Question about Hitachi 70VS810 70" Rear Projection HDTV
Hitachi 70vs810, I installed a new lamp but the lamp trouble light is still on and the TV will not come on.
Coldcut
  • 1554 Answers
SOURCE: Hitachi 60VX500 60 in. Rear Projection TV
The HV circuit that runs the lamp is out
or the thermal fuse near the lamp is bad/blown.
Posted on Jan 27, 2008
  • 1779 Answers
SOURCE: My Hitachi 70" LCD will not turn on
Take the door back off and look for a safety tab somewhere on the door that will activate a small safety switch, the tab will stick out. Maybe you broke the tab off or just didnt get the door on correctly. Try that and let me know.
Posted on Feb 04, 2009
ericvb2005
  • 194 Answers
SOURCE: When I turn the Hitachi tv on there are three
no..thats hard one to fix it...
go to the expert technician so that they know what the real problem about
Posted on Oct 19, 2009
  • 4234 Answers
SOURCE: I recently moved and when I powered up my Hitachi
Check the lamp access door and make sure that it is completely closed. There are interlocks that prevent the unit from starting if the door is open. Also, it is possible that the move damaged the lamp as they are extremely fragile especially when older. If the door is not the problem, try replacing the lamp.
Update this if neither option resolves the problem.
Thanks,
Dan
Posted on Nov 09, 2009
  • 86 Answers
SOURCE: hitachi 50vf820 ultravision tv. replaced lamp now
Did you make sure all doors and screws are back in unit biggest mistake is not putting door back on mechanism that wont let lamp light without it on please start here
Posted on Apr 27, 2010
I put a new lamp in my hitachi 50v720 tv. The light keeps blinking and the power will not come on
If it was blinking like it was, it's probably either a bad lamp or a faulty install. Try re-installing the housing of the lamp in the T.V. if you're sure you didn't over tighten or under tighten the screws on the lamp. These are all simple things to check before you send back the potentially bad lamp.
Jun 17, 2011 | Hitachi 50V720 Television
Have a ultra vision 70vs810 it blinking red and
I tried all of the above and no luck but THEN we realized we had it plugged in to the surge protector not the battery backup. Once we plugged it in to the battery backup it powered up like a champ! Good luck!
Jul 31, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
The power is on , no pictures or sound. Blank screen.
sounds like a bad lamp most lamps are rated at 2000 hours hope this helps ya
Apr 14, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
I have a Hitachi 70 inch lcd rear projection tv (70vs810). When the tv is turned back on the screen is very blurry. We have had a problem with it over the past 6 months but it would go away after warming...
This is a well described problem with model #. Thanks for that. Now it could be a tv lamp at the end of its life if the tv lamp is around two years old. Its easy to change lamps and the procedure is explained in owner's manual. If the lamp was replaced recently or the problem stays even after changing the tv lamp, its the optical block going bad. That need professional help and you should not try to mess with it. Check out at www.fixurtvs.com These repairs could be expensive and may be wiser to go in for another TV.
Feb 26, 2010 | Hitachi 70VS810 70" Rear Projection HDTV
I recently moved and when I powered up my Hitachi model 70vs810 the temp light is flashing and the tv won't light up
it sounds like theres something wrong with your tvs air filter.
my advice is to take it to the store you got it from and ask them if theres anything they can do
they should be able to clean
i really wouldnt sujust trying to get it out your self it can be tricky putting back togther
Nov 09, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Feb 04, 2009 | Hitachi 70VS810 70" Rear Projection HDTV
Power light blinking continuosly
First off check your lamp or replace it. You can never have too many lamps..........in the last minutes of overtime ! Are you kidding Me! If lamp doesn't work, you will need to find qualified servicer. Try craigslist or tv repair in yellowbook
Craig www.classtorations.com
Jun 08, 2008 | Hitachi 70VS810 70" Rear Projection HDTV
Won't turn on?
You need to check the lamp itself,sometimes they just blow up like a bulb does and if the lamp is good make sure all the fans are running and all compartments are close properly like where the lamp sits.Set needs to be unplug from the wall while you check.The wainting is not acceptable for 3 months.Let Us know if you need more information.
Oct 10, 2006 | Hitachi 70VS810 70" Rear Projection HDTV
Open Questions:
See all Hitachi 70VS810 70" Rear Projection HDTV Questions
Hitachi 70VS810 70" Rear Projection HDTV Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
