Question about Bosch Evolution 800 SHE58C05UC Stainless Steel Built-in Dishwasher
Bosch SHE58C05UC/50 dishwasher stopped at 96 minutes (will not advance) & I cannot cancel. Diagnostic codes C4 then P0, rinse light steady on, drying light flashing. No water in anti-overflow pan, it's dry, float switch is working. Vacuumed out any/all water, Have replaced water inlet valve. Main circuit board shows no sign of solder joint disruption. Have switched circuit on, then off in attempt to reset (negative results). Any ideas on how to reset and then to fix the problem?
  • Disha Wasser Oct 29, 2012
    Delicate cycle now runs but never finishes. I think it is waiting for the water to reach temperature. Heater light on front od D/W is flashing. How do I test for control board fault vs. heater unit fault?
3 Suggested Answers
Macmarkus
  • 2605 Answers
SOURCE: I have a SHU43C05UC/22 Bosch Dishwasher. The
Welcome to FixYa.
Based on your description I'd say the issue is with the control...unfortunately.
The number"1" being displayed ( on models with the display like yours ) is actually an error code indicating a fault in the heating process.
Bosch has had a history of this exact problem I'm about to lay out for you and this is the first thing I'd be looking for if called out to service the unit with the symptoms you've described.
**B/S/H/ also issued a recall on certain models between 1999 - 2006 depending on the serial number so you may want to contact Bosch to inquire if yours is affected.**
http://microsites.boschappliances.com/safetyrecall/dishwasher/
or
Bosch dishwasher hot-line 1-800-856-9226
1-800-856-9226
Before calling, have the model and serial numbers on hand. A live operator can be reached at the hot-line 24/hrs day.
Those not affected by the recall still can be a problem but easily fixed. As I've alluded to the issue is likely within the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
My first suggestion would be calling in an authorized bosch service tech. if that is an option for you and your budget however, If you feel capable of checking this on your own, there`s a way to visually inspect the control yourself.
It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The culprit will 99% of the times be one of the pins from the heater relay,
**Your control WILL differ in appearance, however the issue, the service and all the same info applies...except the part number. Yours will be # 431692**
**Flip this over and inspect the solder joints, it will be obvious when you see it...the cover for your models control comes apart in a similar manner**
This is where and what to look for, except I`ve re-soldered this one already...
...hence the unit sit`s and takes longer & longer to finish because it can`t heat to advance or unless the 2 buttons for "cancel" are pressed, other-times it will eventually stop or display "1".
You can also run the unit through a regular or econo cycle ...any cycle with the exception of rinse & hold, and with the door panel removed place an ammeter on the gray/black wire it should draw 11 amps during the wash cycle...after it fills and the flow switch indicates it has adequate water to engage the heater.
i.e.
**My Opinion - if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...but it has to be done well...or it will not last, although Bosch recommend`s replacing the control ( # 431692 @ approx. $150 - $250USD...$167.99 at "searspartsdirect.com" ) and I don`t pretend to speak on their behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power or turn off the breaker before attempting any service to the dishwasher.**
If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau/Siemens, to service your machine.
Hope this answer`s your question, let me know if I can assist you further.
Thank`s for visiting "FixYa" for your repair inquiries. Please take a moment and rate this solution to it's helpfulness.
Good luck.
Regards,
Macmarkus :)
Posted on Oct 31, 2010
SOURCE: I have a 13 month old Bosch SHE58c dishwasher.
I have exactly the same problem. Turn on the machine and it just pumps and pumps, door controls do nothing. According to the technician who came and looked at it the problem is a bad control board. He ordered the part and we are waiting on it.
Posted on Jan 19, 2011
Bosch dishwasher stuck wash cycle
If you post your model number I and others may be able to help you further.
Short of that, it sounds like, the dishwasher stops because it's waiting for the water to get to the right temperature before it advances. If you open the door and the water is cold, you need to replace your heater because it's not heating the water. If the water is really hot, then replace the thermostat inside the door because it's not reading the water temperature correctly and advancing the timer.
Dec 16, 2013 | Dishwashers
SHE58C05UC/46 dishwasher won't complete cycle
sound like wash heater failure if it doesnt reach wash temp it will jump back to beginning of heat phase,thats why you get a lot of foam heat will suppress this as part of the wash action.
Jul 28, 2013 | Bosch Evolution 800 SHE58C05UC Stainless...
SHE/43M bosch dishwasher fault code C3, P0, not washing, but draining
I have the exact same thing. While P0 is on the display, Regular Wash is lit and Quick Wash is flashing
Nov 07, 2011 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch SHE58C05UC/50 normal cycle only runs for one minute and shuts off. Quick Wash works?
643268 pc board located under a metal panel on the right side of the machine at the bottom.
Aug 20, 2011 | Bosch Evolution 800 SHE58C05UC Stainless...
I have a Bosch SHE58C05UC dishwasher. It appears to be **** in some sort of diagnostic mode. How do I get it to reset. When you turn it on all the lights are on and the display says either 10 or 11.
Hi diybritt,
Either:
1) Hold in the Power button for 5 seconds.
2) While active, unplug the machine, wait 5 minutes and plug it in again.
Hope this helps :-)
* If you found this solution helpful, please rate it
Jul 17, 2011 | Bosch Dishwashers
I need to reset my Kenmore Elite dishwasher but i don't know how.
follow the below instructions:
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel and stop the "Clean" light from blinking repeatedly.
Good luck.
Jul 14, 2010 | Microwave Ovens
Our glasses are coming out with a cloudy film all over. How do we remove and prevent? Dishwasher has plenty of rinse aid.
remember all the dishwasher needs is 1. dishwashing soap. 2.the hottest water going to the machine. 3.the jet dry must be filled completely,some model you can turn up the jet dry is needed. hope this helps.
Mar 12, 2010 | Bosch Evolution 800 SHE58C05UC Stainless...
I need a manual for the bosch she58co5uc
http://www.bosch-home.com/us/SHE58C05UC.html?source=search
Oct 17, 2009 | Bosch Evolution 800 SHE58C05UC Stainless...
My Bosch dishwasher won't shut off. The timer says "1" forever and when you open it there is about an inch of SOAPY water still there.If you press start it goes to "13" and again counts down to "1" and...
Bosch SHE44C06UC
The dishwasher continues to run...I followed instructions and performed the diagnostic...the light above the quick wash was solid, the light above the rinse/hold was flashing...the code displayed in the cycle countdown window was P0...now assuming the machins isn't "pissed-off"..can you help-
Feb 28, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Kenmore Elite Dishwasher clean light ind flashing and won't start
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Feb 17, 2009 | Kenmore 24 in. 15142 Built-in Dishwasher
Open Questions:
Bosch Evolution 800 SHE58C05UC Stainless Steel Built-in Dishwasher Logo
120 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
