Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
Clicking Hi. I just received a KitchenAid Heavy Duty Plus mixer, the KSM50 series for Christmas. I am very excited. I finally used it today to make pound cake. When I whipped the eggs with the whip attachment, everything went great. But, when I began mixing the batter with the flat beater a clicking sound started. The sound matched the speed I was mixing at- at higher speeds it got faster. When I turned it off and checked the attachment, when I shook the beater back and forth it made the click sound i heard when it was going. My husband said that it was the gear, but the whipper worked fine. We then wondered if it is normal for that to happen with heavier batters? Other friends have these mixers and I have not heard them click with any batter. Suggestions? Thanks.
    President:
  • 2,976 Answers
I have the same mixer. Make sure the bowl is firmly latched into the base. also, make sure the bowl didn't get bent in shipping. If the paddle hits at a regular timed interval, it's must likely a problem with the way the bowl seats. As long as you don't hear a loud hit verses just a click, it shouldn't be a problem, just an annoyance. In time, you will probably heat tapping when you use the wire wisk. I am glad I bought mine. I hope you enjoy the difference a good mixer makes.
Posted on Jan 03, 2009
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Kitchenaid Heavy Duty 325 stand mixer. Making cookies and now the motor runs but it doesn't turn to mix. PLease help/.
kITCHEN AID ARTISAN 325 WATTS TILTING HEAD PIN CAME OF WHILE MIXING DOUGH. HOW IS THE EASIEST WAY TO INERT PIN BACK OR LINE UP THE HOLES TO INSERT PIN?.
FRANKAMOR
Feb 06, 2010 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Wifey dropped her mixer this evening...Now its leaking oil...Hate to get rid of it...Would like to repair it if possible..Any suggestions ?
First thing is to determine where the leak is and if the broken part is available and replaceable. If it is the main housing I think a new mixer would be a wonderful Christmas present,
Eric
Dec 19, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchenaid mixer 45ss
I dont know much about them but If you cannot get it repaired I do have a lift bowl stand mixer that I bought without the bowl or attachments that I would sell for $80.00 Or I will buy your attachments. Thanks, Mark.
Mar 23, 2009 | KitchenAid K5SS Heavy Duty Commercial...
I don't know how to use the small bowl that came with the
All Kitchenaid manuals are available online at www.kitchenaid.com.
On the main page, click Customer Care in the upper-right hand corner. Then click Locate Manuals and Guides.
You will want to enter your model number exactly as it appears on the bottom of the unit. You will need to tilt the mixer gently onto its side and locate a white sticker to see this.
When entered on the website, this will pull up the Use and Care Guide (manual) and even exploded parts views if those are needed.
Dec 10, 2008 | KitchenAid KP2671 Professional 6 Series...
Beaters don't reach the bottom of the bowl
There is an adjuster on the model I own - the KSM50... It is a tiny little silver screw at the base of the motor between the screws that mount the bowl mover to the stand. Screwing to the left makes the bowl lower and turning to the right makes the bowl higher. I just adjusted mine. Note - just a slight turn can make a difference, but my screw was SO TIGHT- I had to ask my husband to do it. Plus, it is located in a difficult area for some screwdrivers to fit into. He got mine to budge and now my clearance of beater to bowl ratio is perfect.
:) Hope it works for ya,
Nov 05, 2008 | KitchenAid K5SS Heavy Duty Commercial...
The adjustment screw fell off
There is no adjustment screw. That should be all the way up so that it will compress the spring and lock the lift lever un the up position. You will need to put the spring, washer and then the Nylock nut back on, I use a standard socket with some paper wadded in the bottom and over one side to hold the nut it it while I screw it back on.
Nov 02, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid 325 Heavy Duty Stand Mixer runs with low power & clicking noise
well there is a couple of things to try
1. see if kitchenaid sells the motor or
2. if a local appliance parts store can get the motor
this is the only thing you can do about the motor , the wires in the motor are shot and it will need reconstructing in the wireing, that is why it won't run fast and strong , because the wires have been heated up to much and now they can't create a strong enough magnetic field
but to replace the motor shouldn't be to hard just a little patience
if you need any more help just let me know!
electech
Oct 22, 2008 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Kitchen aide mixer
was the bowl snapped in to place.....push down on the back lip of the bowel until you hear it snap
Dec 30, 2007 | KitchenAid KSM5PS Heavy Duty Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
225 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
