Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
Wiring diagram for a lse7806ace pressure switch
I need the wiring diagram for the pressure switch for the maytag lse7807ace
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: Maytag LSE7806ACE washer won't start, repairman
You can get this at www.appliancehelponline.com your part # is AP4025471 cost is $11.18
Posted on Mar 06, 2010
Maytag lse7806ace
open and close the lid,if you don't hear a clicking sound you just have a bad lid switch,you have an older machine and it has a cherry switch in it,go here and look at part number 5
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Washer-dryer-combo-Parts/Model-LSE7806ACE/3048/0152000/M0601018/00016?blt=06&prst=0&shdMod=LSE7806ACE
part number 208823,all it is is a safety so the washer can't run with the lid open so it will fill and then stop because the switch is bad.
Jun 06, 2013 | Washing Machines
I have a model lse7806ace maytag stackable washer/dryer unit. Initially, the washer would not do anything. I replaced the lid switch and it then filled and agitated at the same time... but when it went...
Ok , when you pull out the washer knob to start it the water fills . Can you stop the filling by pushing the knob in? if so the water valve is ok.
There is a sensing tube from the tub which connects to the pressure switch. This is what causes the water level pressure switch to shut off at the correct level. I would suspect this as they replaced the pressure switch and it keeps filling. If this is the case there is a small hole which will cause the pressure switch not to turn off the fill valves.
You can check this by removing the tube and submerging it in some water then blow in the tube while blocking the other end , if you see bubbles it is leaking and needs replacing.Hope this helps
Feb 19, 2011 | Maytag LSE7806A Top Load Stacked...
Awhile back I had FixYa help me with my washer. It would fill up with water and then just stop. It turned out to be the lid switch. Now about a month or so later I went to wash a load of clothes and again...
Hi.
If the lid switch is OK and there is water getting into the machine, then test and replace the pressure switch that detects water level.
Here the part:SUB 12002304 (Water Level Switch Kit)
Part is nr 6 in this diagram.
Also test the inlet valve to ensure that dual inlet is working. If hot is not filling, the machine will not complete filling.
A technician can swap valve contacts to find out if
both valves are opening.
If there is no filling at all, check the inlet valve and inlet duct:Water Inlet Valve.
Inlet valve is at the back of the appliance. It can be tested reading Ohms at terminals.
Aug 11, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Washer does nothing when you pull the button to start
It is probably the lid switch. On some machines there is a lid switch fuse that may not be in your wiring diagram for your machine.
Some of the fuses are glass and look like an automotive fuse and there are some enclosed in the switch assembly that you can't see unless you drill out the rivets holding the switch together.
It is a carbon fuse with a spring on each end pulling on it.
I had the same problem with mine and Maytag tech told me there was not a fuse in the switch.
This made troubleshooting especially frustrating.
Apr 15, 2009 | Maytag Performa PAV3200
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
