My sony bravia kdl32cx523 wont turn on just red light blinks 6 times
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1000 posts to different brand TVs now. Pull up older posts there.
Posted on Oct 27, 2012
SOURCE: red blinking light
The red light blibking 6 times indicates that the power supply board has a defective or damaged area. I know this because i had the same problem...bought a damaged tv for parts and replaced the power supply board as the tv would not turn on...wokrs like a charm now.
Posted on Dec 03, 2008
  • 1039 Answers
SOURCE: 13 red standby flashing lights -- turns on, then turns off
Are you sure about the 13 flashes. Error code only goes to 8 flashes.
Posted on Apr 26, 2009
dsacco86
  • 1077 Answers
SOURCE: my sony bravia tv is flashing red stand by light
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Posted on Jun 29, 2009
  • 197 Answers
SOURCE: Sony Bravia standby light flashing 6 times
there is a bad ground may on the cable check the voltage on the cable & set if on cable call the cable company. if tv call sony they may help with cost may be still under warranty
Posted on Jul 02, 2009
  • 194 Answers
SOURCE: My Sony Bravia Kdl40v300 will not turn on When I
sorry. Hope you still have a waranty. This is not an uncommon problem with the sony's. 99% chance that the panel went out. Could also be a balance board issue, but usually not. Call Sony for an authorized repair center
Posted on Dec 24, 2009
Sony bravia KDL46-V3000 inch led Tv red light blinks 6 times???
It means you do have a LCD panel back lights problem, in most of the case, a defective back lights inverter could be the cause.
Jun 28, 2017 | Sony Televison & Video
Sony bravia kdl-32bx300 wont turn on
https://community.sony.com/t5/Television-General/Red-light-blinks-6-times-tv-won-t-come-on/td-p/47107
Mar 14, 2016 | Televison & Video
Sony Bravia KDL-46W3000 - Shuts off after 30 sec followed up with 6 red blinks.Last 3 days back cover off has been working fine. What board should I be replacing?
Sony Bravia TV kdl- red blinking led light error codes ...
? 10:28
https://www.youtube.com/watch?v=0KGysXbxnaU
Mar 28, 2015 - Uploaded by Tampatec
Sony Bravia LCD TV KDL models red blinking led light error codes & possible ... with perfect picture, no warning signs and it just shuts off. is it that quick? ... with the following problem: I connect the power grid lights Standby red light. ... the title before deleting, it is very fast after that flashes Standby 6 times.Missing: 46w3000 ‎30
Nov 18, 2015 | Sony BRAVIA KDL-46W3000 Television
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony bravia 40 inch red blinking light when turned on green light shows but go,s back two blinking red what should i do
you might try washing it.
submerge the tv in the bath tub, use lukewarm water only.
then turn it on.
problem solved.
Sep 13, 2014 | Sony Bravia KDL-40EX700 40" LCD HDTV -...
Sony bravia won't stay on 52w4100, clicks with green light three thimes then shuts off and blinks red 6 times
Sounds like a power board reset switch gone bad. Have the power board replaced.
Good Luck Ed Pinero
Feb 03, 2013 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony bravia KDL-37XBR6 wont turn on at all, and blinks 6 times..
The 6X blink code is a bad back light error. could be one of the florescent bulbs in the panel if it shows a picture for a couple seconds and there is a darker band across the screen. Also Found loose connector CN6153 on the G5 Power Board.
CN6153 goes to CN6702 on the D4 board. Or the power board
Mar 30, 2012 | Sony Televison & Video
I have a 2008 Sony Bravia KDL-46W4100 that when I turn it on the red light blinks 14 times. Please help me troubleshoot this problem so I can order the correct part to fix this...
Please help me troubleshoot this problem so I can order the correct part to fix this television
Nov 16, 2010 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
Sony bravia 46 shutting off a blinking 6 times
here's blink codes for sony bravia
1 blink abnormal AU Power Voltage
2 blink abnormal d5v/a9v power voltage
3 blink Abnormal panel voltage
4 blink backlight failure
5 blink abnormal main power voltage
6 blink abnormal speaker voltage
7 blink internal temp. rise
8 times ic5000
that helps?..
Sep 11, 2009 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
