Question about MSI MS-9105 (MS-9105-030) Motherboard
Msi ms-9105 dvd boot
I cannot set the BIOS [tried the obvious boot order changes] so that my OS DVD will boot-get error message about failure, or other error. Even XP Pro will not boot. Could the attachment of the DVD drive affect the boot? DVd now attached to a PCI card slot via a SIIG card. DVD plays movies no problem. I am using Ubuntu 10.04 LTS.
  • MSI Master
  • 3,606 Answers
Hello the best way to troubleshoot is to look in the manual
download here:
http://www.msi.com/product/server/Pro266TD-Master.html#?div=Manual
The file needs to be unziped before you can read it.
You also need a pdf reader (adobe) to read content.
If other files needed select in the download box.
Good luck
Posted on Nov 15, 2012
    Problem Solver:
  • 8 Answers
Well first off, the bios is probably going to only look for dvd drive through sata or ide not through a pci slot. and its very tricky formatting a bootable cd and getting it to run, i would suggest, if you are savy enough, to connect your hard drive to another computer and manually add boot files there instead of to the dvd, thats what i had to do one time
Posted on Oct 26, 2012
  • 86 Answers
SOURCE: cmos checksum error after flashing the bios
I had a similar experience after upgrading my RAM. When you reset your CMOS and have default settings maybe you should check if your RAM timings are correct. I could not get mine to load with both sticks in until I fixed the timings from the default settings.
Posted on Jan 20, 2008
  • 33 Answers
SOURCE: MSI k8ngm2-h mobo doesn't recognize PCI-E slot anymore!
Just a suggestion for you to try.
This is to check whether your PCI-E card is ok or not.
The BIOS setting option should be on PCI Express.
Take out the power cable from the hard disk - we don't want to mess around with window driver or system that might be the culprit.
Now turn on the computer, if ok, you should see some texts on your screen. This is a confirmation that your PCI-E card is still working. So then for you to work on your windows to solve the problem. Good luck.
Posted on Feb 19, 2008
  • 254 Answers
SOURCE: Problem installing Windows 7 on MSI KM4M-V
Id say with those specs Id be sticking to XP mate , win 7 like vista munches resources and without them it can be a pain
it maybe time to shout your self an upgrade , plenty of bargains at the moment.
hope this helped
Posted on Feb 04, 2009
Nic61
  • 1073 Answers
SOURCE: MSI motherboard - SATA Hard Drive
Hi again!
Here is the manual, the drivers and everything else there is abut that mobo of yours.
http://global.msi.com.tw/index.php?func=downloaddetail&type=manual&maincat_no=1&prod_no=152
You need to change the settings in the bios, the settings how your motherboard reads the disks. You will find it in the manual-
Good luck
Nic
Posted on Mar 16, 2009
naebarbat
  • 508 Answers
SOURCE: MSI 848P NEO-V: PCI bus - no drivers for real time clock
try to reinstall your driver from here:
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=582
Posted on Jun 05, 2009
NEC laptop will not boot from disk or USB
just make sure ISO files or DVD you are using to boot with are actually bootable disc for OS ,as for USB booting ,you will need to turn on usb boot on the bios and software needs to be USB software.
and I am not talking about boot order that you have already selected.
check windows 8 software on anther machine and see if you can boot with it
Jan 18, 2013 | Computers & Internet
Pxe -e61: media test failure, check cable PXE -MF: Existing PXE Rom Operating System not found How do i resolve this error message? How should i resolve & trouble shoot?
Welcome to fixya.
-The first thing to check is your boot order in the BIOS.
-Unplug from power, remove battery wait a solid 5 minutes and try again.
-Go into the BIOS and choose the Default settings (press F9 to set defaults then F10 to save and exit).
-It sounds like it can't find a hard drive to boot from so it's looking for the Network to boot from.
-If you have an external CD/DVD drive try to boot your OS from that (after changing the boot order).If it did not work then there is a big chance that the problem is a failed hard drive.
Jul 26, 2011 | Dell Inspiron Mini 9 Notebook
I have no idea if I'm even in the right ball park, but anyways, I have a Pentium 4 3.0 Ghz laptop that on the top cover says Syntax, on the bottom it says Model No. GREEN736 Serial No....
Going from No wifi connection to reinstalling windows is a big difference in time and maybe documents. If your sure you can't boot and want to reinstall xp the best would be to go into your bios. Its F12 or whatever on your machine just so you get to the bios. There you can select a certain amount of memory that you have to be partioned. Simply all would go for your xp installation. With the xp disk in the drive turn on the machine and it should boot to the installation. If it doesn't your boot order is incorrect meaning the machine is trying to boot from the hard drive and you want the machine to boot from your dvd drive. So in the bios you have to make sure the default boot at least temporarily is the dvd drive. When in the bios that is real simple to change.
With the computer instructed to boot from dvd drive and disc in the dvd drive it will jump to the installation of the xp pro. If you have any questions come back with another and you should get a response as this is a fairly common question
Apr 06, 2011 | Syntax Computers & Internet
Invalid disk system will not leave screen
that error happens when you have a nonbooteable unit inserted or when your OS master boot record gets damage and the bios doesn't find the OS boot up loader.
check in the bios the boot order settings
usually is like this
1 - Floppy
2 - Cdrom
3 - HardDisk
4 - Network
there can be more options but those 4 are what we care now. change the order in what the system checks for a boot media
like this
1 - Cdrom
2 - Harddisk
=============== place any other device in any other after # 2
If you still get the message then make sure that you laptop has a OS installed ( if it has one already) then try to repair the MBR (master boot record) using the os install cd and the recovery console ( applies to Windows XP, Vista, 7 ).
Otherwise Install a operative system in the laptop and that should take care of the message.
Mar 02, 2011 | Fujitsu Siemens AMILO D-7830 Notebook
Pc keeps rebooting and wont even go to safe mode
the os on the harddrive is not recognising the hardware and could be caused by change in bios settings or bad os.
Jan 24, 2010 | Dell Dimension 8200 PC Desktop
Error loading o.s windows xp
If you want to try booting from safe mode, start the machine and press F8 until you get a boot menu, but you getting the 'Error Loading OS' message sort of suggests your relative may have wiped the harddrive before handing the machine off to you, which would mean there will be nothing there to recover from.
Sounds as if the PC is set to boot from the harddrive, so your easiest fix would be to get into the bios settings at startup and set your 'boot order' to read from your optical drive (cd or DVD) first- Put YOUR copy of XP in and away you go!
Another option would be to go to bootdisks,com and download a Win'98 boot floppy image with CD-Rom drivers, & unzip the image to a 3.5 floppy, but that's the long way around.
Oct 07, 2009 | Famous Brand Dell Optiplex GX280 Intel...
Boot failure self HDD test #1-7 XP PRO.
Hi this Alex You can use Ntfs for dos programm which allow you to access ntfs partions on while dos loaded. then you will be able to get you data copied
Sep 23, 2009 | HP Pavilion dv4000 Notebook
I'm getting a PXE-061: Media test failure, check cable. message what do I do?
That message means that the machine can't find any OS on the local drive, so it's trying to boot from the network, and no network cable is attached.
The most obvious possiblities are:
1) There is no OS on the HDD
2) The HDD is not installed or not installed correctly
3) The BIOS boot order has the network boot before the HDD
Jul 04, 2009 | Computers & Internet
Problem loading an OS onto a Dell XPS One 2010
YOU NEED THE BIOS UPDATE FOR THAT ,,GET IT FROM A ANOTHER CPU ,,BOOTABLE DOWNLOAD,,PUT IT ON THE DELL ,,THEN XP,,CHECK THE DELL WEBSITE
May 15, 2009 | Computers & Internet
Installing XP on a PCI SATA Card
hey change ur boot order in bios.....
put dvd/cd drive 1st...
May 30, 2008 | ASUS P4S800-MX Motherboard
MSI MS-9105 (MS-9105-030) Motherboard Logo
311 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
