Question about Proscan 32LA30Q Television
Have a time warner cable remote need a code for proscan led tv
5 Suggested Answers
SOURCE: cant control tv with direct tv remote
I don't know what size TV you have but just installed Direct TV for parents and none of the codes worked after a LONG time my husband tried the Sears codes and got the last one he tried to work. He used 10056. It is a 47 inch LCD Proscan TV. If that doesn't work, you might want to try all of the Sears codes to see if one will work for you. Good Luck
Posted on Mar 17, 2009
MNfisherman
  • 11896 Answers
SOURCE: need codes for proscan
phone_header_def.png saveupto_a.png phone_callnow_def.png DIRECTV Specials DIRECTV Packages DIRECTV Receivers DIRECTV DVR DIRECTV HD DIRECTV vs. Cable DIRECTV vs. Dish DIRECTV Sports Home > Remote Codes DIRECTV Remote Codes remote_codes_header.jpg TV CODES VCR CODES DVD CODES STEREO RECEIVER CODES
STEREO AMPLIFIER CODES DIRECTV RECEIVER CODES
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Posted on May 06, 2009
  • 814 Answers
SOURCE: proscan universal remote
Found these codes on the website for PROSCAN. www.oncorpus.com, for you model television.I hope this help you with your problem. UNIVERSAL REMOTE CONTROL CODE LIST
For Universal Remote Control brands listed below, please use accompanying Proscan codes
and refer to your Universal Remote Control User Manual for basic instruction for changing TV code to
operate Proscan model.
Proscan codes for Sony TV=8003,8012
Proscan codes for Philips TV=1005,1006,1007,1035,1064,1216
Proscan codes for other universal remotes=272,132,134,116,040,016,024,056,019,262
Posted on May 21, 2009
SOURCE: lcd 32" proscan need code for universal remote
The code for Proton works for Proscan LCD televisions. I have 2 codes for Proton 10178 and10466.
Posted on May 30, 2009
Time Warner codes for Mitsubishi tv
If Time Warner remote is universal, you probably can use its code search feature to find something that will control your Mitsubishi TV. Also, Time Warner might be able to tell you what code to use.
Jan 14, 2015 | TimeWarner Cable Time-warner cable...
Trying to find a remote code. The tv is a 19"PLEDV1945A-B and the remote is a Time Warner UR5U-8780L-TWC
TV Instructions:
TV Codes: try 333
or 116, 143, 258, 363
STEP 1 Turn on the TV.
STEP 2 Press the [TV] button and the [OK/SEL] button simultaneously for three seconds. The TV Device LED will turn on indicating that the remote is in the programming mode. The LED will remain on for 30 seconds and the next step must be entered while the LED is on.
STEP 3 Point the remote control toward the TV and enter the three-digit code number assigned to your brand device (codes can be found in the code tables in the user guide or online). If there are more than one three-digit number listed for your brand, try one code number at a time until your TV turns off.
Note: When the TV turns off you can verify that you have selected the correct code by pressing the [POWER] button. The TV should turn back on. Then try all of the functions on the remote control (i.e. volume, mute, etc.) to ensure you have the correct code. If any of the functions do not operate as they should, repeat the instructions from STEP 3 above using the next three digit code number from the brand list.
STEP 4 Store the three-digit code by pressing the [TV] button once again. The TV Device LED will blink twice to confirm that the TV code has been stored.
Program My Remote Time Warner Cable
Nov 13, 2014 | Proscan 19 In. 720p LED HDTV/DVD Combo...
Time warner remote code for seiki 24'' led tv
Code for the black remote UR5U08780L-TWM is 132
Jun 20, 2012 | Televison & Video
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
Feb 27, 2009 | Panasonic Televison & Video
Can't get universal remote or cable remote to work with my tv.
I need programming instructions for proscan universal remote control. I have code.
Feb 20, 2009 | Proscan 32LA25Q 32 in. LCD TV
Program Time Warner Remote RT-U62CP-1.17 to work ONKYO TX-SR575
i bot a new tv i don't have the book for the time warner remote so i don't know how to program it to work the tv it only works cable box
where can i find how to program remote that comes with time warner cable
Dec 26, 2008 | Onkyo TX-SR573 Receiver
Proscan 32LA30Q Television Logo
530 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
