Question about Sears Garden
Battery does not charge on my 15 hp sears rider mower
    Habit-Forming:
    Scholar:
  • 54 Answers
First thing i would do,check the water level in the battery,don't have to on a " Maintenance Free " battery. Remove both cables,from the battery,clean the cables with a wire brush,especial made for this.There can be a small film of acid oxidation deposit forming,that get into the cable clamps and the battery posts.This causes the cables not to make good contact with the posts. There is something else you can do and that,is use a portable battery charger. Try to charge up the battery with that,this would eliminate the tractor's charging system causing the problem. If this battery won't take a charge or hold a charge,the battery is bad.Hope this helps.Sincerely,Brad Locke DTD 12/04/15
Posted on Dec 04, 2015
SOURCE: 15 HP Kohler Engine RIding mower wont stay on
What's the gap setting between the coil and flywheel 15 hp kohler motor?
Posted on Aug 03, 2008
  • 20 Answers
SOURCE: mower wont stay running
take hose off and take to local hardware store.probly got something that would work
..freaken sears..')
Posted on Jun 02, 2009
  • 202 Answers
SOURCE: I have a Husqvarna Pro Rider 15 ride on mower,cuutting deck broke
You may find this helpful. A complete manual you can download and use for this and other repairs.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqom88hoen2003_1140142-26rideen.pdf
Posted on Dec 23, 2009
  • 66 Answers
SOURCE: Older Sears rider mower model 6-25 with Tecumseh stalls.
Sounds like you have a wire grounding to the frame somewhere. Check the wires to see if you see any bare spots or frays. www.nnyparts.com
Posted on May 30, 2010
  • 4044 Answers
SOURCE: sears rider new drive belt
Double check the belt routing. Drop the deck so you can get a view of everything and make sure the actuation pulley is actually engaging when you put it in gear. You'll also want to check the rear of the mower for a bypass switch. They started including a switch, it's more like a wire that activates a small lever, that allows you to move by putting it into neutral bypassing the transmission. If you don't have that switch then it is most likely the belt not routing correctly or the transmission. If it was working before you changed the belt then most likely the problem is the belt not being routed correctly.
Posted on May 09, 2011
How to remove solenoid ona COX 12.5 hp rider mower ??
If you talking about the fuel shut off solenoid it mounts base of the carb bowl. Check out my blog: http://foggyfacts.blogspot.com/2010/08/riding-mower-mystery-solved-mower-quits.html FoggyFacts Riding Mower Mystery Solved Mower quits after 15 minutes then...
Oct 14, 2016 | Garden
42 craftsman rider electricity at solenide non at starter.
Check power at solnoid on cable coming from battery. 12-13V. With key turn to start should have 12-13v
May 22, 2015 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Need MANUAL for Craftsman 13.5 hp 30" rider mower - CAN DOWNLOAD IF YOU PROVIDE MANUAL
go to sears... you need your model number and it's free... no model number, no help
Aug 22, 2014 | Craftsman Garden
Rider want go up hills good
It depends on your interpritation of a hill, most manufacturers will only recommend a maximum 15 degrees due to the risk of tipping the machine over.
May 17, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
What volt battery for craftsman tractor model 917276240
all riders take a 12volt battery . you can buy the smaller lawn and garden battery for around 30$ my suggestion is get the bigger battery that is offered specially if going to use the rider during winter and it has a twin cylinder . it give you more power for faster starts and is easier on the charging system .
Nov 24, 2011 | Craftsman 24 Hp 48" Deck Yard Tractor
Mountfield 1228h ride on mower battery does not keep charge when mowing
had same problem,when u r setting in the sit open the hood of the tractor on the left side of the eng. u will see a square part bolted into the side of the up by the top it should have three wires coming out of it this is the rectifier which runs off the magneto on the eng. this keeps the battery charge but very expensive $57 had to order mine from craftsmans took 1wk
Mar 31, 2011 | Tecumseh Ov691ea 22 Hp 22hp Lawn Rider...
Sears riding mower
Even new batteries can be bad. All it take is one dead cell in it and it won't be enough to start the mower. The other thing to look at is the cranking amps of the battery. The cheapest wally world battery won't cut it for the larger motors. www.nnyparts.com
May 29, 2010 | Garden
Mower wont stay running
..freaken sears..')
Jun 02, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Apr 20, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
