Question about Cameras
System error comes up Lens will not retract - Cameras
    Top Expert:
  • Cameras Master
  • 75,797 Answers
There is nothing you can do except replace the camera or have it repaired. Some camera makers also offer exchange problems.
Posted on Oct 26, 2012
SOURCE: lens will not retract
In my case, there was dust in the switches that sense the cover movement.
  1. Close the sliding door and wait until the lens is drown inside (timeout).
  2. Open the screws that secure the front cover.
  3. Remove the sliding door covering the lens. There is no trick (hidden screws etc) so just use the force. The door is mounted by two-sided tape and adhesive.
  4. Remove the front cover. This is also mounted by two-sided tape / adhesive in the center, so you have to be a bit brave.
  5. The sliding door rails and the movement sensors are now visible. Clean all dirt.
  6. Try the door functionality.
  7. Mount the front cover after the lens works as it should. Close the screws.
  8. Mount the sliding door.
Posted on Oct 23, 2008
emissionwiz
  • 75797 Answers
SOURCE: camera focus error
there is a small logic circuit that controls the motor that retracts the lens and a sensor that tells it the lens is retracted, it is a lens position sensor, one of these two components is most likely defective, the thing is there are no consumer service info provided by panasonic, they will not sell you parts either, the camera is a mystery to take apart and repair without the tech manual which u can't get, so u see the delima here, u must either have this camera fixed by a panasonic repair station or see if it qualifies for a upgrade exchange program for a newer model.
Posted on Aug 07, 2009
RixsFixes
  • 2200 Answers
SOURCE: Nikon Coolpix 3100 will not turn off or lense retract
Try removing the battery from the camera to see if this will force a reset. This may well resolve the problem.
If your problem persists after this please do add a comment and I try to assist further.
Thanks for using FixYa.
Posted on Nov 02, 2009
  • 102366 Answers
SOURCE: lens error and will not retract
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Feb 22, 2010
SOURCE: lens error 126,1,0,-9
Mine said error code 126, 1, 0-9 but it was just bent so I had to bend it back, now it works fine.
Posted on Apr 02, 2010
My lens won't go in and when I try to take a picture it clicks and the code E18 comes up.
lens error comes when your lens is not able to retract insde.
This can be due to some kind of dirt or any sand particles stuck inside the lens. this may also occur when the camera is dropped from a height which damages the lens system.
Please give a small tap to the camera lens. It works in many cases. If not you will have to consult a authorized service center
Jan 03, 2011 | Canon PowerShot S2 IS Digital Camera
Lens error - clicking/gravelly sound when opening and closing and zooming. Comes up with 'lens error' on camera
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
Aug 18, 2010 | Canon PowerShot A480 Digital Camera
Lens will not retract. orange and green lights come on, but preview screen remains dark and lens will not retract when I trun it off.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
May 02, 2009 | Cameras
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
System Error
I had the same problem. It was because the lens had just begun to retract and then jammed. I tried pushing back it in to no avail. I was considering it was time for a new camara anyway. Hoping to get a little more life out of it, with nothing to lose I was about to take it apart to see if I could clean out any obstruction as other posts had reccommended. Before I did that, I let my Mr. Goodwrench cousin take a look at it. Instead of trying to force the lens back in, he pulled it out. Apparently the slight play in the lens allowed him to do so and whatever was jamming the lens from retracting must have fallen out. Suddenly, the lens retracted and the camara is working fine. So before you throw the camara away or take it apart, try pulling out on the lens housing. You may also have to move it slightly back and forth while pulling out to get whatever is jamming the lens to move out and away releasing the lens to retract again.
Oct 25, 2008 | Nikon Coolpix 775 Digital Camera
Zoom will not retract
Dear Grammie,
You have either experienced a lens error or your zoom dial is broken (both usually caused by some sort of impact damage, but which can be spontaneously occuring).
Look for an error message on your camera's LCD screen such as "E18," or "lens error restart camera." If you do not see a lens error but simply cannot retract your zom lens (go into wide angle mode) via the zoom lever then it simply maybe a broken command dial. Either way, however, you will need to have the camera serviced in all likelihood. Call tech support at 1-800-828-4040 M-F from 8 am to 12 midnight EST and Saturdays until 8 pm EST. Hope this helps.
Sincerely,
HeavyDLB
May 22, 2008 | Canon PowerShot A540 Digital Camera
"lens error" on casio ex-z3
Sorry to say but a lens error actually is a problem that you cannot fix at home. When a lens error occurs, the motors inside that make the lens retract and protract were some how damaged, usually caused if the lens try coming out when you have it in your pocket or against a surface so it cant fully come out. You will have to send the camera in for service and you can do that by calling 1-800-706-2534, option 1.
Oct 19, 2006 | Casio Exilim EX-Z3 Digital Camera
System error
hi the problem that causing this is: there is some pressure to the lens did it fell? probebly there is a fault in the lens sorry cant help good luck
Mar 20, 2006 | Panasonic Lumix DMC-LC43 Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
