Question about Mitsubishi WS-65909 65" Rear Projection Television
Ws-65909 power light goes out after 3 seconds no sound or picture
Self check gave 2 blinks and 2 blinks
  • Mitsubishi Master
  • 8,617 Answers
Thats the code which normally indicates a convergence failure you can get the WS55909 - WS65909 Convergence repair kit which also has instructions from www.tvrepairworld.com its listed under the Mitsubishi repair kits catagory.
Posted on Oct 27, 2012
  • 126 Answers
SOURCE: powers on for three seconds then goes off
The first thing to do is to try to determine why the set is not turning on. It is equipped with a self diagnostic feature. On the front of the set push the MENU and DEVICE button at the same time and hold until the LED starts flashing a two sequence code. That will narrow things down for us.
Posted on May 05, 2009
  • 126 Answers
SOURCE: We have the dreaded blinking green
The Digital module must be repaired. It is not booting up. When first plugged in the LED in that set will blink for 70 to 90 seconds. That is the amount of time it takes for the digital module to boot up. If it continues to blink past that time the module is belly up and needs to have some capacitors changed in it. Most reputable shops can do this in your home and average cost is between $150 and $250 depending on where you live.
Posted on Jun 11, 2009
SD Tech
  • 14553 Answers
SOURCE: Mitsu WS-65909 COMES ON AND TURN OFF IMMEDIATLY, ERROR CODE 2-2
Two blink code on this set means Usually one of the two pico fuses that protect the STK-393-110 CONVERGENCE IC is blown--the fuses will need to be tested and the chip and them replaced--
If you have enough skill I have step by step start to finish instructions for this repair in this set---set detects one of the voltages to the Chip is not there and shuts down instantly. I have photos of the chip, fuses and protect resistors this set uses also.
If you want the instructions for free give me a email and I will send them to you for free--if you are able to do this repair yourself you will save a lot of money--you can buy the chip on Ebay for about 14 dollars plus shipping and the same seller sells the pico fuses..............
If you want to attempt this give me a vote here--If you are not able to do it yourself I have suggestions for you about getting the set fixed--I have done hundreds of these sets!
Just reply to this post here.
Let me know what you want to do, I am here to help people
SD TECH
Posted on Sep 19, 2009
Testimonial: "This is what I thought from reading your other posts, please send me instructions. mchamber5@yahoo.com Thanks"
SD Tech
  • 14553 Answers
SOURCE: I have a mitsubishi ws-65909 - flashing 2,2. Can
I have this information but it is too large to post here.
Let me know by rating this solution and I will find a way to give you the instructions.
SD TECH
Posted on Nov 13, 2009
SD Tech
  • 14553 Answers
SOURCE: mitsubishi diamond WS-65909 WILL NOT TURN ON
Are you getting the 2,2 blink code?
If you are I am the one you want to talk to.
I have repaired hundreds of these sets and know them very well.
Let me know and I will assist you.
If this has helped you rate this solution as I do this here for free.
SD TECH
Posted on Dec 20, 2009
Testimonial: "THANK YOU WILL TRY TO LOCATE FUSE"
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
I have a mitsubishi ws-65807. I have no picture or sound. It used to work.
try the self check this model has, try to turn set on and when green power light comes on and goes off press and hold both the menu and input buttons on the front of the set at the same time for at least 5 seconds and then release both buttons.
This is a self-check this model has----the power light will then blink a two digit error code like 2 blinks, 2 blinks, a pause and then repeat it several times.
The idea here was to narrow down what area the problem is in.
Let me know with a comment here and I will tell you what the error code you found means.
SD TECH
Apr 12, 2011 | Mitsubishi WS-65807 65" Rear Projection...
"on" light flashes twice and then "blacks out"
IF power light comes on and a few seconds later goes off, do the self check this model has.
On front of set when this happens, press and hold both the menu and input (device) buttons at the same time for at least 5 seconds and then release both buttons.
Watch the power light closely, it should blink a two digit error code like; 2 blinks, 2 blinks, a pause and then repeat it several times.
Let me know what error code you find and I will tell you what it means.
SD TECH
Dec 11, 2010 | Mitsubishi WS-65909 65" Rear Projection...
The t.v will not stay on after being on for about 5 seconds.
do the self check model indicated has.
when power light comes on and then goes off: On front of set press and hold both the menu and input buttons in at same time for at least 5 seconds and then release both buttons.
Power light will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
This will indicate what kind of problem set has.
SD TECH
Oct 22, 2010 | Mitsubishi WS-65909 65" Rear Projection...
I have ws-65909 65 in TV , The power went out and now the timer light is blinking and i can not reset it.
Unplug it for 2-3 hrs. then when you turn it back on again, be sure to reset the sleep timer to "off".
Sep 08, 2010 | Mitsubishi WS-65909 65" Rear Projection...
Our tv comes on and then the picture goes dead
WS-65807 has a self check feature. If the power light comes on and goes out after a few seconds engage the self check:
On the front of the set press and hold BOTH the Menu and Input(or Device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light should then blink a two digit error code--the most common is 2 blinks, a pause and 2 blinks--this is the most easy to fix. The set will repeat the error code several times.....
Let me know what error code you find and I will tell you what it means and what may be wrong.
If this information has helped you rate this solution as I do this here for FREE.
SD TECH
Nov 29, 2009 | Mitsubishi WS-65807 65" Rear Projection...
I have a Mitsubishi 65" Big Screen TV (WS-65909). I cannot turn it on. When I press the power button, the "Timer" light stays on for about 3 seconds and then turns off and nothing happens. TV does not...
tO KNOW WHAT THE PROBLEM IS YOU HAVE TO DO THE SELF-CHECK that this model has.
After you turn it on and the power light goes off:
On the front of the TV press and hold both Menu and Input (or device) TOGETHER FOR AT LEAST 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light will blink an error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what error code you find and I will tell you what it means. 2,2 is most common and the least expensive to fix.
If this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
sd tech
Nov 09, 2009 | Televison & Video
My 65 inch projection TV turns off within a few seconds when I turn it on. Why? No pictures or sound.
If power light does come on and a few seconds later it goes off---do the self check that the WS65909 MITSUBISHI should have:
On the front of the set press and hold both the MENU and INPUT(OR DEVICE) BOTH FOR 5 SECONDS AND THEN RELEASE BOTH BUTTONS.
Power light should blink a two digit code--error code---for example: 2 blinks, a pause and 2 blinks.
Let me know what code you get----it will repeat it several times---and I will tell you what it means.
SD TECH
Nov 03, 2009 | Mitsubishi WS-65909 65" Rear Projection...
When I power up the TV, I hear a click and the green light turns on, but seconds later, it clicks off.
try self check==when it shuts off press and hold both menu and input buttons on the front of the set for 5 seconds and release both====power light should blink a two digit code===most common is 2 blinks and then 2 blinks, let me know error code and I will tell you what it means====it should repeat the code 10 times
SD TECH
Oct 17, 2009 | Mitsubishi WS-65909 65" Rear Projection...
My model is a WS-55511. I turn on the TV, the
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
PRESS AND HOLD “device” and “menu” buttons on front of tv for at least 5 seconds and then release both together.
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC’s is blown---set will detect no voltage to convergence IC and shut down.
Aug 08, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-65909 65" Rear Projection Television Logo
73 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
