Question about Alpine Kce-104v Input/output Expansion Unit For Cva-1004
I don't have the right wire harness for kce 104v but need to know how to connect wich is ground and wich is the positve and so on
    Master:
  • 444 Answers
Go onto google. Type the brand end model number into the search box. There are site where you can down load manauls for no charge.
Posted on Oct 27, 2012
Head lights, tail lights and dash lights don't work. inside lights, brake lights, and back up lights do work.
need so check ground wires. start at your head lights and fallow the wire harness til you see a wire grounded to the body. check and make sure connections are good and that the wire isnt broken anywhere
Mar 23, 2013 | 1994 Dodge Caravan
I don't have a grounding wire and don't know what to use!
You can attach a wire to the metal part of the turntable and screw the other end to ground screw on the amp.
Mar 05, 2012 | Philips gemini XL-500 II Turntable
I need to know what the wiring harness wires do and go to by the colors of the wires. Example (yellow=12v constant/Red=12v acc/ Black=ground)
OK, I assume you are talking about the harness of wires from the radio itself. If you are going to install this, I recommend you purchase an install wiring harness. This way you can plug into the factory harness of the vehicle. If you are attempting to hardwire the radio, please don't. If you vehicle doesn't have the factory vehicle side of the harness, try visiting the scosche or PAC website to see if they have it first. If you purchase a wiring harness, it will have all the information for the right install. Hope this helps.
Sep 05, 2011 | Car Audio & Video
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
Need to know if i can hook the ground or negative side together and just run the l positve and right positve with seperate wires
No. Using a search engine look for "speaker wiring" and find something that looks like what you're contemplating (which is not crystal clear). Then try to find something in the amplifier manual that blesses it. Hint: it's not there. Each speaker should have one Plus and one Minus from the same amplifier channel.
Jul 29, 2011 | Onkyo TX-SR606 Receiver
I am trying to wire a 7 pin trailer arness to my dodge ram 2500,the harness has a dark green,yellow,green,green/white,brown, red and 2 black wires. the truck doesn't have the 2 black wires and the red...
Go to napa and they have the connectors that plug in to your existing wire connection, I don't know if they have the one for yours, but it won't hurt to check, you don't have to cut or splice the wireing with there trailer connectors, plug it in and done.
May 21, 2011 | Dodge Ram 2500 Cars & Trucks
We are replacing the fuel filter in a 98 pontiac transport. The new wiring harness came with a purple, grey & 2 Black wires. The OE harness comes with purple, grey , black and a white/black. How do you...
Assuming you mean replacing the fuel PUMP, the 2 wires are different guages. Connect the lighter wire to the lighter wire and the heavier wire to the heavier wire. If the new harness uses both the same size wires, the heavier wire on the vehicle side (solid black) is for the fuel pump ground. Lighter wire is for fuel guage sending unit.
Sep 21, 2009 | 1997 Pontiac Trans Sport
I`M REPLACING THE ORIGINAL RADIO ON A 1996 GMC JIMMY, I NEED TO KNOW WICH WIRES ARE WICH, (ALL THE POWER ONES) OLD RADIO NOT AVAILABLE
PLEASE RATE MY SOLUTION, THANKS.
1996 GMC Truck Factory
Stereo Wiring Chart
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Mar 08, 2009 | 1996 GMC Jimmy
Problem with factory radio
you probly need a wiring harness....if this is the first aftermarket cd player in the truck... go to car audio place round town and ask for a wiring harness for your model truck....the wires will then be color coded.....hopefully this helps
Jan 26, 2009 | Car Audio & Video
I need installation instructions for a MTX thunder 280
BATT = 12v positve constant
GND = 12v negative or ground
REM. = 12v positive switched or remote wire.
The remote wire is most commonly found on aftermarket CD players. It's typically in the main wire harness. The most common color of this wire is blue with a white stripe.
Jan 20, 2009 | MTX Thunder 2-Channel Amplifier 282 Car...
Alpine Kce-104v Input/output Expansion Unit For Cva-1004 Logo
41 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
