Question about Samsung ML 2010 Laser Printer
Printer does not take paper from the tray
Hi, Printer does not take paper but it gives the sound of printing, i have samsung ml2010. it worked untill last week. Your help will be appreciated. Thanks, Raj
  • Raj Kal Oct 19, 2007
    I am not able to remove the removable rod.
    Genius:
  • 2,985 Answers
Try this Take out paper tray. Remove Toner cartridge Stand printer on its back so that you can see the pick up wheels/roller They should/could be on a removable rod/axle Pop it out and give a gentle rough up with a fine emery/nail board Re assemble - make sure the rod/axle is snapped it tight and correctly linked up re plug in - try it out. Failing that check the makers tech help on the web site.
Posted on May 14, 2007
  • john ash
    john ash Oct 19, 2007
    Try doing it in the machine if this model is fixed.
    or as stated contact the makers web site
PAPER JAM ML2010
May be it is your toner problem try toclesan it nd also change it.
If roblem still occurs then servece your printer and clean its pars with iso propile.
Sep 15, 2008 | Samsung ML 2010 Laser Printer
Paper stuck - Samsung ML2010
Clean the roller with 409/simple green or water. Use a cloth not paper towel. NO alcohol. Rub it up good and it should start feeding. steven 818-888-0006
Apr 27, 2010 | Samsung ML 2010 Laser Printer
My Samsung Ml2010 does not pull the paper
check your paper tray is properly inserted in it. or any papaer jam problem may be.
Sep 30, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 Printer does not receive the Paper
Make sure you have put enough paper in paper tray. Printer will not pull paper if not enough. (more than 10 sheets) hope it works. : )
Aug 10, 2009 | Samsung ML 2010 Laser Printer
Samsung ML2010 printing blank pages after toner replaced
Reputable or not, every once in a while you get a bad one (even originals). It's obviously defective. Return for a replacement
May 19, 2009 | Samsung ML 2010 Laser Printer
Paper jam in tray 1
Hi glenpcr,
I had the same problem and solved it.
At my printer it was a problem of the MP-tray (multi purpose tray).
There are two hinges which keep the open MP-tray in a horizontal position. One of this hinges was broken and I just received it.
Just try it.
regards,
Stephan
Feb 10, 2009 | Samsung CLP-510 Laser Printer
Printer ML2010 not responding
LED pattern Possible Problems and Solutions
Your system has some problems. If this problem occurs,
contact your service representative.
On Line/Error LED
lights red
• Paper jam occurs. To solve the problem, see “Clearing
Paper Jams” on page 5.6.
• The front cover is open. Close the front cover.
• Paper tray is empty. Load the paper in the Tray.
• The toner cartridge is out of toner. Remove the old toner
cartridge and install a new one. See “Installing the Toner
Cartridge” on page 2.4.
• You pressed the Cancel button while the printer is
receiving data.
• In Manual Feed mode, there is no paper in the manual
tray. Load paper into the manual tray.
• If the printer is receiving data, the On Line/Error LED
slowly blinks green.
• If the printer is printing the received data, the On Line/
Error LED blinks green fast.
Jul 15, 2008 | Samsung ML 2010 Laser Printer
Printing jammed on thicker paper
See the manual. It looks as if 120g/m2 is the heaviest paper it can use:
"Set Type to correspond to the paper loaded in the tray from
which you want to print. This will let you get the best quality
printout. If not, print quality may not be acheived as you want.
Thin: Less than 19 lb (70 g/m2) thin paper.
Thick: 24 lb to 32 lb (90~120 g/m2) thick paper.
Cotton: 20 lb to 24 lb (75~90 g/m2) cotton paper such as Gilbert
25 % and Gilbert 100 %.
Plain Paper: Normal plain paper. Select this type if your printer is
monochrome and printing on the 16 lb (60 g/m2) cotton paper.
Recycled: 20 lb to 24 lb (75~90 g/m2) recycled paper.
Color Paper: 20 lb to 24 lb (75~90 g/m2) color-backgrounded
paper."
Nov 22, 2007 | Samsung CLP 300 Laser Printer
Samsung ML 2010 Laser Printer Logo
116 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
