Question about Skil 5.0 Amp Variable Speed Scrolling/Orbital Jigsaw 4490 01
Both leaf springs have come off the roller wheel guide
This is for my Skil 5.0 Amp Variable Speed Scrolling/Orbital Jigsaw 4490. I was cutting pallets and both of the leaf springs popped off the roller/wheel guide leaving no leverage or "push" against the back of the blade as it was cutting. How do these leaf springs reassemble to the wheel guide piece?
Thank you!
John
    President:
  • 2,976 Answers
You will have to take the case apart and push them into place. If you have access to a hemostat or a nice long, this pair of needle nose pliers, it will be helpful. There is possibly a screw inside that holds them in place. If so, get the smallest bottle of blue threadlocker that you can find. It's quite expensive and you only want enough to wet the screw threads. Only use blue, it's removeable. If you use red or black, you will not be able to turn the screws if the problem ever happens again.
Posted on Jan 03, 2009
The blade broke off inside and I can't get it out. Please help me figure how to get it out.
moden jigsaw blades are held in with a taper chuck system
disconnect the unit from the wall socket
push the spindle all the way in
now press on either side of the blade holder and that should move down releasing the blade
now while holding that section down turn the unit right side up and the broken bit should just fall out
Oct 13, 2015 | Skil 4495-01 6 Amp Orbital Jigsaw
How do I get a broken blade out of a Skil 4495 jigsaw
with a pincet /forcep and inbetween the quick release activated , some wd40 will also help and a air-compressor
Sep 08, 2014 | Skil 4495-01 6 Amp Orbital Jigsaw
How do you change a blade on a Skil 4280 jig saw?
It is REALLY easy, when you know how. There is a black piece, the larger one, near blade insert...lift it and VOILA, you can insert or remove blade easily. I lost manual and spent forever trying to put blade in. Hope this helps.
Sep 22, 2013 | Skil 4280-01 4280 Variable Speed Jigsaw...
Oil leak from my Skil Jigsaw and it keeps Jamming when I cut wood
get a nail file and sharpen the blade till you can see your face in it
May 07, 2013 | Skil Top Handle Jig Saws Variable Speed...
Motor runs but blade does not move
It sounds like you have a problem somewhere between the motor armature and the reciprocating mechanism that makes the blade move up and down. Unfortunately the only parts Skill has available for your saw are the switch, cord, brushes and blade holder You'll could take it apart to see if something came apart that is repairable without parts. If you need parts like gears or motor parts, they are not available.
Jul 08, 2012 | Skil 4390-01 Variable Speed Orbital Jigsaw...
No power on the jigsaw
could be several problems. If you are mechanically inclined and have a volt/ohms meter I would unplug the tool and remove the handle half and start the process of troubleshooting with the cord,,,, switch,,,, and go on from there till you find the problem. Usually it is a cord or switch that would be the problem.
Feb 07, 2012 | Makita 4304 Factory-Reconditioned Variable...
I purchased a new B&D variaable Speed Orbital
you can order that in any B&D service center..try it..
Jun 09, 2011 | Black & Decker Saws
My scroll saw will not come on. There is power to
The motor is probably fine. Try taking the case apart and check for a loose connection to the motor.
Nov 25, 2009 | Skil 5.0 Amp Variable Speed...
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Skil 5.0 Amp Variable Speed Scrolling/Orbital Jigsaw 4490 01 Logo
616 people viewed this question
Top Skil Saws Experts
JOHN LAPIER
Tejodhar Atreya...
Tejodhar Atreya...
Are you a Skil Saw Expert? Answer questions, earn points and help others
