Question about Sony XL5300 Replacement Lamp for XBR2 SXRD Rear Projection Television
I replaced my Sony XL 5300 lamp for my Sony KDS-R60XBR2. I immediately found a very green tint on every picture on all channels. I attempted to adjust the colors with all the settings on the Picture Settings, but nothing helps. Any suggestions??
4 Suggested Answers
  • 53 Answers
SOURCE: no picture on my sony kds-50a3000 red blinking light at lamp spot
If by noise, you mean a loud, audible pop--then it's your lamp that imploded.
You should be able to just pop off the cover on the side (right side if you are facing the front of the set), remove the internal lamp cover (if present) and yank (I mean, gently pull) out your lamp.
Look for all the bright particles of glass inside your newly imploded lamp. Replace with a Sony original, as these sets can chew through generic lamps very fast.
Now, if by noise you mean something else, please elaborate.
Posted on Aug 01, 2009
ladywinn
  • 5138 Answers
SOURCE: Sony SXRD-KDS-R50XBR1
Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 and Call UED 1-800-648-6657 Just see which one has the lowest Price.
Posted on Jan 01, 2010
  • 129 Answers
SOURCE: Picture color is off after circuit breaker
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Posted on Jul 26, 2010
KDS-R60XBR2 No picture, no sound but solid green light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Mar 21, 2014 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Power error 6 times - 11V is low. - No picture/No sound
From my past experience, yes. Not sure about the 11v being low. My kdf 45 acted that way when the main lamp went out. Found a replacement on Amazon for around $45 and now good to go! So far about a year and a half. Have had to replace about 4 for friends and family so far with same symptoms. All worked great! http://www.amazon.com/F93087600-Projection-Replacement-KDS-R50XBR1-KDS-R60XBR1/dp/B005I4OLAS/ref=sr_1_13?ie=UTF8&qid=1386773721&sr=8-13&keywords=Sony+Sony+Kds-r60xbr2+bulb&tag=donations09-20
Dec 11, 2013 | Sony Kds-r60xbr2 60" Xbr Rear Projection...
Sony kds-r60xbr2 power wont come on and hte power led is blinking red 5 times
The 5 blinks is indicating the lamp ballast needs replacement your model uses the Sony lamp Ballast 147401211 for sony models KDF42E2000, KDS-50A2000, KDS-50A2010, KDS-55A200, KDS-60A2000, KDS-60A2010, & KDS-60XBR2 amd LDS-R60XBR2
Which is available at the bottom of the page at the following link. The ballast comes with installation instructions,
http://www.tvrepairworld.com/sony_circuit_boards/sony_dlp_circuit_boards
Aug 04, 2012 | Sony KDS-R60XBR2 Television
It now has a green tint -- will replacing the lamp solve that?
I have the same problem. I'm pretty sure the lamp will not take the green tint away, for the green comes from a problem with the optical block.
Jan 20, 2011 | Sony XL-5100 Projector Lamp for Grand WEGA...
Sony wega KSD-R60XBR1 green screen that can not be adjusted no matter what input is used or adjustment through onscreen tv options. how do i knw if it is the color wheel, light engine, or just a bulb
It is light engine problem in your Sony KDS-R60XBR2 lcd rear projection tv.
This tv does not have any color wheel because of its light engine technology.
Lamp is just light source that provides bright white light to light engine and its working properly.
Light engine will be replaced to fix green screen problem.
If you tv model is other than above mentioned, let me know to revise this answer.
Hope these info will help you.
Thanks.
Nov 17, 2010 | Sony KDS-R60XBR2 Television
Our tv has a green tint to all channels. We replaced the projection lamp, but still have the green. Even the black & white movies have green.
when you change video mode does it fix it? when i switch to movie, or sport, or standard, or night time it fixes the green tint
Oct 30, 2010 | Sony KDS-R60XBR1 60" Projection HDTV
Picture color is off after circuit breaker tripped. Only blues and greens. Model SONY KDS - R60XBR2. Does the lamp do this when it needs replacing or could something else have blown when the breaker...
Jul 26, 2010 | Sony KDS-R60XBR2 Television
Green overall tint
There is an extended warranty on the optical block which is causing your problem. Contact Sony directly at 800-222-SONY to arrange to have a technician look at the TV and have the optical block replaced. Sony is covering parts and labor for this repair. For more information visit the Sony website
Oct 19, 2008 | Sony KDS-R60XBR2 Television
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light has recently starting flashing and the picture and sound blank out. it does it for about 30 seconds and then picture comes back on...
I have a Sony KDS-R60XBR2 60" SXRD and the power/standby light flashes green 96 times than it switches to a RED lamp light that flashes steady. Do you know what it means?
Apr 27, 2008 | Televison & Video
Sony XL5300 Replacement Lamp for XBR2 SXRD Rear Projection Television Logo
66 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
