Question about Craftsman Convertible 25cc. Gas Line Trimmer
I can't find a Model Number for a straight shaft Craftsman Professional Bushwacker 25.44cc gas trimmer that's been dicontinued?
The carb is a Walbro WYL 51 its engine family is WN4XS.0254RA and It only has a little white sticker with 1A 7577(98) , 805-4885342. It's a straight shaft with a on/off toggle switch by the half moon handle
  • 398 Answers
SOURCE: Need to replace entire head of Craftsman Bushwacker
there should be a little alignment hole where you can stick a small screwdriver thru to hold it from spinning then turn clockwise(its reverse thread). let me know if there isnt an alignment hole
Posted on Mar 26, 2009
SOURCE: have craftsman 32cc gas line trimmer it runs until given gas
Replace the spark plug, clean the air filter and fill the tank with new fuel at the correct fuel oil ratio. Had the same problem last year. Tried to cheat with year old gas.
Posted on May 10, 2009
  • 246 Answers
SOURCE: I need to know the gas mixture ratio for a craftsman weedwacker
Hello mcguilmd:
>>All Two Stroke Engines will use a 50 to 1 Ratio using Today's Two Stroke Oils. I once had an Old Chainsaw probably from the 1950s, maybe Earlier 70s that had a sticker on it that said to use a 25 to 1 Fuel/Oil Ratio, but that would have been using Two Stroke Oils of the Time Period the Chainsaw was Manufactured. I was having a Problem with Oil Coming Out of the Muffler and Started Decreasing the Oil in the Gas. I Reduced the Oil Until it was a t a 45:1 Ratio and Decided to be Safe, I would Use a 40:1 Ratio Mix. In that Chainsaw I used 50 to 1 Ratio with no problems. Today's Two Stroke Oils compared to Yesteryears are more Efficient at Lubricating. It is like comparing Today's Synthetic Motor Oil to Motor Oils of Decades ago. All the Equipment I use in Landscaping, anything from a Weed Eater, Leaf Blower, Chainsaw, Hedge Trimmer, use 40 to 1 ratio, and I use all types of makes and models, Stihl, Homelite, Husqvarna, Shindaiwa, and Echo, Sears. I mix up a 5 Gallon Fuel can and use it in all of the Equipment for my Customers and for my Landscaping. I like my Fuel/Oil Ratio a Little Heavy, so I use a 40:1 Ratio. The Following was Copied and Pasted here from and MTD E-mail to me when I Asked for the OEMs Suggested Mixture for this Unit. The mixture, as described by the engine manufacturer, is a 50:1 ratio when using the approved types of 2-cycle engine oils.
50:1 ratio is a mix consisting of 2.5 ounces of 2-cycle oil per 1 gallon of gasoline.
The 2-cycle oil used should be approved and have one or more of the following specification titles: NMMA TC-WII, TC-W3, JASO FB, or JASO FC. NOTE: If unsure of the 2-cycle oil specifications, or the oil is not approved, use a 32:1 fuel to oil ratio. This ratio consists of 4 ounces of oil per one gallon of fuel.
NOTE: Always mix 2-cycle fuel oil and fuel in an approved gasoline safe container prior to filling the engine. Make sure to use a separate gas can for this 2-cycle fuel mixture and label it accordingly. Keep in mind that the fuel capacity of these engines normally is less than a gallon, therefore you will have to use this extra oil mixture for multiple fuel fills. Adding a fuel stabilizer will also help to increase the shelf life of fuel.
>>I Suggest Using a 40:1 Ratio and if Oil Starts Coming Out the Muffler then go to a 50:1 Ratio.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 14, 2009
  • 41 Answers
SOURCE: Craftsman weed wacker trimmer head won't turn
it could still have the broken peice from the old one inside the seat.take it apart and look inside and inspect the seat where the drive cable enters.
Posted on Apr 14, 2010
panilling9
  • 284 Answers
SOURCE: Which fuel line "port/inlet" on the Walbro wt-380
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Posted on Jun 25, 2010
Craftsman weedwacker model 316711970
If you go to searsparts.com and put in your model number it will show you a drawing of your weed wacker. Not sure of what you are looking for. Hope this helps.
Jul 09, 2015 | Craftsman 29cc 4Cycle Straight Shaft...
Managemylife com sears
Check for spark if u have pour a small amount of gas in carb it should start also check air filter if runs then stops carb problem . Spray some carb cleaner then re try
Jul 20, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman owner manuals
If you go to searspartsdirect.com and put the model number in it will show you a diagram and on the page is a offering for the owners manual.
Jun 26, 2014 | Craftsman 29cc 4Cycle Straight Shaft...
How do I replace line?
With surgical clamp. Just remove the old line & filter. Push new line from the carburetor to the tank. Connect line to carb and cut to fit gas filter. A new filter ief you feel it's necessary. I just clean mine just once.
Aug 22, 2012 | Craftsman 29cc 4Cycle Straight Shaft...
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
I have an 18" Craftsman Bushwacker hedge trimmer
The wire into the handle may have been pulled and come loose. You will have to take the handle apart to check. They are simple.
Sep 28, 2017 | Craftsman Garden
Walbro WA219b carb
Go to www.searspartsdirect.com and with your model number you should be able to find explode parts views of that trimmer. Filtered line to primer, primer to straight inlet on carb, angled outlet on carb back to tank. That might work. Not sure without part number.
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
Mar 25, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Convertible 25cc. Gas Line Trimmer Logo
73 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
