Question about Tools & Hardware - Others
How to reset timer on 2W900-FMR remote trarter
How do I reset my nec projector model vt700 lamp time without remote
How to Reset a NEC Projector Lamp Timer ... - RelampIt
www.relampit.com/Projector-Lamp-Timer/NEC-Projector-Lamp.php
How to Reset a NEC Projector Lamp Timer. Make sure the projector is in standby mode; Press the Off or Help button on the remote control for a minimum of 10 ...
NEC reset lamp without remote Questions & Answers - Fixya
www.fixya.com/tags/reset_lamp_without_remote/browse/nec
My bulb warning had just recently appeared a few weeks prior, so I thought the bulbmust ... ...reset the Lamp timer o an NEC MT1050 projector. ... ...reset lamp usagetime without the remote on NEC VT490 HelloPress the MENU button on the ...
reset lamp hours nec projector without remote Questions ...
www.fixya.com > Forum > Tags
Find solutions to your reset lamp hours nec projector without remote question. ... My nec vt48 projector gets hot and turns off. It ... Question about VT700 Projector.
Replacing The Lamp - Nec VT700 User Manual [Page 58]
www.manualslib.com > ... > Projector > VT700 > User manual
Jan 29, 2016 | NEC Office Equipment & Supplies
I'm trying to cut off the timer on a sony t.v.RM-Y909 so I can turn my t.v. on with the remote control.
The RM-Y909 works for the KP46WT500, among other TVs. For the KP46WT500: to reset Timer 1 or Timer 2, you need to access the timer sub-menu. With the TV on, press Menu. Use the Joystick on the remote to select the Timer icon (looks like a clock) then press the center of the joystick (with the + with a circle at the center symbol). Use the joystick to select the timer you want to reset and then press Reset (on the left side at the bottom of the remote). Alternatively, you can just turn off the timer. The TV will remember the settings. Press Menu to exit the menus.
Sony has the manual on their product support page in the manuals tab: https://esupport.sony.com/US/p/model-home.pl?mdl=KP46WT500 . The direct link is https://docs.sony.com/release/KP46WT500.PDF . The Timer menu section is on page 57. I hope this helps.
Aug 31, 2015 | Sony Televison & Video
Reset lamp timer
Try this, it works on older LG TV models:
Put the projector on. While holding down the Menu key on the projector, press and hold down the Menu button on the remote. Keep both buttons pressed for a count of at least 5 seconds.
When the Service Menu pops up, release the Menu button on the remote control first and then the one on the projector after.
Now you're in to the service menu, you need to find out which button on the remote brings up the Lamp Timer Reset function. This is where you're going to have to do a bit of trial and error. With the TVs, the remote button was the Mute key. There isn't a Mute key on the projector remote, so try the Lamp key first. If that doesn't work then try some other buttons. Here's the method.
While holding down the Enter/OK on the projector, press and hold the Lamp key for five second. If this works then the lamp timer reset box should appear. Release the remote button first, followed by the unit button.
Press Enter/OK on the remote to reset the lamp timer. If there's an On Screen Prompt to confirm, press Enter again.
Press Exit on the remote to come out of the menus.
Warning: Don't reset or change any other functions. The service menu isn't the place to be tinkering around with stuff you don't understand.
Aug 31, 2014 | LG Office Equipment & Supplies
HOW DO I RESET THE LAMP TIMER ON A SONY KDF55WF655
Procedure for resetting your lamp timer,
Use the Remote Commander to put the set into service mode to display the service menus.
1. TV must be in standby mode (Power off).
2. Press the following buttons on the Remote commander within a second of each other: DISPLAY ==> Channel 5 ==> Volume + ==> POWER. The first service menu (TV) displays.
To reset the Lamp Timer:
1. Press the JUMP button 3 times on the remote to get to the Panel OSD mode.
2. Next press the remote channel 2 button 9 times to get to the Lamp Timer mode.
3. Press the remote 3 button, mute, then enter to reset the timer to zero.
It will take 45-50 seconds for the timer to reset. After the timer is reset you can shut the TV off. The lamp timer will remain reset (no need to save).
Jun 30, 2011 | Sony Televison & Video
What are the specs of a power adapter for an old Telex FMR-2 wireless reciever.
Check this out-including specs receiver. hope this will help ........................................
http://pdf.textfiles.com/manuals/STARINMANUALS/Bosch%20-%20EV/FMR-450.pdf
Aug 08, 2009 | Telex FMR-500 Microphone
How do I reset the filter timer on the hitachi cp s210?
The reset function is in the options menu. Once you scroll through the menu locate the filter timer, forward to the timer locate reset, you then need to hold down the reset button on the bottom RH of the remote control.
May 07, 2009 | Hitachi CP-S210 Multimedia Projector
E44W46LCD Lamp Timer Reset
To reset the lamp timer, hold the "enter" button on the tv and the "mute" button on the remote at the same time. Once the menu pops up, hit the right arrow on the remote and confirm the reset.
I would guess that's it's a little too late for this answer now, but for future reference... ;-)
Jan 09, 2009 | Zenith E44W46LCD 44" Rear Projection...
Replacing the projection lamp
Try resseting the lamp timer following the info below: Procedure for resetting the KDF42WE655, KDF50WE655, KDF55WF655, KDF55XS955, KDF60WF655 or KDF60XS955 lamp timer:
Dec 05, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projection lamp timer reset
I need help resetting the lamp timer. Is there a way to reset the timer w/o the remote? We bought this tv as a floor model 4 yrs ago and they didn't have the actual remote that came with it, so they gave us another remote that works. We replaced the lamp but we keep getting the message that the lamp needs to be replaced and the timer reset. Plus the red lamp indicator is still on. We even used a friend's remote (he has the exact same tv) and it still will not reset the timer.
Jul 19, 2008 | Panasonic PT-44LCX65 Television
Tools & Hardware - Others Logo
16 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
