Acer AL2216WBD LCD Monitor Logo
Anonymous Posted on Oct 26, 2012
Acer AL22 Has no image for 1 Hour. Then is OK.
Over time ( one year) it boots up slower and slower. Now, Initially, it does not show any life, not even the Acer logo. Then, after an hour or more, it does finally boot, and works fine. IF I turn it off then, it works OK when I turn it back on. But if I leave it off for a period of time. it again takes much time to function again. Do I throw it out or can I fix it?
Buddy Mcsparrin
Level 3:
  • Master 1,684 Answers
  • Posted on Oct 27, 2012
Buddy Mcsparrin
Master
Level 3:
Answers
1684
Questions
Helped
1011060
Points
4641
That is a common symptom of a failing power supply board. The filter capacitors start to go bad and the power supply can not stabilize and start correctly, after the capacitors are powered up for a while they can hold a charge and the power supply finally gets going. Here is a link to a repair guide for that model.
http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
  • Anonymous Oct 27, 2012
    Thanks Buddy, for the analysis and the solution. I shall order the kit and do the repair. It is great to have this site and the access to experts who can help. Gene
5 Related Answers
Anonymous
  • 198 Answers
  • Posted on May 24, 2007
SOURCE: Acer AL1916W 19" problem
Hello mat78, Unfortunatelly the problem is hardware based. You will need to have the monitor repaired in a service center. Here's why: LCD/TFT monitors don't produce light themselves. They are composed by a matrix of transistors (TFT - thin film transistor) that have the property to reflect or allow some light (certain wavelenghts)to pass through them. They don't produce light by themselves. Instead there is a fluorescent tube (neon like) light inside the monitor and that's the light source used in order for you to see what's on the screen. A flourescent light is suposed to last pretty much, i don't think yours has a problem, you say it works for some seconds or so. Instead your problem is most probable with the inverter circuitry that powers on that light. It's a common problem among these types of monitors but in your situation i don't think it will be an expensive repair. In the case that the screen is dark (in a dark place you can't read or view anything on it) but if you apply light to it ( a flashlight or something) and you see something, then the problem is most likely to have occured with the invertor. Try to ask at a local service center for a repair, this shouldn't be an expensive procedure. Hope this helps.
Anonymous
  • 6966 Answers
  • Posted on Jan 22, 2008
SOURCE: acer al2016w monitor
Based on publish specs of the Acer AL2016W its maximum resolution is 1680x1050. If the PC is fine then perhaps the issue is that the PC is set to display higher than the 1680x1050 max res of the Acer LCD. What is required is to lower down the Screen resolution of the PC. This can be done by booting into Safe Mode (on boot, press and hold (or tap continuously) "F8", display will be "Windows Advanced Options Menu", use up/down arrow keys to move to "Safe Mode" and hit the Enter key. Right click on any clear area of the desktop and click on Properties, click on the Settings tab and move the Screen resolution to 1680 by 1050 pixels or lower. In some cases, you may need to lower down also the Screen refresh rate. Reboot.
hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Anonymous
  • 6966 Answers
  • Posted on Feb 15, 2008
SOURCE: Acer AL1716 (black) - Drops to No Signal -
Hi Eric,
Your post/description of "No Signal" and power LED changing from green to amber is indicative of just that - the monitor is not receiving any signal from the video card of the computer or the signal it is receiving is beyond its capability.
Just to verify that it is indeed the PC;'s setting that is the root of the problem and not an internal fault within the monitor, pls:
1. lower the screen resolution of your desktop's properties.
2. it may also be of help if you likewise lower the screen refresh rate.
Both of the above may be adjusted through the appropriate settings in your Display Properties.
If your concern has not been corrected after completion of the above procedures, pls post back details of your video card (brand/model), display properties settings: a) screen resolution, color quality and Advanced/Monitor screen refresh rate.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Thank you for using FIXYA.
A
Anonymous
  • Posted on Mar 19, 2008
SOURCE: monitor flashes display 2-3 times then goes blank on initial boot
Throw it out the window. Acer sucks.
Anonymous
  • 472 Answers
  • Posted on Apr 09, 2008
SOURCE: acer al1916 monitor goes black
You probably have a few dodgy caps on the power board inside. It's an easy fix if you are confident around electronics.
If not, pop it off to your local TV repair shop and have it taken care of now before it gets expensive with a complete failure.
Hope it helps =)
When i boot acer with dvd it shows image checksum error
Re burn a new copy... You probably just had a defective cd.
Does ACER ASPIRE One 11.6" have camera ?
Yes'
General Brand Acer Series Aspire One Model AO751h-1401 Part# LU.S780Y.002 Operating System OS Provided Windows Vista Home Basic Processor CPU Type Intel Atom CPU Speed Z520 CPU L2 Cache 512KB Chipset Chipset Intel SCH US15W Display Screen Size 11.6" Widescreen Display Yes Display Type WXGA Max Resolution 1366 x 768 Display Feature LED backlight & Acer CrystalBrite Technology Graphics Graphics Processor Intel GMA 500 Video Memory Shared system memory 2GB Hard Drive HDD 250GB Hard Drive RPM 5400 RPM Hard Drive Interface SATA Netbook Camera Camera Type Acer Crystal Eye webcam Communications LAN 10/100Mbps WLAN 802.11b/g Wireless LAN Expansion / Connectivity USB 3 x USB 2.0 Video Ports 1 x VGA Audio Ports 1 x Headphone/Speaker/Line-Out Jack 1 x Microphone-in Jack Audio High-Definition Audio Support Speaker Built-in stereo speakers Input Device Touchpad Multi-gesture Touchpad (Circular-motion scrolling, pinch-action zoom, page flip) Keyboard Standard Card Reader Battery 3-cell Li-ion Battery (2200 mAh) Battery Life Up to 4-hours Manufacturer Warranty Labor 1 year limited Parts 1 year limited
3answers
Hi my acer lap top is in safe mode and wont start if i buy a fix it cd will this work thanks alicia
Since you can boot in safe mode, teh you should try using the SYSTEM RESTORE to take it back to the day the problem started, try that first.
For example of XP: http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/systemrestore.mspx
2helpful
2answers
I have a Acer Aspire 5745 (CPU: Intel i5 processor 2.5GHz RAM: 2GB OS: Win 7 Home Basic) which is only 2 months old. Yesterday I started a installation setup of a game, when suddenly the system restarted....
Hi, I do apologize for the inconvenience you have been facing.The reason why the laptop does not reboot to Windows even after reinstalling Windows is because the issue is with the hard drive not being recognized the reason for which you get a blinking line on the screen after the Acer logo .In this case I would suggest that if the laptop is under warranty please contact the Acer Technical support and have an order placed for repair.
Thank you for your time and best wishes for your effort.
Acer laptop power button and fan problem
This is usually something to do with network booting, see if your PC is trying to boot from some sort of network device, or network address, real or imaginary, It may also be a virus, trying to connect, somewhere, at boot up, so run a rootkit check too. Check all network settings and privacy settings too.
Here is a program that runs at boot time and tells you what is going on and how to speed up your boot time, it may help. copy/paste below. http://www.soft32.com/Download/Free/BootVis/4-19687-1.html
Install the eRecovery drivers for aspire 5715Z
First ensure you have enabled D2D from Bios, If bios settings are OK then that message often comes up when E recovery partition is damaged.
Possible solutions are calling Acer and getting a disk to restore recovery partition (best way to proceed)
Or downloading and installing drivers from acer website
Here is recovery procedure from manual, to ensure you are doing corrrectly:
Create backup
You can create and save backup images to hard disk, CD or DVD.
1 Boot to Windows XP
2 Press Alt + F10 to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery settings and
click Next.
5 In the Recovery settings window, select Backup snapshot image and
click Next.
6 Select the backup method.
a Use Backup to HDD to store the backup disk image on drive D:.
b Backup to optical device to store the backup image on CD or DVD.
7 After choosing the backup method, click Next.
Follow the instructions on screen to complete the process.
Restore from backup
You can restore backups previously created (as stated in the Create backup
section) from hard disk, CD or DVD.
1 Boot to Windows XP.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 Select the desired restore action and follow the onscreen instructions to
complete the restore process
Here Acer download page: Acer Service & Support
2answers
Acer 2300 Travelmate wont start up
my guess is that your ram got loosed a little bit. that is why some of your system files are not loading correctly. Try re-inserting you ram or memory. just always remember that computer parts are very fragile so do not force to dislodge anything.
2helpful
2answers
My acer,mod. 1715
Rich most likely this monitor needs capacitor replacement if you can solder you can do it, you just need to order or get the bad capacitors that need replacement so you need to open the case and get at the power board. once you can get at the blown caps you can see whats damaged and what is OK usually it is 1 or 2 capacitors at about 50 cents each. and about 1 hour of your time.
let me know what your doing, good luck
1helpful
2answers
Slow or fast charge
Yes, the amperage your charging at determines charging time. The higher the amperage, the faster it charges. Your battery is rated in mAh or milliamp hours. One Ah means the electric charge transferred by a steady current of one ampere for one hour. A mAh would be 1/1000th of an amp for one hour. If your battery is a 1500mAh battery it means 1.5 amps for one hour. This charge current should not exceed the rating of the battery. It would cause possible excessive heating and possible a fire or explosion, especially on newer more volatile batteries like lithium polymer batteries. The life of the battery charge when fully charged will be similar no matter how you charged it, but slower, lower amperage charges will maintain your battery better than quicker, higher amperage charges and help extend it's life to its potential.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
