Question about Harman Kardon AVR 335 Receiver
I have a AVR 335 Karman,no TV sound ,I have outher input sounds,please advise
4 Suggested Answers
lock123
  • 6831 Answers
SOURCE: I have an AVR 335 less than 3 years old no sound
Hello
Yes, there is something you can try, to know where to look for the problem if this happens again. If the receiver is still under warranty, just send it back, otherwise, open up the amp and trace the path back from the speaker channel to the capacitors on each channel, this is usually the problem(you should be able to see if it is blown, cheap to repair).
If all the channels went out at the same time, there is something wrong with the central unit, to repair that, if it is not the above problem, cost expensive.
Hope this can help you.
Kind regards
Andrea
Posted on Nov 09, 2009
  • 417 Answers
SOURCE: Harmon/Karden AVR 230 Surround Sound Receiver
Use your remote to get into the Menu. Look for something called audio, or audio properties. In there you can choose your inputs (sources) and output choices.
On the remote itself, there should be a button called input, or source. That would be for things input to the TV.....such as dvd, vcr.
Posted on Apr 07, 2010
Testimonial: "Thanks for the great advise. My entertainment center is up and running and life is good!"
walesarumi
  • 6993 Answers
SOURCE: We recently purchased an AVR
This is how the connection is suppose to be, DVR "OUT", to TV "IN" using the RCA plugs, then press AV on the TV. If this is how you connected it, then maybe there is something wrong with the video wire (Yellow).
As for the DVD, you need to connect an Audio wire separately because the component Red + Green + Blue wire only stands for video. Audio is Red and White, this must be connected for you to get sound from the DVD.
To connect the Audio for your DVD player, connect Red and White wire to Audio "OUT" of your DVD player, to "AUX" in of your AVR 146 receiver, then select AUX on your receiver and sound will come out from your DVD through the receiver.
I hope this is not complicated for you. This connection is simple, all you need is to understand the basics which is OUT and IN. If you want to watch DVD on your TV, this means the DVD will be good OUT to IN of the DVD. The same goes for audio.
If you don't understand, please let me know so that I can direct you further.
Good luck.
Posted on Oct 06, 2010
How to connect and set up my DENON AVR-3300 to my LG tv. Waht connections on amp and tv do I use?
  • if you want to listen your TV on your Stereo system thru your receiver, AVR-3300 ** you need to connect "Audio Output " RCA jacks or "Optic cable output" of your TV
** to "AUX input " or "TV" OR "Any input" of your receiver ( except Phone ) or "Optic Cable input"
** than just switch to respective mode on
AVR-3300 RECEIVER corresponding your RCA or Optic connection...
There you go..Your TV sound is on the
AVR-3300
Receiver..By this means whatever you watch on the TV (tuner, satellite , Xbox ) ,it's sound will come thru your stereo..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Mar 28, 2011 | Denon AVR-3300 Receiver
No sound regardless of input. front panel lights up and functions as per inputs however also noticed pwr supply fan and internal heat sink fan do NOT turn on. Any debugging tips appreciated! Thank You...
The power supply has to be on to some extent or it wouldn't light up.
http://www.retrevo.com/support/Harman-Kardon-AVR-335-Receivers-manual/id/386bh133/t/2/
Does it tune FM? That would indicate some life.
No sound? Is it Muted or a tape Monitor selected inadvertently?
Page 53: Reset the processor...
Processor Reset
In the rare case where the unit's operation or the displays seem abnormal, the cause may involve the erratic
operation of the system's memory or microprocessor.
To correct this problem, first unplug the unit from the AC wall outlet and wait at least three minutes. After the
pause, reconnect the AC power cord and check the unit's operation. If the system still malfunctions, a system
reset may clear the problem.
To clear the AVR 335's entire system memory including tuner presets, output level settings, delay times and
speaker configuration data, press and hold the Tone Mode Button (5) buttons for three seconds. The unit
will turn on automatically.
NOTE: Resetting the processor will erase any configuration settings you have made for speakers, output
levels, surround modes and digital input assignments, as well as the tuner presets. The unit will be returned
to the factory presets, and all settings for these items must be reentered.
If the system is still operating incorrectly, there may have been an electronic discharge or severe AC line
interference that has corrupted the memory or microprocessor.
If these steps do not solve the problem, consult an authorized Harman Kardon service center.
Jan 28, 2011 | Harman Kardon AVR 335 Receiver
How to connect the herman kardon AVR 260
I have a AVR 247 and a AVR 347 there is a HDMI output on the back this will go direct to your HD TV HDMI input. If you have a HDMI output on your SAT. box then run this to the receiver HDMI 1 input. If you dont have a HDMI output on your SAT. box, then you want to use the digital fiber optic output from your SAT box and run it to OPT 1 input on the back of the receiver. This will be for audio only from the TV but thats all you want anyways. Be sure to set your receiver to HDMI 1 OPT 1 for this option. PS. This is a very clean and nice sounding receiver the only flaw to these receivers are the amount of heat they generate even on very low volumes. You must get a 4 or 5 inch boxer 120 volt fan and set on top of receiver blowing down and plug it in the back of receiver on the switched plug outlet so it comes on when powered up. This will make your receiver last 10 times longer. i have had mine for 3 years now and run them very hard sometimes with no problems with this fan addition. Hope this helps good luck.
May 24, 2010 | Harman Kardon AVR 2600
Can you advise me as to where (in the uk) I can obtain the .47ohm fusible resitors please for my harmon kardon 335. I have chnged the capacitor that was S/cct
try this link http://www.rapidonline.com/Electronic-Components/Resistors-Potentiometer/Low-Ohmic-Resistors/4W-Low-ohmic-resistors/65206 its in uk
the order code you will need is 62-7108 for that store
good luck
Dec 19, 2009 | Harman Kardon AVR 335 Receiver
Hello
Kind regards
Andrea
Nov 09, 2009 | Harman Kardon AVR 335 Receiver
Need starchoice codes for Karman Kardon AVR 220
http://www.starchoice.ca/english/customercare/techcentral/remote_controls.asp
Look here for the codes to whatever remote you have. The chances are there arent any though. Harmon Kardon codes are a very unique signal that most remotes cant duplicate. More than likely you are going to have to use the original Harmon Kardon remote.
Oct 24, 2009 | Televison & Video
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
No television sound from denon avr-3000
TV has Component input (Green,Red,Blue) connect as follows:
1. Connect Component Video and Audio cables from the Cable box, PS3, DVD or Sat box to thea Component Video and Audio input on the Denon (TV/DBS, DBS,VCR1 VRS2, VDP or DVD).
2. Connect a Component Video cable from the Denon to the TV Component Video input.
3. If you do not have a cable or sat box and have a cable from the wall to the TV you must take an RCA(Red&White) audio out of the TV to an input listed in #1
Nov 21, 2008 | Denon AVR-2106 Receiver
I have a samsung cinema system rts he10t and a samsung lcd tv le32a556 and i am trying to get the sound from the tv to the cinema system i have a hdmi cable and the red and white phono cable connected but...
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Nov 17, 2008 | Audio Players & Recorders
No sound for TV AVR 786
Check cables, see if other audio sources work through audio input ports.
Apr 24, 2008 | Denon AVR-786S Receiver
Harman Kardon AVR 335 Receiver Logo
55 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
