Question about Acer Aspire Computers & Internet
Room Stat Overides Programmer
I have installed the above room stat and programmer, however the room stat overides the programmer, basically when the heating is not on the time for it to be on ( as normal ones work ) it comes on if the tempreture drops below the room stat set figure. Therefore the room stat calls for heat and it fires even when its out of programmed time. I have had both my electricians look at it and they both thought the product was faulty therefore i changed it for a new one and the same happens, there completely cluelss and theres no way it should happen. No doubt there is a very simple explantion but we dont have one. Has anyome else had this problem ?/? there appears to be no info on this issue online either.
  • 2,888 Answers
It sounds like its working as a frost stat ,which will fire the heating when the temp drops with the heating not being on , this to stop house from freezing up .
Posted on Oct 27, 2012
  • 1 more comment
  • jon crafer Oct 28, 2012
    thats what it does sound like but thats no it, sounds like a permanant switch live is wired in wrong internally to me,
    the heating comes on in the night when temp drops below set tempreture completely out of programm
  • Paul Carew Oct 28, 2012
    yes live is in the wrong place
kdgrayson
  • 195 Answers
SOURCE: My central heating timer is always on even when I
IF YOU MEAN TIMER WHEEL ON HONEYWELL STAT ITS NORMAL OTHERWISE I HAVE NO IDEA WHAT YOURE SAYING
Posted on Dec 03, 2009
  • 149 Answers
SOURCE: potterton puma heating will not shut down even
thermostat stuck closed repair/ replace
Posted on Jan 16, 2010
  • 36 Answers
SOURCE: fitting room stat
take the link out and fit stat wires in its place,will work then.
Posted on Jan 31, 2010
  • 2888 Answers
SOURCE: Central heating - room thermostat Honeywell T6360B
hI he has wired the pump to permanant live there should be link between two of them ? cannot recall which . not much help sorry
Posted on Mar 01, 2010
  • 2888 Answers
SOURCE: I have a Y plan heating/domestic instalation.The
Hi the cylinderstat controls the hot water only not the heating the boiler stat controls the water temp the room theromstat controls the rads , if you have one ,
so boiler stat set on 180f or number 5 cylindersat set on 140f to 120f roomstat to your comfort , the boiler stat works as a over heat so if the cylinder stat or roomsat fail it will turn off on the boiler you should beable to check wiring from that .
Posted on Mar 10, 2010
There is no power going to the pump in my boiler
Power to the pump goes via the room stat in turn from the programmer check these out first
Apr 22, 2013 | Water Heaters
Danfoss rx1 thermostat shows 'of' ?
Remove batteries from room stat,turn off the electrical supply to reciever unit.
Turn back on the electric to reciever unit,the red light should be on,press the top "manual" button,the green light should come on and boiler should fire (assuming the programmer is in an "on" period)
Press the bottom button,and keep it pressed,then press the top button until the green light flashes,stand about 6 feet away,and refit the batteries to the stat while observing the reciever unit,either the red or green light (cant remember which) should flash to show the 2 units are syncronised.
Another basic test if all seems ok,when turning the stat up or down,when the green light on the reciever unit comes on or goes off,its usually accompanied by an audible "click" ive found,that if this is not happening, the reciever unit does not switch either on or off,may be intermittant.
Replacement is the only cure.
garden led light
Jun 04, 2012 | Garden
Replacing an ST699 with a ST9400C following repl wiring diagram, but programmer does not come on. Is the diagram incorrect? Wiring colours do not follow any of the plans. Syst has room stat, cyl stat,...
Disregard wire colors. Instead wire by terminal designation. In other words :
Wire on "R" Terminal on old thermostat to "R" Terminal on new thermostat no matter the color.
Jun 14, 2011 | Honeywell Heating & Cooling
The heater is not coming on. fan will blow cold air but does not heat up.
Assuming you have the T-stat set to the heat setting and set at least 10 degrees above room temperature and have the t-stat set to AUTo (If applicable) then the problem is with the actual heating unit. The T-stat merely turns the unit on.
Feb 02, 2011 | Honeywell Programmable Thermostat Heater
I have a Y plan heating/domestic instalation.The boiler will go off and on even if the programmer is off,If the programmer is off and I turn the cylinder stat up the c/heating pump will run,i recently...
Mar 10, 2010 | Heating & Cooling
Cannot get central heating working,for honeywell ST6400 programme
with y plan 3 connections on programmer HW on HW off CH on HW on to cylinder stat then HW call to Orange on Mvalve to power boiler and pump HW off to grey wire on Mvalve to close hot water CH to room stat common then heating call to white on Mvalve
Jun 13, 2009 | Honeywell Programmable Thermostat Heater
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Computers & Internet Logo
76 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
