Question about Dell 3100cn Laser Printer
Paper Jam Error on Dell 3100cn Laser Printer
Paper Jam Fuser 007-105
Open Duplex Mod Remove Paper
  • Anonymous Mar 21, 2014
    removes paper and can't get past error message about paper jam
    Problem Solver:
  • 5 Answers
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Posted on Jan 09, 2009
Jam in duplex area
Its is trick..If its more then two pages print, printer grabs second page even first page in duplex unit., here its confusion. Check with simplex single print, see any paper mismatch error? or printer throwing paper in output bin after successful print?. No.. check fuser out sensor or paper out roller.
Print only two pages matter in duplex, check where paper struck? if paper our roller not grabbing paper back properly in time (slipping while grabbing back) gets jam error.
Always ensure that select proper paper size in printer.Other than this it may major issue, need technical knowledge..& possibilities are less to judge the exact problem..
Keep update us to resolve the issue.
Aug 22, 2014 | HP Color LaserJet Professional CP5225dn...
Problems getting printer to respond after clearing paper jam
hi try this your printer error is mentioned and a solution offered good luck
Aug 28, 2007 | Dell 3100cn Laser Printer
Paper Jam Fuser 077-104
Most likely you will have to replace the fuser. Also I would inspect all pick up rollers and make sure they are all textured with no smooth or bald spots. Bad rollers are the #1 cause of jams. Also if you hear any clicking you may have a bad gear.
Jul 13, 2012 | Dell 3100cn Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is...
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Jun 24, 2011 | Dell 1815dn All-In-One Laser Printer
How to open drum to remove the jammed paper inside
Hi Good day!! here are the steps how to remove paper jam in brother hope it help's you!!
1. Pull the paper tray completely out of the printer.
2. Pull the jammed paper up and out of the printer.
3. Press the cover release button and then open the front cover.
4. Pull out the drum unit assembly. Pull the jammed paper up and out of the printer. If you cannot remove the drum unit assembly easily at this time, do not use extra force. Instead, pull the edge of the jammed paper from the paper tray. If the jammed paper can not be pulled out easily, turn the jam dial towards you as you gently pull the paper out.
5. Open the face-up output tray. Pull the jammed paper out of the fuser unit. If the paper jam can be cleared.
6. Open the jam clear cover. Pull the jammed paper out of the fuser unit.
7. Close the jam clear cover. Close the face-up output tray. If the paper jam still cannot be cleared, for HL-5130 and HL-5140 users go to Step 10, and for all other users go to the next step.
8. Pull the Duplex Tray completely out of the printer.
9. Pull the jammed paper out of the printer or the Duplex tray. Put the Duplex tray back into the printer.
10. Push the lock lever down and take the toner cartridge out of the drum unit assembly. Take out the jammed paper if there is any inside the drum unit.
11. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
12. Put the drum unit assembly back in the printer.
13. Put the paper tray in the printer.
14. Close the front cover.
Oct 19, 2010 | Brother MFC-7440N Laser Printer
Duplex jam 0 - check inside
hey just open the back door of your printer remove the jammed papper...den resart your printer n then print...Robert
Jan 05, 2010 | Dell 1815dn All-In-One Laser Printer
Jam 2 error...
The issue is most likly the fuser. Check it for paper. It may need replaced. If you need a technician to do it, replace the printer. It will be cheaper. if you can do it yourself, look into the price of a fuser.
Jan 23, 2009 | Dell 1815dn All-In-One Laser Printer
Close reg cover
After researching the error online, I solved my problem by simply pushing the back cover of the unit closed; I didn't even know it had come open after I removed my jam.
Hope this helps!
Jul 18, 2008 | Dell 3100cn Laser Printer
Paper jam
Probably one of the sensors on the fuser is not working correctly. There are two sensors on the back of the fuser that move when the paper exits the fuser. Remove the back of the printer when the printer says there is a jam and move the sensors to see if the error goes away. If so you may have to replace the fuser unless you can just replace the defective sensor.
Jun 03, 2008 | Lexmark T644 Laser Printer
Dell 3100cn Duplex won't feed
I'd suggest it is a sensor issue. Since the error comes up, the printer stops responding - even if everything is okay.
Jul 28, 2007 | Dell 3100cn Laser Printer
Dell 3100cn Laser Printer Logo
823 people viewed this question
Top Dell Office Equipment & Supplies Experts
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
