Question about Maytag Atlantis MAV7260B Top Load Washer
Hi..i have a maytag top loader washers that won't turn or spin...can hear belt squealing and smoking
  • 91 Answers
Tip machine machine back now access belt should have motor pulley, pump pulley and middle big yellow thrust bearing,, usually pump is broken
Posted on Jan 03, 2009
Washer squealed, gave off black smoke in spin cycle
For sure change the belt. Clean the pulleys with a solvent to remove anything oily or like melted belt. The machine probably was overloaded. If it's a front loader, check the bearings.
Nov 24, 2013 | Washing Machines
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Maytag belt problem
Sounds like a partially seized component. The belt will work under average load, but when it reaches spin cycle where it must run at high speed it may be encountering too much resistance from the component that it is spinning. Was there a whining or squealing sound? Did you notice any smoke or odour? Perhaps a failed bearing may be to blame, or an errant piece of clothing. My machine is a Maytag front loader and I can easily turn the drum with my fingertips. I don't know what machine you have, but basic mechanics tells me that the motor is spinning and the piece the motor is trying to spin via the belt is resisting. Hope this helps. Cheers!
May 19, 2009 | Vic Tokai, Inc. Trouble Shooter for Sega...
MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
May 12, 2009 | Maytag PAV2300 Top Load Washer
Washer does not turn or spins
the pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Very load noise when tub stops spining
My washer did the same thing. I put some belt dressing on the belt (the belt is on the very bottom, no disassembly rquired). The belt dressing I picked up at the local auto parts, and this seemed to help.
Dec 11, 2006 | Maytag MAV6200 Top Load Washer
Open Questions:
Maytag Atlantis MAV7260B Top Load Washer Logo
169 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
