cars & Trucks
Engine Turns Over But Will Not Start
1. check the oil
2. Spray starting fluid in card 1 second
3. try to start
if no
pull spark plug and with leather gloves hold 1/8 from cooling fins
if spark = YES spray starting fluid in to hole where spark plug goes. repeat step 3. If spark = NO remove flywheel and check points clean contacts and recheck for spark.
if runs for short while after apray of starting fluid - clean carborator ( see youtube)
replace spark
Nov 10, 2013 | Cub Cadet Garden
Have a 2003 Mazda Tribute having intermittent starting problems. It will turn over but not start. Also it will die while driving every now and then. Have replaced IAC, fuel filter, and fuel pump works...
You need to determine what you are losing when the car won't start - either spark, or fuel.
Check for spark with a spark tester at one of the spark plugs. If no spark when attempting to start, you have an ignition system problem. If you have spark, but the car still won't start, you have a fuel delivery problem.
Nov 02, 2013 | Cars & Trucks
1990 Cadillac Seville won't start. Is it the electronic control module?
Car not starting or turning over indicates towards multiple possibilities. It can be issue with battery or weak battery. But if battery checks out ok, then it can be starter issue or faulty alternator or problem with low fuel pressure or no spark at spark plugs due to dirty spark plugs or faulty ignition coil or injectors getting cracked or dirty and needs to be cleaned.
To confirm the problem, the basic troubleshooting is required.
Click this link below and follow the troubleshooting:------
http://technoanswers.blogspot.in/2012/02/car-starting-issues.html
This For spark plug problem, click the help links provided below: ---
Car has no spark?
http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
How to Replace Spark Plugs?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
Car cranks, has spark but will not start?
http://howtobyme.blogspot.com/2011/12/car-crankshas-spark-but-will-not-start.html
The spark plug firing order for car?
http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
How to gap spark plug ? http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html
Spark plug Replacing for?
http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
How to identify number one spark plug on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
How does the spark plug wire go on the distributor cap?
http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
Spark plug Firing Order Diagram?
http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 19, 2012 | 1990 Cadillac SeVille
2001 Kia Rio, motor start very well first time after drive around 2 miles motor no start no more
For spark plug problem,click the help links provided below :---Car has no spark?http://schematicsdiagram.blogspot.com/2011/06/car-has-no-spark.html
------------How to Replace Spark Plugs?http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-spark-plugs.html
-------------Car cranks, has spark but will not start?
The spark plug firing order for car?http://schematicsdiagram.blogspot.com/2011/06/spark-plug-firing-order-for-car.html
----------How to gap spark plug ?http://technoanswers.blogspot.in/2012/02/how-to-gap-spark-plug-on-chevy-impala.html-----------Spark plug Replacing for?http://technoanswers.blogspot.in/2012/02/spark-plug-replacing-for-chevy-impala.html
-----------How to identify number one spark plug on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-to-identify-number-one-spark-plug.html
---------How does the spark plug wire go on the distributor cap?http://schematicsdiagram.blogspot.com/2011/12/how-does-spark-plug-wires-go-on.html
---------Spark plug Firing Order Diagram?http://schematicsdiagram.blogspot.com/2011/12/2006-suzuki-forenza-spark-plug-firing.html
This will help.
Thanks.
Feb 03, 2012 | 2001 Kia Rio
Started kawasaki fc420v put in gear started pushed lever to start mower and it died. check spark plug no spark.
You need to try a new plug and see if you get spark with that one. You may have to get in a dark area to see the spark. A blue spark means it's good, a white spark means Coil is not so good, and no spark means it's a bad Coil. If you still have no spark, then you have a bad Ignition Coil (Module).
Good Luck!
Jim
Aug 08, 2011 | Garden
Car will not start, engine turn fast enough to start. swapped relays still would not start. 2003 madza tribute.
Check if you have a spark by pulling the spark plugs and crank the car while the spark plug is on the ignition coil/spark plug wire and ground the threaded part of the spark plug and ask someone to start the car and look for a spark is a spark is present then ignition is fine. If spark plugs are wet and smell like fuel there is problem in the ignition system.
Mar 14, 2011 | 2003 Mazda Tribute
Will not start
THE BLOWERVAC COULD HAVE GAS PROBLEM OR A NO SPARK TO SPARK PLUG PROBLEM. TO DETERMINE THE SPARK PROBLEM FIRST, REMOVE THE SPARK PLUG, LOOK AT THE END OF THE SPARK PLUG (ENGINE END) TO SEE IF IT IS DRY OR WET WITH GAS, THEN RE-ATTACH THE SPARK WIRE WHILE THE SPARK PLUG IS LAYING LOOSE AND PULL THE ROPE TO TURN THE ENGINE AND LOOK TO SEE IF THERE IS SPARK OCCURING AT THE SPARK PLUG. IF THERE IS SPARK PRESENT, YOU HAVE NO PROBLEM WITH SPARK. REPLACE THE PLUG AND WIRE. IF NO SPARK CHECK YOUR WIRE LEADING TO THE SPARK PLUG TO MAKE SURE IT HAS AN ELECTRICAL CONNECTION AT BOTH ENDS, SPARK PLUG END AND ENGINE END. IF LOOSE FIX THE CONNECTION THEN RE-TRY THE SPARK/ENGINE TURN OVER BY ROPE METHOD AGAIN TO SEE THEN IF YOU HAVE SPARK. IF THEN YOU DO HAVE SPARK, RE-ATTACH SPARK PLUG TO THE ENGINE AND RE-ATTACH SPARK PLUG WIRE TO THE SPARK PLUG AND TRY THEN TO START THE ENGINE.
IF THERE WAS A WET PLUG WHEN YOU FIRST REMOVED THE SPARK PLUG AND YOU NOW HAVE SPARK AT THE SPARK PLUG, YOUR ENGINE SHOULD START.
IF IT STILL WILL NOT START AFTER THE SPARK CHECK, I WOULD REPLACE THE SPARK PLUG WITH A NEW ONE.
IF THEN IT WILL NOT START, THEN REMOVE THE SPARK PLUG AGAIN AND POUR A SMALL AMOUNT OF GAS INTO THE ENGINE SPARK PLUG HOLE. A PINT PLASTIC OIL CAP FULL OF GAS IS ENOUGH, DO NOT OVER USE MORE THEN THAT.
THE RE-ATTACH YOUR SPARK PLUG AND SPARK PLUG WIRE AND TRY STARTING THE ENGINE AGAIN. IT MAY TAKE SEVERAL PULLS TO GET THE EXTRA GAS IN THE SPARK HOLE TO BE USED UP BEFORE YOU START TO HEAR IT RUN ALITTLE AND FIRE NOW AND THEN.
IT SHOULD START THEN.
IF THEN IT DOES NOT START, YU HAVE USED UP THE GAS YOU PUT INTO THE ENGINE BY THE CAP FULL METHOD AND IT IS NOT GETTING GAS BY THE GAS TANK SUPPLY.
THIS MEANS THEN YOU HAVE AN IN LINE GAS LINE FILTER THAT IS PLUGGED UP OR YOUR GAS MAY BE OLD IN THE GAS TANK. IF GAS IS NOT OLD AND FILTER IS NOT PLUGGED, THEN YOU NEED TO REMOVE THE GAS LINE LEADING TO THE ENGINE CARBURATOR TO SEE IF IT WILL FLOW FROM THE GAS TANK OUT THE GAS LINE SUPPLY HOSE. IF IT DOES FLOW FREELY, THEN YOU DO NOT HAVE A GAS SUPPLY PROBLEM,
AS LONG AS YOUR GAS IS NOT OLD GAS. OLD GAS WILL GO BAD IN TIME. I'D REPLACE THE GAS WITH NEW AND TRY AGAIN.
IF THIS DOES NOT WORK, THEN ITS CARBURATION CLEAN UP TIME.
IT WILL NEED TO BE REMOVED FROM THE ENGINE BY A FEW BOLTS, HOSE'S REMOVED AND TAKEN APART AND CLEANED. TARNISH FROM GAS AND OIL WILL BLOCK THE CARBURATOR JETS AND VACCUM PUMP FROM WORKING PROPERLY. CLEAN AND REPLACE, TRY AGAIN TO START ENGINE.
MORE GAS IN SPARK PLUG HOLE TO GET GOING MAY BE ANOTHER ATEMPT AFTER CARBURATOR CLEAN UP.
Feb 20, 2011 | Homelite Mighty Lite Blowervac
Craftsman 26 Hp 54" Deck Yard Tractor Logo
42 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
