Question about Samsung SyncMaster 172N 17" LCD Monitor
Dead samsung 172n power light flickers
Green power light flickers.(60 cyles) ticking noise from powersupply. Disassembeld replace all out put capacitors on switchmode powersupply. did not fix.. disconnected the inverter circuit still ticks. any ideas? this unit uses the "top246y" switching circuit not much there to go wrong xcept a few zeners and 2 caps....
  • Rob Jan 03, 2009
    logic board ok with it dissconnected it still clicks.
    no the dc out put is not at 5 v / 13 v like its sposed to be
  • Rob Jan 04, 2009
    the switchmode powersupply ticks like its going into shut down/ protect mode. the output voltage fluctuate everytime it ticks. i have removed all power draw from the logic and inverter boards by removing jumpers from key circuits. The only thing i didnt mess with was the 5 volt section as it has the feedback circuit for the switching pwersupply.
  • 63 Answers
Have you checked the power output from the power board? Is it constant and steady? Try reflowing all the joints if you haven't already. Especially transformer and coil joints. Maybe a bad logic board? Do you have spares to try? Does it do this with everything disconnected from the pwr board (switch, logic, inverter)?
Posted on Jan 03, 2009
  • Chris McLellen
    Chris McLellen Jan 03, 2009
    What is the output voltage at if not 5v/13v. Is it jumping up and down? Or just nada?
Samsung has standby light, it blinks tone sounds no green light. Replaced t-con, power supply and control boards.
Hi Patrick,
have a close look at your LVDS cable and screen ribbons for signs of failure or heat damage, and you could try to pull a picture from an AV output in various formats to see if it's the screen itself is failing in some way,
Jun 29, 2016 | Samsung UN60D6000 60 Inch 1080p Smart TV...
Hi my samsung lcd tv model le40s8, it won't switch on when i press the power button on the remote the red light starts to flash and it makes a clicking noise and won't turn on
if you can do soldering work, replace two 1000uF10v bulging capacitor with 1000uF 16v or 25v in powersupply board. you will save $200.
Aug 17, 2009 | Samsung LN40A450 LCD TV
My dell desktop is just making a ticking noise and won't turn on
If it is beep sound the problem may be with the Ram. Remove the ram and refix it. If the problem not solved replace the ram
Jun 30, 2009 | Dell Dimension 4600 PC Desktop
TV will turn on for 2-3 seconds and then turn off
Unplug power cord- safety first!
open backcover
check powersupply- top center right is p.s.
top left side of powersupply you'll see 5 capacitor 3300uF 10V.
see any pop up on top? replace it All with same rate or 16v is O.K.
do not use temperature rate 75c. Use 105C.
if you know how to solder. you could save $300 at least! Mahalo!
Mar 12, 2009 | LG 50PC3D 50 in. Plasma Television
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Oct 30, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
Lens out, Camera on, power light flickers on and off
Hey kyla_peyton,
If this camera turns off during use it should mean either the batteries have gone dead or there is a malfunction in the camera. It sounds like you have eliminated the chance that this is a battery failure. There are many malfunctions in the camera that could cause this so I would have the camera looked at by an authorized service technician. I hope this helps!
Go Ahead. Use Us.
Jul 13, 2008 | Samsung Digimax S500 Digital Camera
Samsung SPN4235 42" Plasma
green light flashing no video but audio, on/off switch in operable
Nov 12, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Samsung SyncMaster 172N 17" LCD Monitor Logo
490 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
