Dell 2335DN fuser problem.
I have a Dell 2335 DN that shows fuser not installed even thou it has a new fuser installed.
5 Suggested Answers
macminiguy
  • 34 Answers
SOURCE: show me how to replace a fuser in a dell mfp 1815
Pull down the rear door. There should be 2 screws on either side.....remove them....look for 2 more screws towards the bottom. Remove them....the entire rear plastic of the machine should pull off...exposing the fuser. Remove the screws holding the fuser in place. Pull the connectors from the power supply below and you should be able to pull the fuser out! If you need a fuser you can get one at www.getthatpart.com they have good used fusers at good prices....you can also call them at 410-374-1261
Posted on Oct 25, 2010
Testimonial: "Thank you, this will allow me to fix it today, not wait a week and all of the added expense! Again thank you."
SOURCE: fuser error in dell 5330
Replace the fuser lamp and the thermistor.
Posted on Nov 08, 2010
StevenC82
  • 160 Answers
SOURCE: fuser error
Hey, if your Dell 2335DN has a fuser error or low heat error first try cycling the power (powering off and back on the machine). If this doesn't fix it, you should replace the fuser (part# KW449). Here is a video showing how to replace it and where you can purchase one. Good luck!">
Posted on Mar 11, 2011
StevenC82
  • 160 Answers
SOURCE: I have a Dell 2335dn,
Make sure the fuser is seated correctly and cycle the power (turn the machine off and back on). If the error continues try replacing the fuser (part# KW449). Iteminc has this in stock and ships same day. Here is a video that shows you how to replace it. Good luck, and thanks for using FixYa!
Posted on Aug 22, 2011
How do you reset maintenance count on a dell 3130?
You don't. You can't.
When you install a replacement Transfer belt (it has it's own counter chip) that resets the transfer belt pagecount, and as a result clears any transfer belt life related warnings/errors.
When you install a REPLACEMENT Fuser (that has it's own counter chip) that resets the fuser pagecount, and as a result clears any fuser life related warnings/errors.
PLEASE NOTE - The fuser supplied with the DELL 3130 when new DOES NOPT have a counter chip - the fuser life warnigs are triggered by the printer pagecount. Installing a fuser from another printer (even if it has a ZERO pagecount WILL NOT reset the fuser pagecount (because the 'ship with' fuser has no counter chip.
Aug 27, 2014 | Dell 3130cn Color Laser Printer
Reset fuser on Xerox phaser 7760
You don't need to reset it it. It should automatically reset with no problem you can try to clear the NVRAM . Careful because you will lose all the information you have stored in it like any IP address or specific settings. What it will do is bring the printer to"factory default settings. You can do it in "service diagnostic mode. goodluck
Feb 19, 2014 | Xerox Corporation 7760/Dn - Xerox Phaser...
Removal of paper stuck in a dell 3115 fuser?
It's best to remove the fuser to get access to it. This video will show you how to remove it, and which levers to move to release tension in the pinch roller to clear the jam http://www.youtube.com/watch?v=UjyggtF8d1k After you remove the jam make sure to do a close inspection on the internal roller (use a flashlight). You're looking for any scratches or "dents" in the colored roller (sometimes a deep red/brown color sometimes blue) if there are scratches you are probably going to have to replace the fuser. The imperfections on the fuser roller will show up on your printed pages. If you do need a new fuser you can find them for $160, or the entire rebuild maintenance kit for $375 http://www.fastprinters.com/productdetails.asp?PRODUCT_ID=DELL-UG190
Dec 19, 2013 | Dell Printers:Dell MFP Color Laser 3115cn
Dell 2335 problems
There is a Brother Solutions Page for that
Nov 06, 2013 | Brother MFC-5840CN All-In-One InkJet...
0500H Fatal Error
Witam,
0500H Heating roller warm-up failure:
The thermistor /1 does not detect the specified temperature and the warm-up cycle is not completed even after the lapse of a given period of time after the cycle has been started.
Relevant electrical parts
Fuser unit
Printer control board (PRCB)
DC power supply (DCPU)
Solutions:
1 Check the fuser unit for correct installation (whether it is secured in position).
2 Check the connector between fuser unit - PRCB PJ9 for proper connection and correct as necessary.
3 Check the connector between fuser unit - DCPU CN2 for proper connection and correct as necessary.
4 Change fuser unit.
5 Change PRCB.
6 Change DCPU.
Mar 12, 2013 | Konica Minolta Magicolor 3730 Dn Color...
Fuser error in dell 5330 dn
Nov 08, 2010 | Dell 5330dn Laser Printer
Show me how to replace a fuser in a dell mfp 1815 dn printer please
Oct 25, 2010 | Dell 1815dn All-In-One Laser Printer
Need to clear all data from printer
Information is here, under maintenance section of manual
http://support.dell.com/support/edocs/systems/2335DN/en/index.htm
Mar 21, 2010 | Dell 3100cn Laser Printer
ERROR CODE 010-387 RESEAT FUSER
I had the same exact issue with my 5110cn printer. It turned out that the 5100 fuser is wrong for this printer and will not work. The 5110 has a circuit board on the inside and the 5100 fuser does not. Dell item number KX491 with a BCN # of 652423 works perfectly.
Hope this helps!
Jan 08, 2009 | Dell 5110cn Laser Printer
Burn paper, and show open heat error
It is most likly a problem with the Fuser. If you are under warranty contact Dell. If not, replace the printer. The cost of a fuser plus the labor to install it is usually more than the cost of a new printer. Plus that printer is end of life, so the part may not be available
Dec 08, 2008 | Dell 1600n All-In-One Laser Printer
jasbo
jasbo
