Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Green Light on Mitsubishi WD-62525 keeps blinking
After a power outage the green light keeps blinking but the TV won't turn on. Tried the reset button but still won't come on. The manual states that the Timer is Locked. Does anyone know how to UNLOCK the Timer? The bulb was already replaced and still looks good. Any other suggestions?
  • 2 more comments
  • grandma22 Jan 03, 2009
    Same problem. After a power outage the green timer light keeps blinking and the tv won't turn on or off. I unplugged, I reset, no luck. Now it will blink and buzz at times. What's UP?
  • duke714 Mar 23, 2009
    Blinking green light of death! Use to be able just rest or pull the plug, but today it just won't go away! 5000 dollars for 3 years and died right after warranty. Never going to buy a damn Mitusbishi anything from now on!
  • Anonymous May 06, 2009
    I had a power failure and the green light keeps flashing and I can't turn my set on? I have pushed the reset button and I have unplugged the TV and plugged it back in, it just keeps blinking.
  • Cactus Jake May 18, 2009
    SAme here....power got turned off; and now the green light is blinking and the TV will not work; no matter what we do.
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
Posted on Feb 09, 2010
  • 179 Answers
If the timer light is blinking slowly then the timer is on, and the set will turn on normally when the power button is pressed. otherwise it is the chassis not booting up. checkout www.tv-techs.com.
Posted on Jan 04, 2009
  • 3 Answers
After you plug in, press the reset button and wait 60 seconds. You can call Mitsubishi direct. They are very nice and when our lamp went out after about 1 year, they sent a new one free, overnight! We did have it repaired once, at about $750, that was mostly for them to come get it an bring it back. I still thought we could not get a new one for the price. Unfortunately, when you spend a lot on something, it seems to be expensive to repair as well, just like a cadillac or bmw or volvo! But then, you get what you pay for. Something great or something cheap and replacable?
Posted on May 07, 2009
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525, continous amber lamp light. No picture. Lamp is good.
Hello:
Make sure u replace the lamp cover as the safety switch need to be closed to make the set work. If new lamp did not repair your problem , then it may well be the Ballast Board, Sometimes call the Lamp Driver.
Nov 28, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Flashing green light on Mitsubishi WD- 62527 TV
how time dose the light blinking was your pix
dark if so you need a lamp@powersupply for lamp. hope this help you out,
Aug 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
The TV wouldn't turn on...no power
sounds like you have a bad flyback in your set
Dec 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a 62 inch mitsubishi dlp model#wd-62525 serial#125902 , tv will not power up it has a flashing green lite below the timer button that flashes,i have try the reset button but it just starts blinking...
if the light just constantly blicks green and doesnt stop. You will need the" V26 DM repair kit " which will usually repair that issue. You can get the repair kit at the following link which includes the replacement capacitor and instructions
http://servicemanuals.vstore.ca/
Sep 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
TV was working earlier, today came home no green power light no nothing
I looked up the manual online - after you replace the bulb, you need to reset the bulb life timer. Using the TV remote push the menu button, SETUP menu, select the lamp reminder option to reset the hours to zero. That might help the status indicators.
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd 62525 chassis
I was told there was a bad batch of capictors so we reaplaced all of them and still the blinking green light ,and no tv still help bagelbaker77@yahoo
Jun 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
5,992 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
