Question about Sony Bravia KDL-37M4000 37 in. LCD HDTV
Audio fades and gets "fuzzy" every ten or fifteen minutes
It occurs on every channel. Corrects itself in a minute or less each time.
    Novelist:
    Scholar:
  • 67 Answers
You may want to try to re-autoprogram the television's channel memory. It memorizes and locks to the exact frequency of the channels you are trying to watch. The TV may be trying to fine tune the station until it locks to it, which may be causing the fuzzy audio.
Also, if the audio leveling or compression is on in the menu (the little music note icon in the menu is the sound options), then try turning it off. This compression may be reacting to the over-driven audio from the cable company.
Hope this helps. Give it a shot and post the results if you would like.
Posted on Jan 05, 2009
Shift key sticks on right hand side
It is time to replace your keyboard (it is affordable). eBay is a good source.
Mar 01, 2014 | Dell Latitude D505 Notebook
Menu pops on and off for about a minute when i first turn the tv on
the self diadnostic program in the tv is going bad.. may be time to replace the tv or dont shut it off completely
Jan 21, 2014 | Samsung LNT4665F 46inch 1080p LCD HDTV
Bose acoustimass 3 left channel fuzzy
Being Bose, the service department will require the unit back for service.
Jun 14, 2017 | Bose Audio Players & Recorders
I cant get my keyless entry to take a new code
TAKE THE BATTERIES OUT FOR TEN TO FIFTEEN MINUTES GIVE THE UNIT TIME TO RESET ITSELF REPLACE BATTERIES .If that dos`nt work get the owners user`s GUIDE
Aug 30, 2011 | liftmaster Chamberlain Garage Door Opener...
The car runs great but when I shut off the engine the fan continues to run. How can I get it to shut off?
The fan is controlled by a thermostat, it will (should) shut off by itself after a few minutes, after the engine has cooled down a bit.
If it continues to run after about ten or fifteen minutes (i.e., it does not shut off at all, and will run the battery down if you leave it overnight), then most likely the fan relay is sticking on, and should be replaced. Less likely is that the fan thermostat is bad.
But if it turns off by itself after about five minutes, this is normal and desirable, it gets some of the excess heat out of the engine.
Aug 23, 2010 | Jeep Cherokee Cars & Trucks
Rca d52w26 hdtv, work's fine for fifteen to twenty minutes. then screen fades away go's blank, the sound and channel's still work. help!
Replace the deflection board. You can get a replacement deflection board from www.tvrepairworld.com which also contains instructions on how to remove and replace the board.
Apr 16, 2010 | RCA R52WM24 52" HDTV Projection Television
The picture is very fuzzy (pixelated) when you first turn power o
this problem occurs usually in the power supply change or check the power supply borad
Dec 18, 2009 | Samsung LN-S3241D 32 in.LCD HDTV
Sharp Notevision XG-NV6XU
Looks like the wrong lamp was installed, or the cooling fan is not working. Careful - it may be permanently damaged, as the LCD inside can be hurt by high temperatures.
Sep 05, 2008 | Sharp Notevision XG-NV6XU Multimedia...
Sony bm-147
The unit will need service. The reel that is on the right is pulling the tape to hard. There is a clutch system that needs service.
Oct 18, 2007 | Sony BM-147 Desktop Cassette Transcriber /...
Sony Bravia KDL-37M4000 37 in. LCD HDTV Logo
76 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
