Question about Canon LV-S3 Multimedia Projector
After power on 6-7sec...warning :(
Become noise... change cooling fan... now, after start, about 6-7 sec. when expect to light bulb turn on, got warning... must put out power cord... ...don't have remote, no option to get settings menu... is there anything i can do, to make it working again?
Remove c-24 errorminolta di450/500
Sir/Mam,
C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 14, 2014 | Minolta Office Equipment & Supplies
Tip
How to expand the lifespan of your projector lamp
One of the most frequent problems encountered is people replacing the bulbs with their bare hands. While this is fine for an ordinary light bulb, it is not a good practice for a projector lamp. The lamp in a projection unit burns much hotter than any regular light bulbs. The effects of touching it with bare skin are equally magnified and problematic.
Touching a projector bulb with the bare skin leaves traces of oil on the lamp surface. While this may seem a very minor detail, it is detrimental both to the bulb and the quality of the resulting multimedia display. The oils will get burnt onto the lamp and drastically reduce the lifespan. As the oil is baked into the surface, it actually diffuses the light being projected, reducing the lumens actually being sent to the refractive surfaces. The light will not be enough to project the image that has come to be expected from the home theater projection system. While the problem may not be noticeable at first, over the course of a little time, the quality will degrade to the point of not being viewable.
Turn off the projector power after turning off the lamp
It is highly recommended to turn the power on the projector to the "off" position only after having turned off the lamp and allowing it to cool. This will allow the cooling fans to do the job they were designed to do. While rapid cooling and heating result in repeated contractions and expansions of the bulb filament, it is much better that it be done more quickly with the cooling fans. Likewise, turning the projector on and allowing the cooling fans to run for a moment before turning on the lamp will help as well. This will add hours to bulb life expectancy and allow for longer hours of viewing pleasure on the home theater projection system.
Constant Movements
Constantly bumping or moving the projector, especially while it is hot can be very detrimental to the projector lamp. The filament in the bulb loses almost all tensile strength when it is heated during normal usage. It is much the same as the filament in a camp lantern. The principle is the same; the filament effectively becomes almost the same consistency as ash, making it extremely vulnerable to damage when it is hot. Even after proper cooling, the lamp filament is very sensitive. Care should be taken when moving the projector for whatever reason. While it is always a good idea to be careful with electronic equipment, some aspects of the home projector are actually a bit more sensitive.
It will usually be necessary to move the projector when cleaning the filters. As always, it is a good idea to move it carefully without jerking it around or bumping it any more than needed. Taking an extra moment or two to check the projector mount and make sure it is still securely fastened can also be beneficial and prevent slips and movement which may otherwise be harmful.
With a little care and a little preventative maintenance, the projector lamps will still need to be changed, but not nearly as often.
on Jul 21, 2010 | Computers & Internet
Power indicator /red/ and warning led/red/ are lighting after ea 15 sec. a lamp never start and fans goes in OFF mode. I checked power supply lines S5V,S-5V,S16V on the Main Board . I checked unit lamp...
If power indicator light red and warning indicator red flashing than according to user manual :-
The projector has been cooled down enough and the temperature returns to normal. When turning ON the projector the WARNING indicator stops flashing. CHECK AND CLEAN THE AIR FILTER.
Experience:- 1. if the temperature is very low than temperature sensor maybe misbehave.
2. If anyone fan not working
so please you check fans.
(If lamp or lamp ballast unit faulty than after a time period the lamp indicator light ON not a warning indicator. I experience many times if any fan in projector are broken or jamed the temperature light if present otherwise warning light ON or flashing)
Jan 20, 2011 | Sanyo PLV-Z4 Multimedia Projectors
Well my mom was watching tv and it just shut off so then my mom turned it back on thinking she might have hit the power button accidentally. But when she turns it on it started blinking the green light for...
The flashing light red power light should only stay while the fan cool down for about 1 minute after a power off (remember to always wait before unplugging the TV so the lamp can cool down with the fan). Does that flashing start right away after plugging back the TV after an hour of letting it without AC power.
The red light should flash no longer than 10 sec. This prepare the light to be turned on. If all is OK the green should stay (no longer flashing) and the sound and picture come on.
As for the lamp flashing, i bet it's only 1 time each 5 sec? Or do it group many rapid flash each 5 sec?
Things that can be wrong:
-the fan lamp
-the lamp is not proprely inserted (wait an hour before manipulating it to be sure it cooled down, and use glove to not put body oil on it).
-Lamps is defective and is not operating properly so you can't get to the usual on screen message that recommend to change the lamp.
Sep 02, 2010 | Panasonic PT-60LCX64 Television
BenQ DX 650 Won't power up making clicking noise
Those units are designed to be fan cooled after the bulb shuts off. When the cord was pulled, the unit lost power and without the fan, sat there and cooked. Could be a thermal fuse, could be the bulb.
Mar 10, 2017 | BenQ DX 650 Multimedia Projector
It makes a wierd noise
The bulb housing has come loose...
When the bulb heats up & cools in normal use, the housing will contract and become loose.
Unplug and re-seat the bulb and housing ...
Another possibility: If the replaced bulb shattered in the projector, there may be debris in the fan... use compressed air ($8/can RadioShack) to clean out (make sure the projector / bulb are cool before using compressed air.
Hope this helps!
Sep 09, 2009 | InFocus ScreenPlay 4805 Multimedia...
When I turn on my EP7120 it starts to warm up and then the 2 warning lights come on automatically. (Red bulb and overheating light) I turn it off and let it cool but when I turn it on the red lights come...
Is the cooling fan working? (If not, then that's the problem).
Check that the intake grid for cooling is not blocked with dust and that it has adequate room to draw in air.
Mar 17, 2009 | HP Ep7120 Multimedia Projector
Read replace lamp then afew weeks later heard pop noise and now black screen
Two things in your TV can make that popping sound. One is the bulb of course and the other is a capacitor. Have you pulled out the bulb to inspect it? My guess is that you have broken glass in the cooling fan, which is why there is a grinding sound. Most bulbs tend to contain the glass from getting everywhere as it's only the filament inside that pops creating little diamond looking pieces inside the lens. If a surge was strong enough or if the bulb was poorly manufactured, the whole unit can explode inside spraying glass everywhere.
If the bulb looks fine, the pop must've been a capacitor on one of your circuit boards resulting in no display. Since the TV still powers on, your power supply and it's fuse appear to be fine. Check the bulb first and go from there.
Oct 17, 2008 | Panasonic PT-60LCX64 Television
Canon LV-S3 Multimedia Projector Logo
43 people viewed this question
old marine
old marine
