Question about HP LaserJet 4250n Printer
Hp 4250 won't print pdf documents - HP LaserJet 4250n Printer
worldvet
  • 859 Answers
SOURCE: Slow printing of Acrobat pdf files on HP Laserjet 1300
Hey look, sorry for all the BS you've been given. Its an issue here.
How much ram does your laser jet hold right now?
This would be the choke point on an HP laser jet.
A typical PDF file in high res can be many many megabytes in size and the HP Laser treats these documents as an image file, same in true in Windows, but uses local ram not printer ram like an Apple.
So, if you have a 256K chip, its possible, on your printer and the file is 4-6 MBs in size, you could be looking at a 16-20 minute print job.
I'm not familiar with any tricks to get your printer to use local ram as a cache. If you have Boot Camp, you might consider starting that emulator up and printing from that interface. No real hope for a difference but its worth the try.
Hope that give you some real thoughts to chew over.
Regards,
Worldvet
Posted on Sep 29, 2008
  • 2692 Answers
SOURCE: HP 6940 will print Word documents, will not print PDF
The reason why is because PDF format can only be printed or modified from the software that writes it. You have only a PDF reader correct?
Posted on Mar 12, 2009
SOURCE: problems printing with HP Deskjet 1280
When I printed powerpoint documents on a hp deskjet 1280 it failed to print lines. I found that this problem could be solved by changing the transparency attribute of the line to 50%. The transparency attribute of a line or shape can be found by clicking on the sequence format/shape-outline/more-outline-colours/transparency at the top of the screen
regards
Graham Pratten
Posted on Apr 27, 2009
  • 96 Answers
SOURCE: HP Laserjet 1200 prints pdf documents slow
pdf documents are historically slow, they usually depend on how they are created and how many attachments or upgrades have been added to the document. this accounts for some of the variations of speed the documents are printed.
Posted on Sep 09, 2009
  • 311 Answers
SOURCE: my hp f 380 printer wont print pdf documents
in this case
open pdf
the click on print
now you need to look for the option that says print as image and this option has to be checked
you can get the option by clickon on advanced or prefrences
Thanks
Posted on Mar 05, 2010
Canon MX860 won't scan to a pdf
Scan and create PDF documentYou need to install a PDF printer driver on your computerfirst. There are quite a few freeware PDF writer programs on the Internet youcan download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select thePDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :-http://www.cutepdf.com/
May 18, 2012 | Canon Office Equipment & Supplies
Paper jam - 13.20.00 'open rear tray' but I can't get my fingers inside to pull any paper out! Please call me on 02076082726 or email me thanks!
Depending on exactly where the paper jam is at, you can try removing the front cover to get the paper. There's only a few screw you have to take off.
you can check out this site. PDF document on how to take the printer apart.
http://www.partshere.com/Models/Q5406A/LJ_4250%204350Removing_n_Replacing_Parts.PDF
good luck!!
Sep 01, 2011 | HP 4250 Monochrome LaserJet Printer
I cannot print a document from my Asus eee pc 900 series using HP Laserjet 4L - it prints test page only. I also have Canon BJC-100 and it won't even print a test page from that.
Hi Sir/mam '' i hope i can help you with my idea ' as you said your HP prints the print test but not working to print any document '', so here we start on start menu then click my computer , as it opens you can be able to see your HP device icon , click HP then click print settings , set it to print using HP as default printer , because another instance it is set to print to image or print to file or print to email. . thank you
Jul 16, 2011 | Computers & Internet
I Have An HP D145 Printer That Won't Print Some Online Coupons Or Will Only Print Portions Of Them. Any Advice? Thank You
Most likely this is an issue with the way the website is displaying the coupon. Check to see if there is an option to print coupon. You might also try to create a PDF copy of the coupon and then printing the PDF document. Finally, one other thing you could try is to take a screen capture of the coupon, save as an image file or PDF and then print as an image or PDF. Hope this helps.
Jul 11, 2011 | HP OfficeJet d145 InkJet Printer
We have a new hp lasterjet 4015n. It will print two sided, but it won't flip up the back side. I have my driver set to duplex print and flip up, but it won't flip up. Is there some setting on the...
I assume that you attached the two-sided printing accessory (duplexer) to your product:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01909142&cc=us&lc=en&dlc=en#N428
The duplexing has to be set in the printer's
Printing submenu
DUPLEX OFF/ON
This item appears only when an optional duplexer is installed. Set
the value to ON to print on both sides (duplex) or OFF to print on
one side (simplex) of a sheet of paper.
The default setting is OFF.
Print on both sides (Duplex) Click Print on both sides. If you will bind the document along
the top edge, click Flip pages up.
User manual:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01295101/c01295101.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 01, 2011 | HP LaserJet P4015N Printer
My hp c5280 suddently won't print. Says refer to printer documentation...what documentation?? Little came with the printer. whaat can I do
You get very little printed material with any hardware these days. A full user's manual is typically included on the CD that came with your printer, and that's what the message is referring to. If you don't have the CD, you can download manuals from HP's support and drivers site. They also have information to help you troubleshoot and resolve printing problems.
Jun 03, 2011 | Computers & Internet
Maximum file size for printing on the hp color laserjet 5500n - having issues with pdf files
If you are getting 49.XXXX error codes while printing PDF files, you can try upgrading the machines firmware.
This seems to be a common "PDF file printing" problem with the LaserJet 4250.
Oct 25, 2010 | HP Color LaserJet 5500 Printer
Ink smudges on the right side of the paper
Your problem is due to a worn fuser unit (upper fuser roller).
The teflon coating has worn again, alowing the toner to stick to the roller and then "repeat" about 3x down the paper (getting fainter each time).
You need to order a new fuser unit.
Click here to go to HP direct
RM1-1083-070CN Fuser assembly - 110 VAC - For LaserJet 4250/4350 series RM1-1083-070CN Fuser assembly - 220 VAC - For LaserJet 4250/4350 series
Make sure you order the currect voltage (US or UK)
Regards
Vince.
Mar 04, 2009 | HP LaserJet 4250n Printer
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
HP LaserJet 4250n Printer Logo
Seeker5211
Seeker5211
