Question about Maytag Atlantis MAV7260B Top Load Washer
Washer does not turn or spins
I have a maytag washer(LAT8426AAE) top loader THAT DOES NOT TURN OR SPIN. I can hear the belt squealing and smoking. It goes thru the whole cycle...please help
    Sergeant:
  • 311 Answers
The pumps and motor pullys go bad on those.tip washer back against wall and inspect there.motor pulley melts ,the pump pulley breaks loose from its spot welds and then will rub metal to metal.when ordering parts replace belt too if damaged.if worn wont get a good spin and then dryer has to work over time.[power bill up.up,up.thanks for using fixya.God bless,tom
Posted on Jan 03, 2009
Washer squealed, gave off black smoke in spin cycle
For sure change the belt. Clean the pulleys with a solvent to remove anything oily or like melted belt. The machine probably was overloaded. If it's a front loader, check the bearings.
Nov 24, 2013 | Washing Machines
Loose belts on Maytag Washer LAT2300AAE
It is normal for the belts on this model to be loose. Normally the noise that you are hearing is either the damper (a white plastic type material,comes in a kit) or the pump making the noise. Take the belt off the pump and put it into a spin cycle and see if you hear it. If so ck the tub bearing for rust or leaking and the damper for wear. If you don't here it, ck the pump.
Mar 04, 2013 | Maytag MAV4755A Top Load Washer
My Magtag Neptune TL 6800 started making a horrible squealing noise then smoke started coming out of the washer. What do you the problem may be?
You need to replace the belt needed to spin the drum. It sounds to me like you may have been overloading the drum, putting too much stress on the belt. Over time, it has begun to " burn rubber" as it spins, causing smoke, or worst case scenario, the motor that turns the belt is locking up as the drum spins causing friction on the belt.
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Smoke when running.....smells like rubber....washer is top load.....about 13 years old....model LAT8426AAE...HD 2 speed....9 cycle. Belt shot?
Its possible. This one has two, located underneath. Lean the machine back to check them. Make sure all pulleys turn freely before replacing them
Jul 14, 2011 | Maytag Washing Machines
Maytag belt problem
Sounds like a partially seized component. The belt will work under average load, but when it reaches spin cycle where it must run at high speed it may be encountering too much resistance from the component that it is spinning. Was there a whining or squealing sound? Did you notice any smoke or odour? Perhaps a failed bearing may be to blame, or an errant piece of clothing. My machine is a Maytag front loader and I can easily turn the drum with my fingertips. I don't know what machine you have, but basic mechanics tells me that the motor is spinning and the piece the motor is trying to spin via the belt is resisting. Hope this helps. Cheers!
May 19, 2009 | Vic Tokai, Inc. Trouble Shooter for Sega...
Maytag washing machine is locked up and will not spin.
Sounds Like The Belt If Inclined Remove The Outer Case Front And Replace Belt Of Equal Size From Any Auto Parts Store.
Jan 05, 2009 | Granberg Bar Mount Chain Saw Sharpener,...
Hi..i have a maytag top loader washers that won't turn or spin...can hear belt squealing and smoking
tip machine machine back now access belt should have motor pulley, pump pulley and middle big yellow thrust bearing,, usually pump is broken
Jan 03, 2009 | Maytag Atlantis MAV7260B Top Load Washer
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Open Questions:
Maytag Atlantis MAV7260B Top Load Washer Logo
257 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
