Question about Samsung 225BW Monitor
Displays in red only - Samsung 225BW Monitor
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
LG 700E CRT 17" monitor,
problem with the monitor Display cable. it is damaged.
Normally monitor will receive 3 colors red, green, Blue signals from CPU. If one cable i.e Red wire connection is missing in display cable which is connected to monitor, Red color image on monitor wil be replaced with other fade color.
So, need the replace the display cable or display connector!
Dec 09, 2010 | LG Studioworks 700S 17" CRT Monitor
Gateway FPD2275W LCD monitor lost "Red" signal of RGB display
Not really, first check your connections, normally when you loose red a pin broke off the VGA connector.
If the panel died then its probably not worth while. The red panel is however, under the most stress.
Jul 09, 2010 | Gateway FPD2275W LCD Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
Camera display is constantly red
problem in LCD (display) replace it
Oct 25, 2009 | Pentax Optio A30 Digital Camera
Discoloration - No display of RED Color
unplug for 10 min to reset then plug back in go to menu and configure the color
Jun 06, 2009 | Microsoft Windows XP Media Center Edition...
Smearing of colors
I have a red tint on the left side of my display at all times. also red smear after any white boxes in display. Has anyone else had this problem?
Feb 19, 2008 | Planar WS231 23.1 in. Flat Panel LCD...
AMILO M1451G display
if you can notice this problem in the BIOS then the problem is with the Display adapter .. if you newly bought your computer i suggest you send it back
Dec 29, 2007 | Fujitsu Siemens AMILO Pro V2010 Notebook
Sony WEGA TV Red color wont display at all.
as other color are ok(blue&green)& no red colour.please check as follows. 1 check supply to red video transistor. 2 check for loose crt base. 3 check for loose connector 4 check components related to red video ckt.& cathode ckt. 5 check for red signal is coming to red video ckt. 6 check red cathoe voltage. 7 signal processor ic.
Sep 30, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Samsung 225BW Monitor Logo
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
