Question about KitchenAid Salad Spinner, 3-Dividers, Red
How to fix a kitchenaid salad spinner
The spinner doesn't work
How do I remove the plunger for washing?
The plunger on mine cannot be removed. I just checked it to make sure. If you remove it, you have broken the unit. Just rinse with water. The plunger should not get dirty of used properly. A rinse under running water is enough.
Jan 28, 2015 | KitchenAid Salad and Fruit Spinner - White...
How do you make salad?
http://en.wikipedia.org/wiki/Salad_spinner
the spinner removes water from lettuce leaves to allow oil (salad dressings) to stick to the leaves. Spin salad then put in a bowl and mix with a salad dressing .
Nov 02, 2014 | Home
Can't lock down my kitchen aid salad spinners handle
You can't the product sucks worst salad spinner on mkt.way over priced
Apr 08, 2014 | KitchenAid Green Apple Classic Salad...
How should I dry lettuce if I don't have a salad spinner?
I don't have a salad spinner at home. All I do it rinse the lettuce, leave it basically "standing up" inside of a collander and let the water drip off. If I don't have enough time to leave it til it drys on its own, I sometimes shake it out and then wrap in it paper towel for a few minutes.
Jul 11, 2013 | Home
Is it true that it isn't good to put mushrooms in a salad spinner?
I haven't heard that but I'm guessing the myth has more to do with getting mushrooms wet. Some chefs say that if by washing mushrooms off with water, it rids them of some of their earthy flavor. Many chefs at nice resaurants simply rub the dirt off of mushrooms, not soak them.
Jul 11, 2013 | Home
I've got mould in the little squares of my salad spinner. What's the best way to clean it?
I'm guessing that your salad spinner is made of plastic. If you don't have a dishwasher with a hot water option, I would fill your sink with very hot soapy water and let it soak until the water cools. By then, most of the mold should have come off and you can simply rinse it.
Jul 11, 2013 | Home
Where can I buy a salad spinner? It'd be a bonus if it had a brake in it to stop the spinning.
With a brake!! enjoy :)
http://www.target.com/p/oxo-salad-spinner/-/A-628331
Jan 14, 2013 | Home
What does a salad spinner do?
A salad spinner washes and takes away extra water from the lettuce/spinach/etc. The lettuce spins around which creates a centrifugal force. This force gets rid of the water.
Jan 14, 2013 | Home
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
KitchenAid Salad Spinner, 3-Dividers, Red Logo
377 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
